Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Modified 1995-2001 Explorers
Notices
Modified 1995-2001 Explorers Questions related to modified 1995-2001 Explorer, Mountaineer, Ranger and 2002+ Sports (2dr). Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, torsion twist, lift kits, engine swap, transmission swap.
White Face Instrument Cluster Install on a 99
Reply
Thread Tools
Old 02-19-2009, 08:59 PM   #41
aldive
Elite In Memoriam
aldive's Avatar
1999 XLT
Vehicle Specs
(Original Poster)
Mine functions perfectly but is not very bright.
__________________
Al Franklin
My truck
My Quest for 30
RIP Al Franklin! 1947-2010. Gone but not forgotten! :(
aldive is offline   Reply With Quote
Old 02-20-2009, 11:49 AM   #42
Joe Dirt
Living in Greenland
Holland, MI
Joe Dirt's Avatar
'00 V8 XLT
Vehicle Specs
Al (and others) did you use the backing housing from your old cluster or the new one? Mine is very bright- just as it is in the pics... I think the clear plastic that the gauge faces mount on was different on the '95 and the '01- because the clear diffusers have to carry the light differently to the gauges maybe? I used the rear backing housing (casing) from the '95 and the white faces and clear things that they stick onto from the '01. May be something different in how the lights work and carry through.
I found my cluster at the junkyard...
The cluster wiring and light locations are different, you have to repin some of the wires- you'll have to look at the old cluster and see where the wire tape meets the connector, and relocate those wires to the new cluster locations.
__________________
Quote:
Originally Posted by FIND View Post
Also, every time you use an apostrophe for a plural, Jesus kills a kitten.
My registry
Joe Dirt is offline   Reply With Quote
Old 02-20-2009, 12:06 PM   #43
muhl5443
Minnesota
muhl5443's Avatar
'98 XLT
Vehicle Specs
i used everything that i got with mine at the junkyard.
__________________
'98 xlt 4.0 sohc
31" bf goodrich all terrain t/a tires
2" TT
REAR SHACKLES
message center mod
vent visors & bug deflector
muhl5443 is offline   Reply With Quote
Old 02-20-2009, 12:19 PM   #44
SVTmountianeer
miami fl
97 mountianeer v8
Vehicle Specs
now knowing how simple the swap is im going to do it so it could match my nv aotumeters
SVTmountianeer is offline   Reply With Quote
Old 07-23-2009, 09:43 AM   #45
Marcus Aurelius
Toms River, NJ
Marcus Aurelius's Avatar
2001 XLT
Vehicle Specs
I know this thread is kind of old, but I am planning on doing the white face gauges. Does anyone know if they just sell the white face so I don't have to deal with many wires and install a whole new set of gauges?
-Marc
Marcus Aurelius is offline   Reply With Quote
Old 07-23-2009, 09:56 AM   #46
celly
disturber of the peace
calgary
celly's Avatar
99 eb 5.0 awd
Vehicle Specs
Quote:
-Marc
There are aftermarket options available, but quality and appearance vary wildly. I'd check eBay for those.
You won't find Ford OEM as white faced gauge overlays alone. They're of much higher quality that the aftermarket stuff, IMHO. Keep in mind that simply swapping out the overlays can be a bit of a project in itself because you've got to pull the needles off and then recalibrate them. Make sure you do your homework. It's not hard to do, but I found out the hard way as my tach and speed were off by a wide margin after the swap. They're perfect now, but it took a lot of trial and error to get them right.
__________________
'99 EB
5.0 AWD, Torque Monster Headers, 1" Trick Flow UI spacer,
Custom Volant based CAI (incl C&L MAF body),
SCT XC2 w/Henson tunes, Flo Pro catback, EE swaybar & airdam, Morimoto HID projector retrofit (4300K), Bilstein shocks, Powdercoating by Turdle, Amsoil everywhere, other stuff.
Quote:
I didnt even waste my time to read that, nor will I, however I read some of it.
I, I, I, Me! Me! Me!,
Craigslist Scams for Dummies, Don't Be a Wannabe.
celly is offline   Reply With Quote
Old 07-23-2009, 10:17 AM   #47
01EB5.0
Allendale, MI
01EB5.0's Avatar
2001 Eddie Bauer V-8 AWD
Vehicle Specs
i just bought a new gauge cluster from the boneyard for $22. Will indstall today.
i used to have the Ebay gauge overlays I installed them without removing any needles but it took a lot of patience. Over the l;ast few years the overlay thats under my tach started to pucker up in the cold and now the tach hardly moves anymore. thats why i decided to just do it right...lol
__________________
2001 Eddie Bauer 5.0L V-8 AWD 152,000 miles...K&N drop-in...P275/70R16 Dueler A/T REVO (second set..first ones lasted 98,000 miles! ), OME rear suspension, TT in front, aletzzas, white gauges, painted interior
01EB5.0 is offline   Reply With Quote
Old 07-23-2009, 10:24 AM   #48
celly
calgary
celly's Avatar
99 eb 5.0 awd
Vehicle Specs
Quote:
How do you get them by the needles?
I popped off the needles with a salad fork (a tip I picked up off the forums) and re-calibrated using the speed and tach readings on my Scangauge. The other needles were eyeballed using a photo I took before the install.
The speed and tach are bank on compared to Scangauge and speed is also bank on vis a vis GPS. I know speed is right because a trooper in North Dakota got me doing 82 in a 70 recently and I was doing 82 as per my GPS as well.
__________________
'99 EB
Old 12-03-2009, 02:33 PM   #49
greg2427
milan, nh
98 ford ranger xlt 2wd
Vehicle Specs
I have a 98 Ranger with no tach and got a cluster from a 97 Explorer with a tach but after installing the cluster in my Ranger it stopped charging. Where did I go wrong? What can I do to fix that??
greg2427 is offline   Reply With Quote
Old 12-03-2009, 04:04 PM   #50
DrthTater
Thomasville, NC
1995 Explorer
Vehicle Specs
Wow. Those all look great, guys. Perhaps that's something I'll do to mine.
DrthTater is offline   Reply With Quote
Old 12-05-2009, 10:03 PM   #51
Bill Kemp
Elite Moderator Emeritus
Greenville, MI
Bill Kemp's Avatar
98 Mountaineer 5.0 AWD
Vehicle Specs
Here is some info that might help.
http://www.therangerstation.com/foru...ad.php?t=45192
__________________
Bill Kemp
Mods to come.....
07 Lincoln MKX
Clones are people two.
Bill Kemp is offline   Reply With Quote
Old 01-09-2010, 09:34 PM   #52
Buyford
Frankford, Ontario
Buyford's Avatar
'98 ''Limited'' 4x4
Vehicle Specs
I want whiteface gauges for my 98 explorer and was looking at the instrument cluster of a 04 sportrac, its was perfect but i called the Ford dealer(parts) and he said that the wireing was different, so where now(e bay) and i live in Ontario. Thanks in advance.
Bill (Buyford)
Buyford is offline   Reply With Quote
Old 01-10-2010, 01:32 PM   #53
muhl5443
Minnesota
muhl5443's Avatar
'98 XLT
Vehicle Specs
i have the white gauges out of a 04 sport trac and dont have a problem with em in my 98 xlt
__________________
'98 xlt 4.0 sohc
2" TT
REAR SHACKLES
message center mod
Old 01-10-2010, 01:43 PM   #54
Buyford
Frankford, Ontario
Buyford's Avatar
'98 ''Limited'' 4x4
Vehicle Specs
Hey muhl, thanks, are the plugs/wiring the same 4 both the '04 and the 98?, the Ford dealer(parts) said that the wiring is different and wont work.
Old 01-10-2010, 11:00 PM   #55
mic98xlt
West Haven, Ct.
98 XLT
Vehicle Specs
I too have the white face gauges from a 2003 sport trac in my 98 xlt. There is no major wiring differences (minor ones) and it will work. They are not wired exactly identical but they work just fine. Don't worry about what the Ford dealer says, technically they are right but in reality it's works. This is a great upgrade mod. One of my best mods for my X.
mic98xlt is offline   Reply With Quote
Old 01-11-2010, 06:31 AM   #56
Buyford
Frankford, Ontario
Buyford's Avatar
'98 ''Limited'' 4x4
Vehicle Specs
cool thanks mic98xlt, what do i have to do for wiring?..i love the whiteface gauges.
Thanks in advance Bill
Old 01-11-2010, 10:11 AM   #57
muhl5443
Minnesota
muhl5443's Avatar
'98 XLT
Vehicle Specs
the wirimg is alil different but they will work. as long as the back of the instrument cluster has 3 holes for wiring connectors and the harnesses in ur truck fit in them you will be fine.
__________________
'98 xlt 4.0 sohc
2" TT
REAR SHACKLES
message center mod
Old 01-11-2010, 12:58 PM   #58
syn-
orlando, fl
96 xlt - wip
Vehicle Specs
Just a heads up I did a how to, on converting this cluster to 96 and below. Not sure how below (anything 2nd gen should be right). http://www.explorerforum.com/forums/...56#post2252656 I too enjoi them, wish they were brighter as day light is still present, but at night they make up for it.
syn- is offline   Reply With Quote
Old 01-11-2010, 04:53 PM   #59
mic98xlt
West Haven, Ct.
98 XLT
Vehicle Specs
Quote:
Muhl is 100 percent correct. They're just plug and play after the connectors fit. Your 98 X will work without rewiring.
Old 01-11-2010, 06:03 PM   #60
Buyford
Frankford, Ontario
Buyford's Avatar
'98 ''Limited'' 4x4
Vehicle Specs
cool thanks guys
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
