Engine firing order question | Ford Explorer Forums
turkey1315
Omaha, NE
94 XLT
I need to identify the number for each cylinder (left & right side) from front to back -- and the cylinder numbers for each port on the distributor from front to back, left & right side.
I want to be sure that I have them connected correctly because my engine appears to be misfiring after a recent spark plug change.
Thanks for any help you can provide!!
Your engine arrangement is
3 6
2 5
1 4
Front of engine
But your coil pack arrangement goes like...
3 5
2 6
1 4
Front of engine
Yes it's weird but alot of times people go 4-5-6 on the right side like the 1-2-3 on the left and it runs like crap.
Later Doug.
Thanks for the reply, but I tried your suggestion and it doesnt seem to work any better, and actually runs worse. Are you sure this is the correct order for a 1994 Explorer XLT V6?
Thanks.
Ed
3 6
2 5
1 4
Front of engine
3 5
2 6
1 4
Front of engine
Later Doug.
The engine arrangement is right, but I believe that you have 4+5 mixed up on the coil.
Yes, Eneurb and Jefe are indeed correct for the OHV engine (which you have).
DOh!! My bad, even I still get it mixed up. I know the right side is different but I got the numbering wrong.
Thanks guys! Doug
No prob... we're just lookin' out for ya!
Just a question 'Runnin' On Empty'. How can both Eneurb and Jefe both be right when the firing orders on the coil are different by each guy? Which one is correct? It would help me out alot! Thanks
Jefe and I have the same coil arrangements in our posts...
my diagram is correct, while Eneurb just stated how to fix Doug904's diagram
SOHC Firing Order
In case anyone's interested, here's the SOHC coil post positions:
5 1
6 2
4 3
Front of engine
The coil pack is flipped around on the SOHC, and this changes the post order from the OHV.
Thanks guys! My mistake!
