| Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. |
Thread Tools |
#1 |
Wannabe Elite Explorer
winter park, FL
1996 Limited 4x4
question about rear differential seal
i have tried searching and have gotten conflicting answers.....
my seal for my rear differential seems to be bad, and oil is leaking out. i was looking at it, and it appears that the gasket/seal is hanging out from the seal. when i take it apart to fix it, should i use a gasket to seal it? or some sealer like silicone? i thought you just sealed it up with something like RTV sealant, but it appears there is a gasket. also, roughly how much oil will i need to refill the diff? and will i need some sort of injector? thanks, todd. __________________ 1996 Explorer Limited(4x4): SCT Xcalibrator, Milemarker E9000 3" PA Body Lift/2" TT and Custom Leaf Pack 33x12.50 Pro-Comp MT's on 15x10 rockcrawlers. a whole bunch of metal... http://www.cardomain.com/id/toddious |
#2 |
Evil Asian
Elkridge, MD
91
You can get the gasket or RTV it. I prefer to use a gasket since its easier to clean if you have to do frequent fluid changes or occasional maintenance.
#3 |
winter park, FL
1996 Limited 4x4
so neither one is necessarily "better"? especially considering it might get sumberged in water? and what is the cost for a seal compared to RTV? thanks, todd.
#4 |
resident douche
Dothan, AL
'92 XLT
I've heard many people say RTV is better. My gasket that was put on about 500 miles ago with my gear change is leaking. I plan on ditching it for RTV sealant.
#5 |
winter park, FL
1996 Limited 4x4
thanks!
#6 | |
Moderator/Technician
Mechanicsville, Virginia
2004 Acura TL
Quote:
-Drew |
#7 | |
Germantown, MD
Quote:
__________________ »»»»»...how'd the moon get there, how'd the moon get there? |
#8 | |
Chestnut Ridge NY
1995 Limited
Quote:
__________________ Black , street stock, 1995 Ford Explorer Limited, 4.0L-OHV V6 with AirHog filter, iridium spark plugs w/Taylor wires, 4dr, auto w/tow package and 3.73 Traction-Lok rear, 4WD, 4 wheel disk brakes with ABS, with tan leather, sunroof and engine block heater, made in Canada. Rear leaf springs from a '78 Bronco 3" wide spring pack added to the stock 2.5" wide main spring, 1.2" lift.
#9 |
winter park, FL
1996 Limited 4x4
yes. just under 3 qts is the info i've gathered. thanks to all for the help. any recommendations on specific oils? any with experience good or bad?
#10 |
Florida
97 xlt control trac 4x4
CAPACITIES
Engine, with filter..........5.0 quarts[1] Cooling System, Initial Fill..........13.0 quarts Automatic Transmission, Others Initial Fill..........3.0 quarts[2] Automatic Transmission, 4R70W Initial Fill..........5.0 quarts[2] Automatic Transmission, Total Fill 4R70W..........14.0 quarts 2wd ..........9.5 quarts 4wd ..........9.9 quarts Manual Transmission, ..........5.5 pints Differential, Dana 35 Front..........3.6 pints[3] Differential, Rear..........5.5 pints[4] Transfer Case,Warrner 4405..........3.0 pints Transfer Case,Warner 1354..........2.5 pints 1. When refilling, remove dipstick to provide adequate venting and allow oil to flow into crankcase. 2. With ENG automatic transmission operating temperature, shift through all gears. Check fluid level in PARK and add fluid as needed. 3. Fill no higher than 9.5 mm or 3/8 inch below fill plug. 4. Fill to no more than 1/4 to 9/16 inch below fill plug hole. Do not use synthetic lubricant in axles using RTV sealant. Synthetic lubricant will chemically atack RTV sealant. |
#11 |
winter park, FL
1996 Limited 4x4
so what are my non-synthetic choices for rear diff? preferrably with a friction modifier already added?
#12 | |
Germantown, MD
#13 |
winter park, FL
1996 Limited 4x4
not sure what you mean?
#14 |
winter park, FL
1996 Limited 4x4
also, i was just looking, and my breather hose definately broke off. the inlet for the breather was totally clogged with nasty sand and dirt. is there any way to clean this out completely? should i spray some cleaner in the breather hole, and let it drain awhile longer?
i am planning on putting new extended breather hoses on all necessary parts (front and rear diff, tranny, t-case) __________________ 1996 Explorer Limited(4x4): SCT Xcalibrator, Milemarker E9000 3" PA Body Lift/2" TT and Custom Leaf Pack 33x12.50 Pro-Comp MT's on 15x10 rockcrawlers. a whole bunch of metal... http://www.cardomain.com/id/toddious |
#15 | |
winter park, FL
1996 Limited 4x4
#16 | |||
Germantown, MD
Quote:
Quote:
Quote:
__________________ »»»»»...how'd the moon get there, how'd the moon get there? Last edited by IZwack; 05-01-2005 at 12:15 PM. |
#17 | |
winter park, FL
1996 Limited 4x4
Quote:
so basically i use a 3/8" socket extension to unscrew that drain bolt? sucks i just broke mine last week tighening up my hub nut..... i will make sure to be careful with the breather than.... there was definately a lot of dirt in/on it though. honestly, i couldn't even tell that there was a hole at first. i should have looked into moving these breather hoses before i took the truck swimming. my breather hose for the front diff has a plug on the end. is that normal? should the back one? thanks for the help, todd. __________________ 1996 Explorer Limited(4x4): SCT Xcalibrator, Milemarker E9000 3" PA Body Lift/2" TT and Custom Leaf Pack 33x12.50 Pro-Comp MT's on 15x10 rockcrawlers. a whole bunch of metal... http://www.cardomain.com/id/toddious |
#18 | |
Germantown, MD
Quote:
re-read the end of my post though about the dirt, i added a few sentences about trying to catch the dirt from the inside of the differential (post #16). as for the front differential, yes there is a plug on the end but its a breather plug so it does allow the axle to breath... good luck if youre going to replace the front differential breather.. that thing is a pain as the rack and pinion steering cooler is right there cutting your arm up. i eventually got my extension on but my arm looked like a dog had chewed on it. by the way, i see you have a limited.. before you take ur X out on the trail again, id remove all of the limited's dress up parts like that bumper... im sure you can get some money for that as the limited's bumpers are totally different from the others in the 2nd generation. you can probably get a standard bumper (from an XLS or XLT) from a junk yard for cheap. __________________ »»»»»...how'd the moon get there, how'd the moon get there? |
#19 |
winter park, FL
1996 Limited 4x4
thanks for the hint....
for the hub nut, i didn't have a 1/2 ratchet, so i had to use a 1/2" socket, then an adapter to 3/8", then my 3/8" extender, then my ratchet...... of course the extender was what broke...... __________________ 1996 Explorer Limited(4x4): SCT Xcalibrator, Milemarker E9000 3" PA Body Lift/2" TT and Custom Leaf Pack 33x12.50 Pro-Comp MT's on 15x10 rockcrawlers. a whole bunch of metal... http://www.cardomain.com/id/toddious |
#20 | |
winter park, FL
1996 Limited 4x4
Quote:
about my trim pieces, it's in the works. i have a tube bumper with winch thats ready to be put on, i just have to drive the 3 hours to go get it, and install it. same with the side steps, i have tube steps waiting for me as well. the problem is, they are already a little scratches, so whoever bought them would need to repaint, plus i had to trim them so i could fit the 33's. not sure anyone would want them still, but they will be available as soon as i have my new metal ones installed. good heads up though. todd. __________________ 1996 Explorer Limited(4x4): SCT Xcalibrator, Milemarker E9000 3" PA Body Lift/2" TT and Custom Leaf Pack 33x12.50 Pro-Comp MT's on 15x10 rockcrawlers. a whole bunch of metal... http://www.cardomain.com/id/toddious |
| Thread Tools | |
