96limitedX
- March 4, 2005
im not really sure where to put this. but i needed to replace my front drivers seat belt. the guy that drove it before me was large and the belt dident retract all the way and got stuck in the door. causing the belt to get very fryed and unsafe IMO. so i went to the local junk yard. found another 95-96 explorer with my saddle tan interior color. and i grabed the almost brand new looking belt for $10. so heres a step by step.
first you need to move the drivers seat all the way up and forword.
then you must remove the plastic part that covers it up by the floor board. its a long paice that goes from the front to the rear seats.
here is what you will need. a set of torx sockets and a 10MM socket and a ratchet
now unbolt the belt at the top of the b-piller. an let it hang down on the floor.
here are the 3 bolts you need to remove. one of on the floor, and two are on the lower b-piller
then you need to fish the top part of the belt through the hole. then just remove the old seat belt.
now you need to fish the bottom of the new belt through the hole and bolt it to the floor
then just install it like you removed it...it will prolly take some messing with it to get the belt to unroll.
heres why i needed a new one....my old belt
now test it out
now test it out
