dreamr
- October 5, 2003
- Lynnwood WA
- 99 XL / 4x4 / 4.0 ohv
Yeah!!!!!
I picked up my trucks new front end tonight ( '96 XJ Hp D30, non-vacuum, 297x shafts). It's in need of some TLC, but was in good running condition before it got chopped out from under the Jeep it belonged to. It looks rather grimy as it has quite the layer of mud and some grease. As well as a ton of brake fluid from chopping those brake lines. I pulled absolutely everything that was attached to the axle just in case it proves useful when the actual swap comes along.
For now the axle build-up is my summer project in between fishing/camping trips. I have no plans on starting the swap untill next winterish. I started this thread now though as I know so little, and I hope to gain all of your support as I start rebuilding the axle. It'll be a long running thread as this will be a slow project (wilderness adventures get most of my money in the summer).
Generally my plans are to refresh/rebuild the axle bit by bit while also collecting parts for the bigger project. Right now I just need to remove all the crap bolted to it and go to town with a wire wheel and a can of por-15 (or rustoleum
) then comes gears, seals, new bearings, possibly new alloy shafts, slotted rotors, etc......
Any advice is of course very much welcomed
