Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Offroad Tech Forums > Offroad Explorer - Ranger Projects > Explorer - Ranger Shocks, Suspensions, Lift Kits
Notices
Explorer - Ranger Shocks, Suspensions, Lift Kits Ford Explorer and Ranger chassis related posts. Get help choosing the right shock absorber and aftermarket suspension for your Explorer or Ranger based vehicle.
Sloped body lift + SOA successful
Reply
Thread Tools
Old 05-22-2005, 04:04 PM   #141
r37ribution
Ypsi/MI Y town! whoot whooot!!!
1996 "Sport" XLT 4.0L OHV
Vehicle Specs
Nick, great idea and awesome truck!
after reading 7 pages, SOA sounds like the way to go. best bang for your buck. I'll probably do the sloped body lift until i can afford to replace the tortion bars. I'm just a little weary about getting the perches lined up properly so my truck doesn't dog-walk. is there any replacment rear end that will bolt up to our trucks from another truck that has the upper perches mounted in the proper place preferably with a 9" rear?
also if anyone has some extra 3" body mounts I got $$$ on it.
thanks aaron
__________________
'96 4.0 OHV6 XLT - RCD 5" coil-over/SOA conversion - Installed - RCD Lift FAQ/IFS Gearbox (F150) conversion - In Progress/Stroked OHV v6 - Aborted/Detroit TrueTrac 4.56 Rear/BamaChips.com XCalibrator/Custom Deaver Leafs/Flowmaster D40
'97 5.0 XLT - Totaled
'97 2.5 Probe GT, 1989 RX7 Turbo II
The newest addition... 2006 Ducati 749s - live to ride!
r37ribution is offline   Reply With Quote
Old 05-22-2005, 06:44 PM   #142
j602
resident douche
Dothan, AL
j602's Avatar
'92 XLT
Vehicle Specs
Getting the perches on right is not that hard. Just have a level handy, and take your time getting them even.
__________________
Josh Loveland
'92 SAS'd Explorer FOR SALE
j602 is offline   Reply With Quote
Old 05-22-2005, 08:24 PM   #143
Nick26
Cumberland, RI
98' 5.0 XLT
Vehicle Specs
(Original Poster)
thanks for the compliments... the perches were the least of my worries, just do them parallel to the lower ones. I read tipping the pinion up and making it mismatch the angle from the transfer case and cause vibrations cause its out of sync. I did it parallel and mines perfectly smooth. I only have like one 3 inch spacer left though after mailing a few off to hokie. technically you could probably bolt up a ranger axle cause they had perches on top but its definitely easier and cheaper to just weld on your own perches.
Nick26 is offline   Reply With Quote
Old 05-22-2005, 08:35 PM   #144
j602
resident douche
Dothan, AL
j602's Avatar
'92 XLT
Vehicle Specs
Yeah I did mine parallel to the old ones and it turned out perfectly. I think moving the perches to rotate the pinion does the same thing as a pinion angle shim.
__________________
Josh Loveland
Old 05-22-2005, 11:27 PM   #145
nissanboy
Winston Salem, NC
97 XLT 4.0 4x4
Vehicle Specs
Ranger rear axles are only 28line and are weaker than the explorer axle... not to mention the spring perches are diffent widths due to spring mounting configurations. The ranger rear is also not as wide as an explorer rearl. So dont use the ranger rear.
__________________
1997 4.0 SOHC 4x4:
____Powertrax Locker_______35x12.50r15 Tires _____BW 1354 Manual__
____Cobra CB_______________3" Body Lift___________KKM Intake kit___
____WAR153 Shackles_______Custom Leaf Packs_____Superior Shift Kit__
Sign up for theR.A.T.E.
nissanboy is offline   Reply With Quote
Old 05-22-2005, 11:44 PM   #146
j602
resident douche
Dothan, AL
j602's Avatar
'92 XLT
Vehicle Specs
WTF are you talking about?
__________________
Josh Loveland
Old 05-23-2005, 01:08 AM   #147
r37ribution
Vehicle Specs
so the swapping the axle idea won't work....was just curious. i have seen a lot of rangers dog-walking down the freeway before like they had a bent frame or misaligned leaf springs, but they are not suppose to be adjustable I thought like our X's. Maybe ranger axle's not fitting is a good thing.
__________________
Old 10-18-2006, 01:42 PM   #148
xplor_off-road
WV
1996 2Dr. Sport
Vehicle Specs
Quote:
Originally Posted by explrig91
o just wondering, that's wat i am doin with mine tho. i got the ranger rear from a junk yard just need to install it. i figure doin a SOA and using the ranger 3inch blocks and combined with my homemade lift up front i am lookin at around 7.5 to 8inches of lift.
I would stay away from the Ranger rear! Unless ya plan on swappin' all the guts out. I'm thinkin' the Ranger only has 27 spline axels where as the Explorers have the heavy duty 31 spline. In any case the weld on perch would be easier to set up than a rear end gear swap! just my .2 tho. anyway good luck
__________________
1996 2dr sport 5spd, 2"tt, 4dr leaf pack, 3"shackels,15x8 ProComp RockCrawlers, Kumho ATs
31.10-50/15, BW1354 t-case swap W/manual shifter.
banged up bumper,smashed finder and a dent in the hood and still wouldn't trade her for a jeep
2006 F-150 FX4 Super Cab 5.4 3V Triton
1968 Chevelle Project car
xplor_off-road is offline   Reply With Quote
Old 07-04-2007, 10:59 PM   #149
Lefy
Westchester, NY
Lefy's Avatar
98 Sport 4x4 4.0 SOHC
Vehicle Specs
I like what I see man good job.. this maybe in the cards for me.
I hate my body lift. and really hate draging my shocks and spring plates on everything.. hmmm
__________________
Aussie Aussie Aussie Ohy Ohy Ohy
My Rig
Lefy is offline   Reply With Quote
Old 07-05-2007, 12:26 AM   #150
r37ribution
Vehicle Specs
sounds like you want a tru lift then...
__________________
Old 07-05-2007, 06:08 AM   #151
sk1er17
My "Jeep Thing" itches...
Jackson,NJ
sk1er17's Avatar
'98 Sport
Vehicle Specs
dayum lefy.. diggin up an old one here aren't ya
that explorer of yours still runs ??
__________________
My Elite Registry.. Check it out
Cardomain Site
Explorers Gone... Went to a Silverado with 8" lift and 37s, then to a 2008 Sierra Denali with 3" lift and 33"s... Now, finally back in an off-road worthy rig...2007 Jeep Commander Hemi QDII (front & rear e-lockers).
Build Thread: Here
sk1er17 is offline   Reply With Quote
Old 07-05-2007, 09:49 AM   #152
Nick26
Cumberland, RI
98' 5.0 XLT
Vehicle Specs
(Original Poster)
Quote:
why spend the money, this is exactly the same if not better and only costs like $200 ($150 for body lift and $50 for perches).
Old 07-17-2007, 10:37 PM   #153
Lefy
Westchester, NY
Lefy's Avatar
Vehicle Specs
yeah my explorer is still rolling round 172k on the odometer. I'm trying to make it hold up till i'm out of college as money is tight. I see you got a chevy now not bad looks good.
__________________
My Rig
Old 08-05-2007, 01:45 PM   #154
Hokie
Hokius Maximus
Denver, CO
Hokie's Avatar
'04 Jeep Grand Cherokee
Vehicle Specs
Another sloped BL member!
I haven't taken it to the full degree. I've got 2" blocks in the rear, tapering upto a 3" block in the front. It sits atleast an inch high in the rear right now.
I've got the cut blocks and correct length bolts in storage for when I do a rear SOA. But for right now I'm running shackles and an AAL in the rear. I'm hoping to get access to a welder and fabrication shop at CSU's engines lab that I'm starting at tomorrow.
One thing I've noticed is that with my rear about 2-3" higher than the front my gas gage seems to be more susceptible to inclines (although at stock height, my Mounty's gas gage has always fluctuated more than my Sport did). More of an annoyance, the only downside I can see is that it reads lower than actual. I'll only put in 16-19 gallons now when it reads low (21 gallon tank).
I need bigger tires, 285's would fit great
__________________
Brett
I get payed to sell and play with Cummins engines
My old '98 MTNR - 5.0 V8 4x4 My old '99 Sport
Hokie is offline   Reply With Quote
Old 08-05-2007, 03:00 PM   #155
MountaineerGreen
Towing Moderator
North East Arkansas
MountaineerGreen's Avatar
2012 F150 4x4
Vehicle Specs
Looks good! Hokie, you need your own thread and maybe some before pictures as well. 285's and 4.10's are just right.
MountaineerGreen is offline   Reply With Quote
Old 08-05-2007, 09:50 PM   #156
dman726749
Mall Crawler
Greenwood Indiana
dman726749's Avatar
96 xlt
Vehicle Specs
bout time you got that thing lifted
__________________
Dustin
96 XLT 2" tt and war shackles, 3" b/l 33" X-Terrains, Custom Snorkel Sold
Dman726749's 96 X!!!
2006 F150 FX4 Super Crew
Indianapolis Indiana Senior Portrait and Wedding Photography
dman726749 is offline   Reply With Quote
Old 08-06-2007, 08:04 PM   #157
Hokie
Hokius Maximus
Denver, CO
Hokie's Avatar
Vehicle Specs
Quote:
Yeah, I'll make a new Elite Mountaineer registry (right now its for my old Sport). I've been busy with the move. Unfortunately, I don't have a picture of it when it was stock. Oh well, it was just a stock Mountaineer with chrome steelies, 29" tires and a 2" sagging rear end.
I'm trying to talk my roommate into putting a 2" budget boost on his '05 Xterra and buying my 265's so I can get 285's. I think that would help my mpg's some right now b/c ever since I regeared I've been getting 15 mpg or less, engine just must be spinning too fast.
That and my speedo/odom is off by 9% (low) right now (which doesn't make sense b/c the larger tires and lower gearing should've countered each other).
I'll have access to a machine shop, welders, WATER JET! and other fun toys so the truck will be getting sliders, front and engine/belly skid plates and maybe the rear SOA.
__________________
Brett
Old 08-06-2007, 08:50 PM   #158
MountaineerGreen
Towing Moderator
North East Arkansas
2012 F150 4x4
Vehicle Specs
Quote:
I had that same thought- but your speed is read at the wheel speed sensor, not at the transmission. So, the gears won't counter the speed issue, the speedo will remain the same no matter what gears you have. You can program your speedo through your ABS module, but you will need a NGS from a stealership to do so. I have corrected my speedo for my 285's.
Old 08-06-2007, 09:52 PM   #159
Hokie
Hokius Maximus
Denver, CO
Hokie's Avatar
Vehicle Specs
I thought the speed is read at the t-case mag pick up sensor? Isn't that why 410Fortune doesn't have a speedo in his '96 with the manual 4406?
__________________
Brett
Old 08-06-2007, 09:59 PM   #160
MountaineerGreen
Towing Moderator
North East Arkansas
2012 F150 4x4
Vehicle Specs
Remember, your AWD T case doesn't have any wires/sensors. 410 did a retro fit of a tone ring to make his speedo work.
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
