Gonzo
Elite Explorer<br><img src="/forums/images/stars4.
- January 10, 2002
- Vancouver, Wa
- '98 Sport
Here is my problem: When the heat/ac is off, air blows from the drivers side floor vent (nothing comes out of the passenger vent). The temperature is adjustable, even when everything is off. It blows harder at higher speeds, and less at lower speeds.
I tried doing the blend door fix, but when I took everything apart, I found out that it already worked fine. But I noticed this actuator. what is this for? Does it have anything to do with my problem? It is located behind the glove box. No matter what setting I put the heat/AC controls on, this actuator does not even attempt to move. You can see the vent behind the actuator. What is this vent for?
Underside of actuator with white vacuum hose:
Actuator with vent behind:
