- February 8, 2003
- Sacramento, CA 95827
- 1992 XLT
Foreward to this Diary:
I have only been building transmissions now for about 4 years or so. I do not claim to be a pro, expert or genius about this topic. Yet, I have been wrenching for 30 years now and at one time did work for FORD. (Seems like another life). I have built engines, component parts, done A/C, Ignitions, suspensions, etc ...and even have a piece of my metalworking handiwork sitting on another planet. (Another fun story).
I started into auto trannies because of a sense of curiosity.... and what I found on the internet insofar as help for those needing it was concerned made me slightly angry. Those who build transmissions seem to LOVE to impose an air of mystery and mystique about them and try to make folks think only "the chosen few" can actually rebuild them. BULLSH*T. I have even seen folks "pretending" to be helpful pull back their help when it was most sorely needed under the guile of, "Oh well, a valiant try, poor dumb amateur, but now you need to come to ME!"
I know a lot about how automatic transmissions work and how to build them. Yet, I possess no "trade secrets" or "proprietary information" as some foolishly claim to possess. If I discover/learn something along the way.. I will share it - and I am constantly learning. My goal is to see those of you who try ...succeed, not fail and serve as a warning to others (as I see elsewhere.) To assist you, I not only share my knowledge freely, I also loan tools when those are needed. I will steer you to the best buys for parts and help you avoid the scams...I believe that for the ones who have some good automotive skills and want to try - You CAN do it.
Sure, rebuilding an auto transmission is not for someone who can barely change their oil... and in fact probably not for 90% of shade tree mechanics....but I see folks capable of awesome things afraid of auto trannies when they could easily do them. I even see people on other sites who are in the business of AT rebuilding, either as a main profession or a sideline trying to scare folks off from trying to build their own.... feathering their own nests - the same folks who claim to have "trade secrets". GIVE ME A BREAK fer chrissakes. For example - clutch clearance is not a "secret" - "ohh I use .037, instead of .028 to .045." Kill me if you have to tell me.
Also...the amount of material to remove from a clutch piston so you can add extra plates to that clutch and still make it all work, is MATH, not "proprietary information". GET a CLUE guys!
So, I decided to do the Diary series. So far dozens have successfully rebuilt their own automatic transmissions using the Diaries and other reference works, but were inspired here. If you are an advanced amateur, and can pay attention to detail (AT's are all about detail), you can do it.... no matter what "THEY" say. I am here to help. I am not in the automotive trades, nor do you need to be.
I hope my Diary can give you a bird's eye view of the process, and even if you do not decide to "do it yourself", you will have a much better sense of what an automatic transmission is all about. Enjoy.
Glacier
BACK TO WHERE THIS THREAD STARTED:
("Once Upon a Time Long Ago.....")
Alright, there IS a slight tease built in here in that I am a few weeks away from really getting into this. I have slowly been acquiring parts - new pump, new mechanical diode, shells and drums, steels and rebuild kits, brand new valve body, kevlar bands, spiral retainers, new torringtons, new updated accumulator pistons, etc.... so once I get going it will happen pretty fast...
I am starting this thread now for a couple reasons. First, If anyone has ideas they want to throw in, or things they want to know about or see in this rebuild, now is the time to speak up. Secondly, and sadly, I have no use for this trannie once it is built, so if someone wants to have a "build to suit" hi-perf 4R70W this can be your trannie, and I can build it to your specs....
Either way I will try and duplicate or add to what I did with the 4.0 Liter A4LD trannie, only this time with a much more hi perf trannie capable of some significant mods (oh and for the 5.0 V-8 engine). Stay tuned.
ps. those of you that have experience with mod's to this trannie please share with me.
pps. Oh, and...I did previous Diaries sometimes in what was more or less stream of consciousness. Years later when i need to refer someone to something specific, it is a pain. This Diary I am setting up differently. There may in the end be 20 or so separate threads making it up, but it WILL be easier in the future to go to your own particular area of interest. So, on that note...this may be a good place to post and update links to the other threads in this Diary. I'll try and post links at the end of each thread to the next, but maybe ONE place for the whole set would be a good idea... so here goes (this thread will be updated constantly until I have them all in when I finish)
Part 2 -Output Shaft, Ring Gear and Hub (and a discussion of extension housings as well)
http://www.explorerforum.com/forums/showthread.php?t=157283
Part 3 - Torrington bearings and Thrust Washers (including selectives)
http://www.explorerforum.com/forums/showthread.php?t=157376
Part 4 - Servos and Accumulators
http://www.explorerforum.com/forums/showthread.php?t=157428
Part 5 - Direct Drum and Hub
http://www.explorerforum.com/forums/showthread.php?t=157440
Part 6 - Bands (2 of em)
http://www.explorerforum.com/forums/showthread.php?t=157481
Part 7 - Main Planetary and Sun gear
http://www.explorerforum.com/forums/showthread.php?t=157487
Part 8 - Case Support
http://www.explorerforum.com/forums/showthread.php?t=158559
Part 9 - Reverse Shell and Sun Gear
http://www.explorerforum.com/forums/showthread.php?t=158566
Part 10 - Forward Clutch
http://www.explorerforum.com/forums/showthread.php?t=158888
Part 11 - Reverse clutch
http://www.explorerforum.com/forums/showthread.php?t=159597
Part 12 - Transmission assembly up to the Intermediate clutch
http://www.explorerforum.com/forums/showthread.php?t=160569
Part 13 - Intermediate Clutch
http://www.explorerforum.com/forums/showthread.php?t=159423
Part 14 - End Case (pump) Clearance - Selecting the Right Selective
http://www.explorerforum.com/forums/showthread.php?t=160708
Part 15 - Pump Modification & installation
http://www.explorerforum.com/forums/showthread.php?p=1462794#post1462794
Part 16 - Output Shaft Speed Sensor installation
http://www.explorerforum.com/forums/showthread.php?t=161096
Part 17 - Parking Pawl Installation (coming soon)
Part 18- EPC solenoid installation (coming soon)
Part 19 - Shift lever and seal installation (coming soon)
Part 20 Digital transmission range sensor installation (coming soon)
Part 21 - Valve Body - Part 1 - upgrades (In progress)
http://www.explorerforum.com/forums/showthread.php?t=186732
Part 22 - Valve Body- Part 2 - Separator plate and installation (coming soon)
Part 23 - Pan install and button up of transmission. End of Project (in my dreams)
Part 24 - Parts listing with part numbers, cost, and where to buy (coming soon)
Part XX - A Discussion about Friction Material (not sure where it will finally go so for now it is the only double X rated thread on the site!)
http://www.explorerforum.com/forums/showthread.php?t=158669
General Q & A on this Diary: http://www.explorerforum.com/forums//showthread.php?t=161450
Changes to the 4R70W in 2004: http://www.explorerforum.com/forums/showthread.php?t=188119
Glacier
