- March 23, 1999
- Parsippany, NJ
- 1996 XLT
I have a 1996. It's a single u-joint in the front (at the front diff) and I guess what is called a double cardan (2 u-joints) at the transfer case. I see 2 torx bolts on either side of the u-joint at the front. They hold straps across the u-joint and hold it to the yolk. I don't see any bolts that hold the t-case end in. Does the drive shaft just slide out from the transfer case? Has any one done this that has some pics I could see? Thanx,
