EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
Front axle replacement and upper Ball joint
Reply
Thread Tools
Old 04-26-2005, 09:51 AM   #1
jspbtown
Belchertown, ma
2001 Sport-Trac
Vehicle Specs
(Original Poster)
I have a 2001 Sport trac that I replaced a lower ball joint on last year. When I did that I noticed a small tear in the outter CV joint boot. Didn't have time to replace it so I gooped it up. Now the upper ball joint is squealing so its time to tackle that. I have a new control arm assembly and am thinking of replacing the entire axle assembly (about $60) while I am at it, in addition to new pads and rotors.
I am pretty comfortable with the upper control arm. I plan on taking several measurements and marking the camber adjusters so I can get it close enough for the alignment shop. Any hints here will be appreciated.
More importantly is the axle assembly. Once I take the large nut off (size anyone?) and remove the axle stub from the steering knuckle, will the other end just slide out of the front carrier? Is it a slip out/slip in type procedure?
Thanks
jspbtown is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
