Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
Rough idle / FLASHING check engine light?!? PLEASE HELP
Reply
Thread Tools
Old 04-04-2005, 08:53 PM   #1
Hpnotiq
teaneck, nj
99 xlt
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
**** sorry for the long story, just want to give as much detail is possible, thank you ****
Hey i have a 99 explorer and this morning i work up and my car was idling and running REALLY rough (prior to this i have had the check engine light on as long as i could rememer... code said my car is running 2 rich or sumthing, never got the time to check it out and recently it sounds like a small hole has developed on my headers) So i wake up go 2 turn the car on and like i said its running really rough. Drove away and at like 2000-2500 rpm the engine sputters alot, after that it runs really sluggish and with lots of noise coming from the engine (the hole in the header sound got ALOT louder and the engine sounds like its sputtering just not as much) and i could also smell fuel. while driving to work i try and see if i can accletate the car hard to see what would happen and my check engine light started flashing for the first time. when i got 2 my job i checked out the engine to see if i could see anything and i realized that a black rubber jose has come off on the right side of the engine (dont know what it does but its a short line, there are 2 of them that run from a black small plastic sensor looking thing to a small metal pipe where the 2 hoses go, looks like a fuel line i guess) i put that hose back on and drove the car around, still sputters just not as much and the car is VERY sluggish when u step on it (its sounds like its being restricted) plleeaasssee help im lost as to what it could be... i know nothing about cars but its sounds like a spark plug / spark plug wire falfunction.
Hpnotiq is offline   Reply With Quote
( Join the Elite Explorers )
Old 04-04-2005, 09:00 PM   #2
section525
sextion525
Red Bluff, Ca
section525's Avatar
1975 Ford Bronco 4x4
Vehicle Specs
Quoted: 22 Post(s)
That's what I was going to say. Sounds like a plug or wire is bad. Maybe even a coil pack. Is this a V6 or V8?
__________________
Support the Forum
'13 3.5 Explorer
'75 5.0 Bronco
'04 6.0 Super Duty
section525 is offline   Reply With Quote
Old 04-04-2005, 09:55 PM   #3
Hpnotiq
teaneck, nj
99 xlt
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
v6
Old 04-04-2005, 11:55 PM   #4
monkeydude3
Millbrook, Illinois
2001 Explorer Sport Trac
Vehicle Specs
Quoted: 0 Post(s)
which v6? OHV or OHC?
__________________
Live each day as if it's your last.
monkeydude3 is offline   Reply With Quote
Old 04-05-2005, 12:06 AM   #5
Hpnotiq
teaneck, nj
99 xlt
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
dont exactly know i think its the worst of the 2
Old 04-05-2005, 12:28 AM   #6
snoborder42
Maple Valley/Downtown Seattle, Washington
92 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
it could be a bunch of things, i am leaning towards a bad oxygen sensor especially if you are getting error codes that said it was running rich. Could also be plugs and wires too like section525 said.
__________________
My Ride:
1992 XLT 4x4 5-Speed, K&N Filter, Flowmaster 40 Series, Panasonic Headunit, Silverstars, Bridgestone Revos
RIP:
1993 "Old Blue" XLT 4x2
snoborder42 is offline   Reply With Quote
Old 04-05-2005, 12:32 AM   #7
section525
sextion525
Red Bluff, Ca
section525's Avatar
Vehicle Specs
Quoted: 22 Post(s)
My check engine light just came on. It ended up being plugs 5,6,7 & 8 were nearly blown out of the head. Too much hot-roddin'. Check to make sure all the plugs are in tight and that all the wires are securely on the plugs. It could be an easy, cheap fix. Or, it could be an o2 sensor. Had that happen too. :p
__________________
Support the Forum
'13 3.5 Explorer
'75 5.0 Bronco
'04 6.0 Super Duty
Old 04-05-2005, 02:50 PM   #8
TPLYNCH
Brewster, NY
1999 XLS
Vehicle Specs
Quoted: 0 Post(s)
The hose that was disconnected sounds like the DPFE and EGR hose. If you are having trouble with the DPFE your truck will run like S**t. Run search for DPFE....
__________________
Tom Lynch
'99 XLS
4 wonderful very used (80K miles) but still like new Michelin XC LT4 tires
"Forget world peace. Visualize using your turn signal."
TPLYNCH is offline   Reply With Quote
Old 04-05-2005, 03:03 PM   #9
TheJMan
Scottsdale, AZ
TheJMan's Avatar
2009 Mazda 3 Hatchback
Vehicle Specs
Quoted: 0 Post(s)
If I remember correctly, my owner's manual states that a flashing check engine light is caused by an engine misfire, potentially resulting in excessive exhaust temperature. I recommend changing all of the spark plugs and wires to see if that solves the problem. It could be something as simple as a plug wire touching the exhaust manifold and burned through. Good luck.
__________________
2009 Mazda 3 Hatchback - Bone Stock
TheJMan is offline   Reply With Quote
Old 04-05-2005, 03:43 PM   #10
KPT
NC
'95 XL 4x4
Vehicle Specs
Quoted: 0 Post(s)
The only time I've seen a check engine light flash is for a misfire code. Get the codes pulled ASAP..........
KPT is offline   Reply With Quote
Old 04-06-2005, 11:02 AM   #11
Hpnotiq
teaneck, nj
99 xlt
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
i got it fixed thanx, it was a combo of the bad hose and a spark plug that had about a 1/4 inch gap between the to parts that spark (dunno exactly wut they are called) its running ALOT better and best of all, for the first time, i dont have a check engine light on =P thanx everybody
Old 04-06-2005, 05:39 PM   #12
Eneurb
Ajax, Ontario, Canada
1998 Limited
Vehicle Specs
Quoted: 0 Post(s)
Quote:
A flashing check engine light means that there is a misfire that has the potential to cause raw fuel to enter the convertors causing them to fail. In most cases you can drive with a check engine light on solid, but disregarding a flashing one can cost lots of money down the road.
__________________
I'd rather have a full bottle in front of me, than a full frontal lobotomy.
Eneurb is offline   Reply With Quote
Old 04-06-2005, 07:45 PM   #13
Hpnotiq
teaneck, nj
99 xlt
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
thanx, ok so now everything is good..... but today i just noticed my 4x4 hi and 4x4 low lights flash on the dash... anybody know wuts up with that? (i know that if the switched isent plugged in that it will do that... the switch is plugged in)
Old 04-06-2005, 08:52 PM   #14
nascar_intimid
st.catharines,ontario
nascar_intimid's Avatar
'94 eddie ..'02 limited
Vehicle Specs
Quoted: 0 Post(s)
Quote:
try the search option first you will get lots of ideas and fixes...take the time to SEARCH...good luck
__________________
Looking back, Knowing that you gave it your all....Win or loose, you finish a champion.
Dale Earnhardt (nascar_intimidator7x)
nascar_intimid is offline   Reply With Quote
Old 04-06-2005, 11:16 PM   #15
Hpnotiq
teaneck, nj
99 xlt
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Or u cant just not b a dick since we were already on the topic and help me out, thanx
Old 04-21-2005, 10:45 AM   #16
tmh6202
Lincoln Park MI
1998 Explorer Sport 2dr.
Vehicle Specs
Quoted: 0 Post(s)
Dude,
It is way uncool to dis someone trying to help you out. If you are like that, good luck getting help from anyone on this board.
tmh6202 is offline   Reply With Quote
Old 04-21-2005, 10:28 PM   #17
buckeyebob
Palm Bay Florida
1994 Lt
Vehicle Specs
Quoted: 0 Post(s)
Can any one help me? problem with under hood light, tach, idiot lights and 4x4 buttons dont work either just bought it cant tell if they ever worked
buckeyebob is offline   Reply With Quote
Old 04-21-2005, 10:36 PM   #18
buckeyebob
Palm Bay Florida
1994 Lt
Vehicle Specs
Quoted: 0 Post(s)
Can any one help me? problem with under hood light, tach, idiot lights and 4x4 buttons dont work either just bought it cant tell if they ever worked fuses ok nothing lights with key on key switch seem a little loose alarm stays on after keys removed and lights are off............
Old 04-21-2005, 10:57 PM   #19
xploded
Grapevine, TX
xploded's Avatar
93xlt 2wd
Vehicle Specs
Quoted: 0 Post(s)
maybe your guage cluster isn't plugged in?? Does the cluster light up when you turn on the headlights? If it does, then scrap my idea...
__________________
For Sale!!!!! Info on my website.
http://www.cardomain.com/ride/2440147
1993/2000 Ford Explorer Prerunner
The baddest in AZ???
(Just moved to Texas...)
Best 1/8th: 10.666@63.52
xploded is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
