#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Jacking instructions
Reply
Thread Tools
Old 05-03-2005, 08:05 PM   #1
sr71bb
Norton, Massachusetts
2001 Explorer sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hello all, i've got a 2001 explorer sport, i've yet to need to jack up the rear of the vehicle for any thing yet. But the jacking instructions say to position the bottle jack under the axle. I keep thinking to myself, that this can't be good for the axle, yet this is what the instructions appear to say. I can't see anywhere else to do it though. On the front, there are hooks to position the jack under. Is this right correct for the rear though?
sr71bb is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-03-2005, 08:16 PM   #2
Arnie897
y=mx+b
Battle Creek, MI
Arnie897's Avatar
06 Dodge Powerwagon
Vehicle Specs
Quoted: 1 Post(s)
I usually go for right under the pig or under one of the shock mounts.
__________________
Mike
I used to have an Explorer
Arnie897 is offline   Reply With Quote
Old 05-03-2005, 08:17 PM   #3
Blee1099
Evil Asian
Elkridge, MD
Blee1099's Avatar
91
Vehicle Specs
Quoted: 10 Post(s)
First thing I recommend doing is doing away with the factory screw type bottle jack. Quite frankly.. I don't feel comfortable with that thing when it comes to lifting a side of the truck up to change a tire for emergency situations. I recommend using a hydraulic bottle jack. You can fit one perfectly in the same location where the factory jack is located. I keep one in my truck along with my hi-lift jack. I pulled over earlier this week to assist a female Explorer owner. The factory jack slipped off the front jacking point on her truck so it proved to be a lost cause with the jack.
Blee1099 is offline   Reply With Quote
Old 05-03-2005, 08:30 PM   #4
alexefron
Rochester, NY
93 XLT
Vehicle Specs
Quoted: 0 Post(s)
With the factory bottle jack youre basically stuck using the axles if you want to get the tire off the ground.
alexefron is offline   Reply With Quote
Old 05-03-2005, 08:34 PM   #5
spindlecone
B
San Jose, Calif
2003 sport trac
Vehicle Specs
Quoted: 0 Post(s)
Quote:
To simply change a tire, the instructions are correct, you will not hurt anything, just make sure you are on level, hard ground.
Do not attemp to get under the EX to do any work, the OEM jack is a POS, you could die
spindlecone is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
