Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > General Explorations!!
Notices
General Explorations!! Closed to new posts. Place new posts in our new model year appropriate forum
Brakes grab when it's wet outside
Thread Tools
Old 04-09-2005, 08:27 AM   #1
rocco123
Endicott, NY
rocco123's Avatar
1994 XLT & 2002 Limited
Vehicle Specs
Quoted: 25 Post(s)
(Original Poster)
I've hadthis problem for over a year. When it's raining outside, and my explorer is in the garage (or parked outside) my brakes will grab. This only happens until it's driven for a little while. I have replaced the front pads and changed all of the brake fluid, & it hasn't helped. It seems like the front brakes are what grab and cause a sudden stop.
I don't understand it. This happens during first brake applications even after it's been in the garage. What could cause it? Brake booster?
Rear shoes have plenty of material left.
rocco123 is offline
( Join the Elite Explorers )
Old 04-09-2005, 09:02 AM   #2
nascar_intimid
st.catharines,ontario
nascar_intimid's Avatar
'94 eddie ..'02 limited
Vehicle Specs
Quoted: 0 Post(s)
mine does it too. I tread lightly on the first brake application when wet then it's o.k. My GMC Safari did it too. Just the rotors being wet is all. I know it shouldn't do it but ...whatever.
__________________
Looking back, Knowing that you gave it your all....Win or loose, you finish a champion.
Dale Earnhardt (nascar_intimidator7x)
nascar_intimid is offline
Old 04-09-2005, 09:36 AM   #3
rocco123
Endicott, NY
rocco123's Avatar
Vehicle Specs
Quoted: 25 Post(s)
(Original Poster)
I can understand that the rotors would be wet, but if I simply pull the thing to the top of my 50 ft long driveway from pulling out of the garage, they didn't have a chance to get wet. I believe it has something to do with moisture in the air. I know the brake fluid had moisture by the color, so I changed that. Heard that could cause the booster to not function right. It's just an annoyance thing, but my wife drives the truck and then I always hear about it.
rocco123 is offline
Old 04-11-2005, 12:08 PM   #4
msmith65
Dallas
'93 XLT
Vehicle Specs
Quoted: 0 Post(s)
That used to happen with a car I own that has drum brakes all around.
The only solution was to replace the linings.
__________________
Fixes since Aug. 2004: radius-arm bushings; driver's power-window motor; cleaned MAF sensor; replaced trans low-reverse servo "D" rings; new fan and fan clutch; ignition-switch lock & tumbler; new radiator; new Kumho tires; added heater-control valve; replaced trans modulator
msmith65 is offline
Old 04-11-2005, 04:33 PM   #5
Eneurb
Ajax, Ontario, Canada
1998 Limited
Vehicle Specs
Quoted: 0 Post(s)
If it's just the rear brakes locking up (which I figure it is), you may just have crappy linings.
__________________
I'd rather have a full bottle in front of me, than a full frontal lobotomy.
Eneurb is offline
Old 04-11-2005, 05:18 PM   #6
rocco123
Endicott, NY
rocco123's Avatar
Vehicle Specs
Quoted: 25 Post(s)
(Original Poster)
I can stand to change the rears. I know the wheel cylinders are good ( no leaks). If they did I could understand them grabbing. Thanks for the input guys.
rocco123 is offline
Old 04-11-2005, 05:42 PM   #7
Eneurb
1998 Limited
Vehicle Specs
Quoted: 0 Post(s)
Rear shoe linings have definately been improved over the years to be able to handle the moisture better.
__________________
Eneurb is offline
Old 04-11-2005, 05:54 PM   #8
snoborder42
Maple Valley/Downtown Seattle, Washington
92 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
My moms explorer does this and it is really annoying. But it was the front brakes that would grab when they are wet and they only do it when it wet. But i noticed they they only do it with the ford brake pads. I changed them once and put on brake pads from the parts store and the grabbing completely stopped.
__________________
My Ride:
1992 XLT 4x4 5-Speed, K&N Filter, Flowmaster 40 Series, Panasonic Headunit, Silverstars, Bridgestone Revos
RIP:
1993 "Old Blue" XLT 4x2
snoborder42 is offline
Old 04-12-2005, 09:07 AM   #9
msmith65
Dallas
'93 XLT
Vehicle Specs
Quoted: 0 Post(s)
Try switching shoes/pads side-to-side, one end at a time, and see when the problem moves.
__________________
msmith65 is offline
Old 04-12-2005, 09:10 AM   #10
huskyfan23
Rah no Hans Bwix
WA
huskyfan23's Avatar
1994 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
Mine do the same the thing! I never thought anything of it. Goes away in 1/8 mile.
__________________
1994 Explorer XLT
My registry entry: here
Diamond Everything w/ HID Bi-Xenon Projectors
I'm no doctor, but I am a self-proclaimed genius. There's no reason not to trust me.
What kind of dessert causes women to gain the most weight? Wedding cake
huskyfan23 is offline
Old 04-12-2005, 09:24 AM   #11
trucku
Queens, New York and living in Budd Lake, NJ now.
trucku's Avatar
2002 Explorer XLS 4.0 4x4
Vehicle Specs
Quoted: 0 Post(s)
I never had an extreme case of it binding or grabbing. I park outside. When it rains you will see rust on the rotors. The longer the vehicle sits the more rust will be present. The brakes will grab very harshly for the first block or so.Sometimes I would hear a break "groan". Once the rust was removed, I had no breaking issues. I would try semi metalic pads or ceramic. I have heard some people praise ceramic pads.
__________________
2002 XLS 4.0 SOHC 4x4. Frantz Bypass filter, Mobil 1 5W30.Perma-cool dual remote (2 full flow PureOne PL30001). Perma-cool remote transmission filter (Pure One PL30001). Scanguage II, Sunpro Oil Pressure Guage
Gen 4 mirrors
"The More Complex The Mind, The Greater The Need For The Simplicity Of Play"
trucku is offline
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
