Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
5R55E question for our trans. wizards...
Reply
Thread Tools
Old 01-18-2005, 09:04 PM   #1
Eneurb
Ajax, Ontario, Canada
1998 Limited
Vehicle Specs
(Original Poster)
Not to get into too much detail (yet), but do you think a leaking intermidiate servo could cause a soft 3-4 shift??
Eneurb is offline   Reply With Quote
Old 01-20-2005, 07:45 PM   #2
Glacier991
EF Tranny Guru
Sacramento, CA 95827
1992 XLT
Vehicle Specs
Could. But then it could be a myriad of other things too.... accumulator hydraulic circuits, sticky shift valve... partially plugged solenoid are just some other things that come to mind..I'd defer to Brain on this one...he's more knowledgeable about the 5R Valve body, which is where I suspect it is.
Glacier991 is offline   Reply With Quote
Old 01-22-2005, 06:55 AM   #3
Eneurb
1998 Limited
Vehicle Specs
(Original Poster)
I've answered my own question. Let me get into detail a little. Truck came into me with a flare up shifting from 3-4. I dropped the valve body to intall a pressure plate and found an air leak in the direct clutch. Disassembled the trans. to find a cracked direct clutch piston. Yay!! Put it back together (with a new valve body also), reinstalled and it drove great... for the first 4 shifts and the exact concern redeveloped. It has been suggested to me that if the intermidate band is hanging up it may cause the problem, but I feel that I would have concerns in more areas than just the 3-4 shift. I have since removed and disassembled the trans. again, and there appear to be hairline cracks in the center support, and the fluid does go through it on its way to the direct clutch... So I'll find out on Monday when my new center support comes in.
Old 01-22-2005, 09:51 AM   #4
Glacier991
EF Tranny Guru
1992 XLT
Vehicle Specs
You bring up an interesting point never really discussed around here.. the use of an air presssure plate to test circuits in an automatic transmission... Few people even know they exist, let alone their use, or use them...might be worth a thread. Good job btw!
Old 01-23-2005, 09:25 AM   #5
Eneurb
1998 Limited
Vehicle Specs
(Original Poster)
Whenever I reassemble an automatic transmission I put the air test plate on and test all my clutch packs, servos and pistons as I reassemble... in effort to prevent the problem that I am faced with right now... but nothing is fool proof.
__________________
I'd rather have a full bottle in front of me, than a full frontal lobotomy.
Old 01-26-2005, 06:21 PM   #6
Eneurb
1998 Limited
Vehicle Specs
(Original Poster)
Here's my final answer. After removing and over-hauling the trans. 3 times, air plate testing every step of the way, new center support and 3 valve bodies, I have decided that I must have an internal case leak. It's unfortunate when such a simple job goes to junk like this. Oh well.
__________________
Old 01-26-2005, 06:52 PM   #7
Glacier991
EF Tranny Guru
1992 XLT
Vehicle Specs
Have you put a pressure gauge on the various taps? AN internal case leak, while possible seems like the Zebra... When the problem may be a horse.
You are clearly HIGHLY knowledgeable. What are your current symptoms?
Old 01-26-2005, 07:35 PM   #8
Eneurb
1998 Limited
Vehicle Specs
(Original Poster)
Both line and epc pressures are in spec in all ranges and change with rpm and gear applications just as they should. There is a flare-up shifting from 3rd to 4th at all times after warm. I ended up going to let the owner of a local trans. shop test drive the truck for me this afternoon. He explained to me that he had the EXACT same symptom with a 1999 5r55e... after numerous teardowns he opted to change the case and all was fine. I have been as thorough as you can possibly be, and after 3 valve bodies I have eliminated them. Unfortunately there is no real way to verify a problem in the case.
__________________
Old 01-26-2005, 08:24 PM   #9
Glacier991
EF Tranny Guru
1992 XLT
Vehicle Specs
Fascinating. I am learning all the time. Any ideas to WHAT in the case is the culprit?
Old 01-26-2005, 08:38 PM   #10
IAmTodd
Johnstown, PA
IAmTodd's Avatar
1994 Explorer XLT
Vehicle Specs
I think somebody knows there way around auto trannies! Sorry I have nothing to contribute to this thread
__________________
1994 Explorer XLT | M5R1 swap | 2" Lift | 32" ProComp Mud Terrains
2006 Saab 9-3 Aero | 2.8 Full pressure turbo | 6MT | 280whp/325wtq
IAmTodd is online now   Reply With Quote
Old 01-26-2005, 10:01 PM   #11
Eneurb
1998 Limited
Vehicle Specs
(Original Poster)
There has to be a crack between fluid passages or something... the dude at the tranny shops exact words were, "there has to be a shower of fluid inside that case"... I have seen bigger trannies like E4ODs actually twist the case... but that was on a diesel dually... not a 4.0 ohv ranger...
__________________
Old 01-29-2005, 10:32 AM   #12
Eneurb
1998 Limited
Vehicle Specs
(Original Poster)
Finally fixed... got a used case from a wrecker and transfered all the parts into it... for all the trans. overhauls that pay a killing, I guess it's not too bad when one goes wrong.
__________________
Old 01-29-2005, 11:46 AM   #13
Glacier991
EF Tranny Guru
1992 XLT
Vehicle Specs
I'll be damned. I definitely learned something on this one. Thanks!!
Old 01-29-2005, 04:18 PM   #14
Eneurb
1998 Limited
Vehicle Specs
(Original Poster)
You and me both!
__________________
Old 01-29-2005, 04:35 PM   #15
nascar_intimid
st.catharines,ontario
nascar_intimid's Avatar
'94 eddie ..'02 limited
Vehicle Specs
Now that's what I'm talking about...this sight put to great use!!!! :p
__________________
Looking back, Knowing that you gave it your all....Win or loose, you finish a champion.
Dale Earnhardt (nascar_intimidator7x)
nascar_intimid is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
