EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > General Explorations!!
Notices
General Explorations!! Closed to new posts. Place new posts in our new model year appropriate forum
97 Mountaineer v8 tranny o/d shift rough
Thread Tools
Old 01-12-2005, 06:57 PM   #1
jackehendrix
birmingham, al
'97 mountaineer
Vehicle Specs
(Original Poster)
Unhappy 97 Mountaineer v8 tranny o/d shift rough
I don't know what tranny I have. I don't know much of anything actually, but I started feeling and hearing a "shudder" when shifting into (and I think out of) overdrive. If I turn the o/d switch off, it doesn't happen. I did tow a trailer load of wood (very heavy) recently and I did not know to turn off the o/d.
Help!
jackehendrix is offline
Old 01-12-2005, 07:26 PM   #2
Bill Kemp
Elite Moderator Emeritus
Greenville, MI
Bill Kemp's Avatar
98 Mountaineer 5.0 AWD
Vehicle Specs
I would start out by changing the trans. filter. This will get about five new quarts of fluid into the trans. and should cure your problem. If not there is a lot more you can do but hopefully you wont need to go any further.
Due to the age of the trans. I would not suggest a flush. Just a filter change.
__________________
Bill Kemp
Mods to come.....
07 Lincoln MKX
Clones are people two.
Bill Kemp is offline
Old 01-12-2005, 07:45 PM   #3
jackehendrix
birmingham, al
'97 mountaineer
Vehicle Specs
(Original Poster)
I should have mentioned. I had the filter and all fluid (flush) changed. It did seem to help, but still a little noise and shift roughness into o/d.
Old 01-12-2005, 10:20 PM   #4
V8Exploder
Los Angeles CA
96 XLT V8
Vehicle Specs
mine has a smilar problem, I have a really hard downshift from o/d coming to a stop. If I do it manually, its not bad, but when I get to the bottom of an offramp it shakes the whole car and makes a huge "THUD", sometimes worse than other but I just changed the filter and fluid and added some lubeguard trans additive and it cleaned up the jolt a little bit, but its still noticable. I dont know what can cause that problem, I just hope it doesnt get any worse. I too tow, I have a 2k lb boat but the V8 and trans can handle that no problem, I'm just keeping my fingers crossed
V8Exploder is offline
Old 01-12-2005, 10:22 PM   #5
Glacier991
EF Tranny Guru
Sacramento, CA 95827
1992 XLT
Vehicle Specs
BTW you have a 4R70W. Might try a bottle of Lubegard... any transmission supply house will have it.
Glacier991 is offline
Old 01-12-2005, 10:37 PM   #6
V8Exploder
Los Angeles CA
96 XLT V8
Vehicle Specs
Napa has it ! It tightened up my shifts and like I said helped lighten up the thud, it worth a shot !
Old 01-12-2005, 11:15 PM   #7
Glacier991
EF Tranny Guru
1992 XLT
Vehicle Specs
Ok Aaron when do we get the picture studded thread on your effort !???? I know you did one....
Old 01-12-2005, 11:30 PM   #8
V8BoatBuilder
Transplanted Bostonian
East Brunswick, NJ
V8BoatBuilder's Avatar
97 Mountaineer V8 4x4
Vehicle Specs
Haha Chris, I just stumbled onto this thread
jackehendrix,
I installed a Baumann engineering shift kit into my 1997 4R70W, and had the valve body apart. The thread (with pics) can be seen here: http://www.explorerforum.com/forums/...d.php?t=123942
One of the modifications that Baumann suggests to add is a redesigned Torque Converter engagement valve. Check out: http://www.baumannengineering.com/aodecat.htm and scroll down to the "Bypass Clutch Control Valve for AOD-E / 4R70W Transmissions" as taken from Baumann's website:
"This precision replacement valve and orificed sleeve are manufactured by Sonnax utilizing superior construction and materials. These redesigned components help to prevent and eliminate torque converter clutch slip and shudder concerns in AOD-E and 4R70W transmissions. This valve is recommended for any AOD-E or 4R70W transmission that has higher mileage or has experienced torque converter clutch problems."
It is installed in the valve body, and does not require removing the entire transmission. My torque converter was not having any difficulty enaging or disengaging, but I installed the valve as cheap insurance while the valve body was sitting on my bench.
It might also be worth calling Baumann up, they know a ton about modding the 4R70W, and could possibly recommend other parts/mods.
A simple pan drop removes about 4-5 quarts of ATF from the system. If you do drop the valve body, you will take out about 12 quarts of ATF from the system. That's most of it. I use Castol Mercon V, with good results. Mercon V is more expensive than DexronIII/Mercon, but the two are NOT compatible, and the 4R70W needs the MerconV.
Here's a tip, the standard FRAM trans filter, sold at many autoparts stores is the actuall OEM filter. Fram doesn't make them, they just re-sell them. One of the reasons, IMO, that flushes kill transmissions, is that they don't change the filter. Instead, the new, detergent laiden, clean fluid knocks gunk loose, and cloggs the filter and valve orificies. They're tiny. Keeping that filter clean is a top priority. I installed an external filter.
If you remove the valve body, get yourself a torque wrench. Ask us here, and I'll post the torque specs and sequence for the bolts. It matters. You'll also need valve body gaskets.
__________________
-Aaron
Off Road: 97' Mountaineer: V8, 4x4, 4.56s, 4" Superlift, SOA, TrXus 33x12.5 - Under The Knife
Work: 00' Ranger 4cyl 5spd, 02' Ford E250 5.4
On Road: 2006 VW Jetta TDI/6spd DSG. Fill it with diesel, please.
Octopus Yachts, LLC Engineered Marine Electrical Systems
V8BoatBuilder is offline
Old 01-13-2005, 12:14 AM   #9
Glacier991
EF Tranny Guru
1992 XLT
Vehicle Specs
I am anxious to do a 4R70W upgraded rebuild.... anyone on the left coast who wants to be the guinea pig PM me!
ps. Aaron.. There is an old adage.... "He do not tootheth his horn, the same shall not be tooted". Great thread btw.
Old 01-13-2005, 12:26 AM   #10
V8BoatBuilder
East Brunswick, NJ
Vehicle Specs
Man... all the cool kids play next to the pacific ocean. I have a feeling my 4R70W will be out within the year to install the Advance Adapters kit.
__________________
-Aaron
Old 01-13-2005, 07:01 AM   #11
jackehendrix
birmingham, al
'97 mountaineer
Vehicle Specs
(Original Poster)
Smile Accolades
You guys are great. It has been a good truck and I actually like working on it, but I don't know what I am doing. I think that I will attempt the valve body removale and do the modifications suggested. I will look at the threads and call Baumann before I start. Any other tips will also be appreciated.
I mainly know real estate, so email me if you need advise in that arena.
Old 01-13-2005, 01:51 PM   #12
97BlackX5.0
Scipio, Indiana
97BlackX5.0's Avatar
97 X XLT AWD
Vehicle Specs
just curious but when they did the flush what fluid did they put back in ... i remember someone telling me a while ago that they updated all 4r70w's to mercon V fluid to eliminate precisely the shudder your talkinga bout.... when they flushed it they could have used regular mercon and not the merconV as not alot of people know about the update... so you might be feeling the effects of a different fluid
__________________
97 5.0 v8 Black AWD
31x10.5 Goodyear RT/S
MAC air intake
Borla Cat Back Exhaust
170,000 and still goin strong with lots of lovin
97BlackX5.0 is offline
Old 01-13-2005, 03:13 PM   #13
jackehendrix
birmingham, al
'97 mountaineer
Vehicle Specs
(Original Poster)
Mercon III vs Mercon V vs Dextron III
I just pulled the invoice and it reads 14 quarts Dextron III /Mercon ATF. As I remeber the conversation when I dropped it off the Technician (if that is the right term) asked me whether I used Dextron III or Mercon. I couldn't answer so as he was raising the hood, he said "it doesn't really matter, cause Mercon is just Dextron with an additive which we will add it if it calls for Mercon." I could be mistaken about the above fluid names. You might have to change the order of the proper names in the above quote and or substitute completely different names (or roman numerals). I will call them before I do anything and try to pin them down. If you can shed any more light on the different types of fluid and what I should do to be sure that I get the right type in there I would be thankful.
Old 01-13-2005, 03:17 PM   #14
V8BoatBuilder
East Brunswick, NJ
Vehicle Specs
Your transmission needs Synthetic Mercon V. Mercon and Dexron III are very different. If they put in the wrong fluid, make them change it. MerconV is more expensive, so you might have to pay. I'd argue it though - they screwed up.
Unless there is some magical new additive, you CANNOT turn Mercon into Mercon V.
__________________
-Aaron
Old 01-13-2005, 05:02 PM   #15
V8Exploder
Los Angeles CA
96 XLT V8
Vehicle Specs
Sorry, I didnt take any pictures on my fluid and filter change, and I wish I could be more helpful on the problem, I guess the best I can do is make sure he is not the only one with a mickey mouse tranny. And I dont get the tooting horn adage....
Old 01-13-2005, 05:53 PM   #16
jackehendrix
birmingham, al
'97 mountaineer
Vehicle Specs
(Original Poster)
http://www.lubegard.com/automotive/i...ard_Poster.pdf
Lubegard is claiming to enhance DEXRON/MERCON ATF to provide a MERCON V type ATF.
Old 01-13-2005, 06:46 PM   #17
V8BoatBuilder
East Brunswick, NJ
Vehicle Specs
Cool. Had no idea that existed.
__________________
-Aaron
Old 01-13-2005, 06:52 PM   #18
mvoeller
Grand Forks
97 AWD 5.0 Explorer
Vehicle Specs
Some of the earlier 97 4R70W trannys used regular mercon fluid, such as my 97 Ford explorer. That's what it calls for on the dipstick and in the manual. But I think that you can switch it over to the mercon V fluid.
mvoeller is offline
Old 01-13-2005, 06:53 PM   #19
97BlackX5.0
Scipio, Indiana
97 X XLT AWD
Vehicle Specs
i was told the difference between mercon and mercon V is it is part synthetic and contains some different additives... it could be that adding a bottle to your tranny to update the mercon to mercon v could be suffiecient.... i personally am running regular mercon right now in mine and have not had any problems but am planning on switching to merconv when i change it again.... (this was before i knew about the tsb)...
__________________
97 5.0 v8 Black AWD
MAC air intake
Old 01-13-2005, 06:55 PM   #20
97BlackX5.0
Scipio, Indiana
97 X XLT AWD
Vehicle Specs
if somone could source the tsb number it would probably help alot of people because this seems to be coming up an awful lot
__________________
97 5.0 v8 Black AWD
MAC air intake
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
