| Explorer4x4 | Sportrucks | EF Arcade | Forums | Elite Membership | Product Reviews | Explorer Photo Gallery |
| Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Millbrook, Illinois
2001 Explorer Sport Trac
Will carbon buildup cause my turbulence?
Hello all~
I have a 1994 XL, 4.0L OHV 4X2 and manual transmission. It has 137k miles on it, and only 7k on the rebuilt transmission. New clutch line, clutch slave cylinder and complete clutch assy. My problems are unusually high idle when warm (900rpm, sometimes more) and when I start it up after letting it sit having been fully warmed up, it will chug like it has a high end cam in it, and when I hit the gas a few times it goes away. Also when it's recently been started, I hear a sort of popping/spitting sound in the exhaust that goes away as I run it a bit. I'm thinking I have a pretty decent carbon buildup on the inside of my engine, and am considering some seafoam. Would carbon buildup cause these things? what's been done: new plugs and wires new fuel injectors (motorcraft) new IAC new DPFE new EGR valve, solenoid and tube new 02 sensors New upper and lower intake gaskets (and valve cover gaskets) new air intake temp sensor (one in the manifold) new coolant temp sensor (for the ECU) new radiator, with fresh coolant flush and fresh coolant new fuel filter new fuel pressure regulator By all accounts this sucker should be running near perfect, but my luck prevails, and it does not! Oh well, any ideas, let me know George *Confused and aggrevated* __________________ Live each day as if it's your last. |
| Sponsored Links (Less Ads) |
#2 |
Charlotte, NC
'92 Sport 4x4
have you tried a different gas grade?
#3 |
Millbrook, Illinois
no, I run regular, and at the price, it's all I can really afford. Will running mid grade or higher help my situatioN?
#4 |
Charlotte, NC
'92 Sport 4x4
probably not, but it doesnt sound like your problem is really that abnormal anyway. 900 rpm isnt that high for idle, 750 is ideal... 900 aint that far off.
that popping/spitting i dont know what to tell you |
#5 |
Sykesville, MD
'00 XLS, '03 Sport
It wouldn't hurt to try seafoam.
__________________ Full of ideas, short on execution. 2000 XLS, 4DR, 4x4, OHV, Manual Mobil 1 & Amsoil Synthetic Fluids, 2WD switch Brown wire mod, KKM air intake, overhead console, lighted sunvisors, custom 2nd HU install, '03 Ranger Fog lights, Hurst short-shifter, 75MM MAF, BBK 66MM Throttle Body My 2000 Explorer |
#6 |
Millbrook, Illinois
The main concern is that as it gets warmer it idles faster... I don't get it. And it is NOT OVERHEATING either.. ::sigh:: I'm gettin rid of it soon anyhoo to get a 4 banger (gas prices killing me). It's near mint condition otherwise. Ice cold a/c, solid trans etc.... Anyone in the IL area who would be interested let me know
George __________________ Live each day as if it's your last. |
| Thread Tools | |
