Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Modified 1995-2001 Explorers
Notices
Modified 1995-2001 Explorers Questions related to modified 1995-2001 Explorer, Mountaineer, Ranger and 2002+ Sports (2dr). Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, torsion twist, lift kits, engine swap, transmission swap.
White Face Instrument Cluster Install on a 99
Reply
Thread Tools
Old 05-20-2011, 12:28 PM   #61
mengjin89
pa
1999 eddie beauer
Vehicle Specs
Quote:
Originally Posted by muhl5443 View Post
i dont think it is a characteristic of them i did mine over a year ago and mine arent dim at all. my only problem is that ever since i swapped mine my theft light hasnt worked.
I have same problem for anti theft light, did u correct it?
mengjin89 is offline   Reply With Quote
Old 05-20-2011, 04:25 PM   #62
Stew1138
Fort Walton Beach, Florida
1995 XLT
Vehicle Specs
just did this swap
i just did this swap in my 95 exploder and i have to say its one of the easier projects I've ever done. i found the 2003 sport trac cluster on ebay for $50. All the idiot lights and gauges work, theres only one or two slight problems. first off anytime a doors is open, the fuel reset light comes on. second, the temp gauge need some custom recalibration. so i popped it off with a fork and stuck it back on where i thought it should be. well, the gauge still thought it was running hot so i removed the "check gauge" light bulb that kept illuminating. all in all very easy and painless.
Stew1138 is offline   Reply With Quote
Old 05-20-2011, 06:36 PM   #63
Fordtrucks
Rapid City SD
2001 XLT AWD 5.0
Vehicle Specs
Am i correct to assume that the sport and sport track clusters wont wonk in a V8 X due to the tach?
Ide like the white cluster but ive got the 5.0
__________________
Real men drive big block Ford trucks!
2001 Explorer XLT AWD 5.0, 3 inches and 31" KM2s.
93 F150 4x4 ex cab short box. 9 inches, 40s, 460, 4 speed.
Fordtrucks is offline   Reply With Quote
Old 05-20-2011, 07:35 PM   #64
boominXplorer
Virginia Beach, Va
boominXplorer's Avatar
00 4x4 Mounty
Vehicle Specs
I had one in my 00 v8 and its in my 98 v8 now. Works with no problems at all. Just make sure you get a 2wd one so you don't see the spots for 4x4 high and 4x4 low but either way it works so it really doesn't matter.
Mine is from a 4x4 but I used the 4x4 lights with my manual 4406 swap in my 00 by wiring into the GEM. That way I would know if I accidentally bumped it into 4x4 high (did that once and didn't notice for a day or 2)
__________________
1998 Mountaineer 5.0 2wd - Mac intake, Ported intake, FMS headers, 3" Exhaust, E-fan, SCT tuned, Baumenn Shift Kit, MSD, 4.10 l/s, Lowered 3/2 on 18x9 Cobra r's, HID's
2002 F250 Crew Cab SB 7.3 Diesel 4x4 - 4" MBRP exhaust, AIH delete, SCT Livewire
2001 Ranger ext cab 4x4 - 5.0/4r70/4406 swap in progress
(2) 97 Mountaineers for parts
98 Sport for Parts My eBay auctions
boominXplorer is online now   Reply With Quote
Old 05-20-2011, 08:28 PM   #65
Fordtrucks
Rapid City SD
2001 XLT AWD 5.0
Vehicle Specs
Perfect, thanks!
__________________
Old 05-21-2011, 05:45 PM   #66
Joe Dirt
Living in Greenland
Holland, MI
Joe Dirt's Avatar
'00 V8 XLT
Vehicle Specs
Stew- if you swap the temp gauge from your '95 cluster into the new one, it will work fine. Oherwise, they peg. There are two gauges on the '95 cluster that have external resistors on the back of them. One was the temp, I can't for the life of me remember the other. But, if you pop the needles off, unscrew the 2 offending gauges off the '95 cluster, then remount to the new cluster and use the new needles, all will be fine.
__________________
Quote:
Originally Posted by FIND View Post
Also, every time you use an apostrophe for a plural, Jesus kills a kitten.
My registry
Joe Dirt is offline   Reply With Quote
Old 05-23-2011, 11:01 AM   #67
celly
disturber of the peace
calgary
celly's Avatar
99 eb 5.0 awd
Vehicle Specs
Quote:
What he said.
__________________
'99 EB
5.0 AWD, Torque Monster Headers, 1" Trick Flow UI spacer,
Custom Volant based CAI (incl C&L MAF body),
SCT XC2 w/Henson tunes, Flo Pro catback, EE swaybar & airdam, Morimoto HID projector retrofit (4300K), Bilstein shocks, Powdercoating by Turdle, Amsoil everywhere, other stuff.
Quote:
I didnt even waste my time to read that, nor will I, however I read some of it.
I, I, I, Me! Me! Me!,
Craigslist Scams for Dummies, Don't Be a Wannabe.
celly is offline   Reply With Quote
Old 05-23-2011, 01:33 PM   #68
Joe Dirt
Living in Greenland
Holland, MI
Joe Dirt's Avatar
'00 V8 XLT
Vehicle Specs
I just grabbed one of each (2wd and 4wd) at the junkyard this past weekend. They'll be up for grabs tonight...
__________________
My registry
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
