| EF Swag Store | 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Modified Explorations!! Closed to new posts. Place new posts in our new model year appropriate forum |
Thread Tools |
#1 |
A Man Without Wheels
Houston, Texas
98 Eddie Bauer (R.I.P.)
I have an interesting mod. Floor shifter in automatic Explorers. Would it work?
I am always thinking of ways to make an Explorer easier and prettier, LOL. But while driving the 03 Taurus that we have, I started thinking about the floor shifter. It has a nice console with a real nice shifter and looks about like an Explorer has, of course without the shifter. So that takes me to a question,
Can a floor shifter from say a Taurus be installed on an Explorer? This of course if for the automatics only, not standard shifts. |
#2 |
Wannabe Elite Explorer
Ann Arbor, Michigan
96 Explorer Limited
Check Out this link....click
__________________
#3 | |
I'm Awesome!
Home is where the Army tells me. Right now it's Manorville, NY
Quote:
It could be done I'm sure it would take some creativity though. All that is connected to the shifter is a cable that goes down to the transmission. The hardest part about a floor shifter would be getting the cable to work and getting all the detents for the different gears set right. |
#4 |
ELITE BRONCO2ERER
Crawlorado
B2 Mod
You could try to use any cable floor or console mounted shifter you can find.
Any AOD floor shifter (aftermarket) can be made to work with the 4r70w, also there are shifters available for the A4LD. I basically had a 93 Explorer automatic trans in my truck and I used a 86 BII, 2wd floor shifter and bell crank assembly (not cable shift, solid linkage). Now I am converting to the 4r70W (AOD-E-W) and I will be using an Art Carr console shifter mounted to a base built into my center console, this one is cable shift just like the stock column shifter. Also when you do go floor shifter you can easily swap over the instrument cluster and column from a 5 speed truck to get rid oft he shift indicator and column shifter. The OD buttong requires some simple wiring as well (two wires from computer, one is OD on/off, the other is the OD light) __________________ 96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's 88 BII 5.0L conversion - BII 5.0l drivetrain thread My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates Wifes 07 FJ build - 2007 FJ cruiser locked and lifted |
#5 |
Music City, USA
98 xl
Like the ones in the UK???
__________________ ![]() "LUCK FAVORS THE WELL PREPARED"
#6 |
Houston, Texas
You mean the Explorers in the UK with automatic transmissions have a floor shifter?
#7 |
Explorer-less
South Hampton, NH
2002 Sentra SE-R Spec V
I think that would be sweet. Might have to do some research on this...
#8 | |
Houston, Texas
Quote:
#9 |
ELITE BRONCO2ERER
Crawlorado
B2 Mod
Yeah except its designed to be used from the pass side.
#10 |
Explorer-less
South Hampton, NH
I would love to do this, as long as it doesn't cost an arm and a leg to do so. The UK explorers do have the floor shift for the automatics, but as 410 said they are designed to be used from the opposite side. Gotta get some of the UK guys in on this one.
#11 |
Giddy up!
Oakland County, MI
97 Mountaineer
It should be a plunger style shift neck button which would allow you to invert the handle or use pretty much any other replacement Ford shifter knob.
or you could just do this and problem is solved
__________________ “Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, pork rhines in one hand, bottle of jack in the other, body thoroughly used up, totally worn out and screaming “WOO HOO what a ride!” |
#12 |
Johnstown, PA
1994 Explorer XLT
I think the UK version uses a Taurus shifter.
Would this work for the 4R70W too?
__________________ 1994 Explorer XLT | M5R1 swap | 2" Lift | 32" ProComp Mud Terrains 2006 Saab 9-3 Aero | 2.8 Full pressure turbo | 6MT | 280whp/325wtq |
#13 |
ELITE BRONCO2ERER
Crawlorado
B2 Mod
but the gear display is on the wrong side
#14 |
Explorer-less
South Hampton, NH
minor details, Jamie :p
#15 |
Houston, Texas
Very minor. If we could find one, then see what modifications it would need. You know how many people with Explorers would want to change theres to a floor shift with a console?
I will take a picture of the console of my Taurus when it get's home. I would bet it is the same as needed for an Explorer. But I don't know what transmission it has. I am just a drive it kind of guy. If I could do something like this to an XLT or Sport, then I wouldn't mind not having an Eddie Bauer or Limited. |
#16 |
Duluth, MN
'99 Sport
I remember this being discussed before on this site. I sure would do it if someone figured it out.
__________________ '99 Explorer Sport 5.0 AWD t-case with 2wd spindles (identity crisis) '99 Explorer XLT 4.0 SOHC 4x4 for daily driver/off road use |
#17 |
I fix dents
Millersville , Maryland
2000 Explorer Sport
Seems to me it is quite possible.
Some work involved but that is the case with any mod of this extent. __________________ MONMIX Wheels and intake for sale Live your life for a change My Explorer CHURCH.... sort of |
#18 |
ELITE BRONCO2ERER
Crawlorado
B2 Mod
oh this is easily possible, but why go overseas when there are high quality good looking aftermarket shifters right here?
keep in mind while looking at other Ford shifters that just because it goes P N R D 2 1 Doesnt mean it has the same throw for the shift lever, meaning it may not pull or push the cable far enough for the trans. __________________ 96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's 88 BII 5.0L conversion - BII 5.0l drivetrain thread My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates Wifes 07 FJ build - 2007 FJ cruiser locked and lifted |
#19 |
Duluth, MN
'99 Sport
Here is the previous discussion I saw a while back.
#20 |
I fix dents
2000 Explorer Sport
I am sure you will keep us in the loop with what you learn BBQ
| Thread Tools | |
