Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Modified Explorations!!
Notices
Modified Explorations!! Closed to new posts. Place new posts in our new model year appropriate forum
LED rear turn signal bulbs??? Help needed
Thread Tools
Old 03-19-2005, 07:32 PM   #1
mattscherrygt
Lancaster, Pa
N/A
Vehicle Specs
(Original Poster)
Hey all,
I just purchased "Redline" model number 3156 (I believe..don't have them with me right now) LED bulbs which were supposed to be direct replacement for the stock rear turn signal bulbs in my '97 Explorer. To make the story short, the bulbs worked fine when my four-ways are on, but when I put either turn signal on, the flash was extremely fast, EXACTLY as if the bulb would be broken or something (as if your stock bulb would burn out, then cause your turn signal to flash faster). Anyways, I can't figure out why this is happening. Again, the four ways work great (meaning, regular flash pattern and speed), but when either turn signal is put on, the flash gets too fast. I tried putting the stock bulbs back in, and the flash resumes to normal speed, so the problem definitely is limited to the LED... Oh yeah, I have the LED's in correctly too, as there is only one way to put them in (the other way they won't even function at all)
Any help would be greatly appreciated!! Thanks a lot all.
Matt
mattscherrygt is offline
Old 03-19-2005, 08:04 PM   #2
huskyfan23
Rah no Hans Bwix
WA
huskyfan23's Avatar
1994 XLT 4x4
Vehicle Specs
You need to add a load resistor.
__________________
1994 Explorer XLT
My registry entry: here
Diamond Everything w/ HID Bi-Xenon Projectors
I'm no doctor, but I am a self-proclaimed genius. There's no reason not to trust me.
What kind of dessert causes women to gain the most weight? Wedding cake
huskyfan23 is offline
Old 03-19-2005, 08:19 PM   #3
mattscherrygt
Lancaster, Pa
N/A
Vehicle Specs
(Original Poster)
Quote:
Thanks for your response. Are you sure this will work, or is it an assumption? Where can I get one/ how much? Thanks for your help once again. Take it easy.
Matt
Old 03-19-2005, 08:21 PM   #4
huskyfan23
Rah no Hans Bwix
WA
huskyfan23's Avatar
1994 XLT 4x4
Vehicle Specs
Yes, I'm positive. There are other threads about it, run a search. I'm not sure what ohm rating you need. You can get them at Radio Shack.
__________________
1994 Explorer XLT
Old 03-19-2005, 08:39 PM   #5
mattscherrygt
Lancaster, Pa
N/A
Vehicle Specs
(Original Poster)
Thanks a lot man. I was just thinking of taking them back, but I will check into this first. I really want the LED look, so it will be worth it. Any other info would be great from any others with specifics, but thanks again Husky.
Matt
Old 03-19-2005, 09:07 PM   #6
DirtyDog
I will not!
Lethbridge,Alberta,Canada
DirtyDog's Avatar
04 Aviator
Vehicle Specs
I just let mine flash fast. I like it better that way and I think it's more noticable
__________________
04 Aviator
06 F-150 Lariat
99 F-150 XLT[/B]
DirtyDog is offline
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
