Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Offroad Tech Forums > Offroad Explorer - Ranger Projects > Offroad Drivelines
Notices
Offroad Drivelines Ford Explorer and Ranger Transmissions, Transfer Cases, Driveshafts and Axles.
how do you tell if a cv joint in the front driveshaft is bad?
Reply
Thread Tools
Old 01-22-2005, 03:29 PM   #1
mercuryman97
greenville,sc
1997 Mercury Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
i have a 1997 mercury mountaineer.....and it has been making a bad clunking and popping noise and a jerky feeling when the front driveshaft is in....so i removed it and replaced all the ujoints and the problem still exists so i removed the driveshaft again.....so someone told me it could be the cv joint in the front driveshaft....so now i want to know how i can tell if the cv joint is bad and how to change it if it is bad.....pics would be great but not necessary?thanks
mercuryman97 is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-28-2005, 05:00 PM   #2
gavin
Anchorage, Alaska
gavin's Avatar
'97 Explorer XLT AWD 5.0L
Vehicle Specs
Quoted: 6 Post(s)
those noises would be the front driveshaft. With it installed, jerk the shaft around at the t-case... if there is a bit of movement, and you can hear clanking, then the CV joint is shot. And that joint is not replaceable, you gotta be a new d/s. The one I need, from fastpartsnetwork, is around $400... I've heard of a replacement that uses a u-joint instead of CV joint, and includes an adapter for changing to that style d/s, but haven't seen or found one myself.
__________________
Daily Driver: 1997 V8 Explorer - K&N FIPK, Granatelli MAF, 3" Body Lift, WAR-153 Shackles, Torsion Twist, custom-built skidplate. 4.56s, Ion Alloy 133's, 33x12.5 Interco TrXus STS.
1986 Bronco2: RIP
gavin is offline   Reply With Quote
Old 02-26-2005, 08:18 PM   #3
agallant
Boston, MA
2000 XLT
Vehicle Specs
Quoted: 0 Post(s)
I had the front drive shaft go on my 2000. Did the same exace thing. One thing you can try is tak the drive shaft out. If the noise goes away there you go. I drove with mine out for about a year. Any way when i called ford for a replacment the wanted over $600 for just the part. I ended up getting one at a junk yard for $75. Just a word of advice, if you drive around with out the front driveshaft in and decide to put one in at a later date, chase the threds with a tap and remember that you have to do a few turns with the tap and back it out. I snapped a bolt off in my t-case and broke a tap aswell.
-AG
agallant is offline   Reply With Quote
Old 02-26-2005, 10:48 PM   #4
ExplorerDMB
Moderator/Technician
Mechanicsville, Virginia
2004 Acura TL
Vehicle Specs
Quoted: 0 Post(s)
Quote:
I'm changing my front driveshaft to a u-joint driveshaft with a double cardan yoke - to compensate for the lift. I have a '95 driveshaft in the garage with a D.C. on it and a slip joint, so it should work out just fine. The CV-joint in the Explorers aren't really that strong in my opinion. That is one reason why I'm changing and getting away from those.
-Drew
__________________
My Useful Threads (38 Entries and Growing)
ExplorerDMB is offline   Reply With Quote
Old 03-17-2005, 12:47 PM   #5
agallant
Boston, MA
2000 XLT
Vehicle Specs
Quoted: 0 Post(s)
Quote:
-Drew
Where did you get it?
-AG
Old 03-17-2005, 04:31 PM   #6
ExplorerDMB
2004 Acura TL
Vehicle Specs
Quoted: 0 Post(s)
It's a special adapter - I got it from a guy off the board, I don't know if you can find them. Good luck. I wuld just purchase the driveshaft from superlift - they'll work just as great.
-Drew
__________________
Old 03-17-2005, 08:37 PM   #7
gavin
Anchorage, Alaska
gavin's Avatar
Vehicle Specs
Quoted: 6 Post(s)
there is another thread floating around here where I posted 2 dif places where you can buy the u-joint style d/s and it comes with the adapter.. around $300 I believe... wether or not that includes a core charge I'm not sure... lemme see if I can find the thread
__________________
1986 Bronco2: RIP
Old 03-17-2005, 08:40 PM   #8
gavin
Anchorage, Alaska
gavin's Avatar
Vehicle Specs
Quoted: 6 Post(s)
http://www.explorerforum.com/forums/...d.php?t=127181
but.. the reply I received from Rockford is that the price I had there was not for the u-joint style I guess.. it's actually around $350 for that one.. but anywhere, there's a couple places to contact.
Quote:
Anybody know anything about 'em? I emailed 'em about a front driveshaft, like 2 days ago and haven't heard a response yet. Wondering if anybody knows anything?
http://www.rockforddriveline.com/convshaftdrawings.htm
Quote:
ok, anybody wanting a conversion front driveshaft for the AWD Sploders, they also have them at http://www.shafts.com for $232
oh, and Rockford has it for $230.31 (if it's the right one)
__________________
1986 Bronco2: RIP
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
