Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Bronco II > Bronco II
Notices
Bronco II Our Ford Bronco II forum covers maintenance, problem solving, 4x4 issues, and all topics regarding the 1984 - 1990 Ford Bronco II.
Ricks Bronco: 1and 1/2
Reply
Thread Tools
Old 09-11-2009, 11:51 PM   #1761
mynameisaric
with an A
Bolingbrook, IL
mynameisaric's Avatar
98 XLT
Vehicle Specs
Quote:
Originally Posted by black91EB View Post
Weren't most full width HP D-44s 5 on 5.5? I don't recall seeing one that wasn't, excepting the 8 lug versions.
Well there was the d44 from the 150, but it was setup for radius arms and had 5 on 5.5, but the 250 was setup for leafs and had 8 lug setup(dont know the pattern). 350 was the same way, but it used a d60.
So i should clarify and say that it is weird seeing a d44 high pinion from 78 or 79 setup for leafs with 5 on 5.5.
this is a d44 low pinion from a 76 250. in 78 they went high pinion, but for the most part were unchanged other than that. (talking about the axles, not the entire truck)
__________________
-Driveway Ornament (aka 98 explorer)
-05 F150 3V 5.4L Supercab
mynameisaric is offline   Reply With Quote
Old 09-12-2009, 08:07 PM   #1762
rookieshooter
Martinsburg WV
rookieshooter's Avatar
84 BII "Li'l Samson"
Vehicle Specs
(Original Poster)
Got the pass side spindle off, what a major pain. Used a combination of those two chisels. As you can see it had some crude around that sleeve.
Pass. side axle is out and I measured the axle tube. It's .500 wall.
__________________
"2012 & 2011Truck Nationals" At Carlisle Extreme 4x4" First Place winner.
"2012 &2011 All Ford Nationals" At Carlisle First place winner Bronco Trail Truck
Featured in 2012 Bronco Driver Mag.
Petersen's 4Wheel mag ROTM. Voted 2008 Bronco II of Year
rookieshooter is offline   Reply With Quote
Old 09-13-2009, 04:33 PM   #1763
rookieshooter
Martinsburg WV
Vehicle Specs
(Original Poster)
I'm going to try something a little different then what I read on cutting off axle. They said use some dowls in the TRE holes and measure angle so the caster will be the same after installing knuckle back on. But what ever you do, don't rotate pinion any time aftewards. Well I want to rotate the tube so I can cut off the tube while setting in my comfy chair.
So just got my Laser light and struck a beam along the axle and up onto knuckle. The Laser tool was flush up against the cast iron diff. The light was adjusted to to shine along tube where it intersected with the center edge of the TRE. Then It was just matter of finding a drill bit the same diameter as the light beam. Next I drilled a series of holes just deep enough to mark the tube it's full length. Next I removed the Laser beam and reatached with the light hitting the three widly spaced holes along the tube. Each and every time it ligned up with the center of the TRE hole.
Next was the tedious job of grinding the weld off the tube knuckle connection.
This took about 50 min. I got a few minutes into this job when I found a comfortabe way to support my arms on my knees and then it was not so bad.
What you want to do is grind down far enough where you can see a faint line/crack. The is where the knuckle meets the tube and there is no more weld. If you look close near the top you can see the crack.
Then get a big 20 pound sledge hammer and knock off...Right like that will happen. And it did not come off.
At this point the knuckle is supposed to be off. But I'm cutting the tube anyways. I hit long on hard and it did not budge.
Yep, 1/2" wall, that is just so cool.
I took the knuckle and put a cutting wheel on the grinder and cut off the tube and the hair line crack in back. Next I took the saw-zall and cut two cuts lenth wise in the tube that was still in that damn knucle. Here it is part way out when I took the pic. Hard to see the one cut it close shut when it took it first hit.
Just use a large socket and a 20 pound sludge and out it came. Ho ra.
And here is the fruit of all this labor. My shortened D44 axle tube. Now to get an early Bronco axle. No it's not welded yet...just too tired.
__________________
Old 09-14-2009, 07:59 AM   #1764
rookieshooter
Martinsburg WV
Vehicle Specs
(Original Poster)
OK, the mystery axle is solved and the ones that said F150 Super Cab are correct.
I checked on the BOM # the tag that was on pumpkin..610068
and then checked on this chart at
http://www.therangerstation.com/tech...M_numbers.html
And this site also. Scroll down to 77-79 F150 and it even mentions 5 x 5.5
http://77cj.littlekeylime.com/Dana44_3.htm
__________________
Old 09-14-2009, 02:06 PM   #1765
rookieshooter
Martinsburg WV
Vehicle Specs
(Original Poster)
This steering arm was fun getting off...The 20# sludge with the sharpened brick chisel is really coming in handy.
I need to get an arm made that fits that bolt pattern for my high steer upgrade. The steering arm that Was on it won't work with my coilovers.
Here is the pass side that needs to be milled and tapped on top for the other side steering bracket to relocate the steering arm higher up.
I talked to a guy in Winchest Va. that mills the tops and uses water jet to make the steering arms. May have to make a trip down there.
__________________
Old 09-14-2009, 02:08 PM   #1766
rookieshooter
Martinsburg WV
Vehicle Specs
(Original Poster)
Anybody have any pics of a HS D44 in a RBV with coil suspension or coilovers?
Just did a little research and fount out that the EB Bronco axle has smaller U-joints. Can't have this, at least need the same as the Dana 44. Looking locally to see if there is a machine shop that can re-spline the Dana or might just have to ship.
__________________
Old 09-15-2009, 09:14 PM   #1767
rookieshooter
Martinsburg WV
Vehicle Specs
(Original Poster)
Well I did not take the knuckle to Winchester Va. but to Hagerstown Md. which is only a few miles from my house. There is a huge Machine shop there that actually is one city block long and 3 stories high. Talk about an Old School place, it must have been built in the early 1900s and still has dozens and dozens of lathes and such. Some of the equipment must have been there the same time. Tons of fasteners and every kind of machining tools you would ever want. Plus they sell steel products and drop pieces.
OK, bottom line, when I walked in there I took the knuckle and explained what I want. He's never done one and I told him that companies that do this get around $50 for one.
He said how about $25...I handed him over the knuckle. It will be done tomorrow afternoon. If I'm back from my Doctor visit I'll pick it up.
__________________
Old 09-15-2009, 10:29 PM   #1768
lifeguard379
sacremento,ca
lifeguard379's Avatar
93 eddie bauer 2 door
Vehicle Specs
do you just want stock shafts or stronger?
__________________
93 2 door eddy Bauer HP44 and Big bearing 9 and 4.88 My elite registry
http://www.explorerforum.com/forums/...d.php?t=153392
sas thread
http://www.explorerforum.com/forums/...d.php?t=165147
sas registry
http://www.explorerforum.com/forums/...d.php?t=244780
lifeguard379 is offline   Reply With Quote
Old 09-15-2009, 11:33 PM   #1769
rookieshooter
Martinsburg WV
Vehicle Specs
(Original Poster)
Quote:
Well I need shafts that are 6" shorter but would like the u-joints to be as strong like the ones that are in there now, which i think are the 297 ones.
The shorter early Bronco shafts that are 6" shorter have weaker smaller u-joints. That's what I read anyway. So shorter shafts with stock type 79 F150 u-joints would be fine.
__________________
Old 09-15-2009, 11:37 PM   #1770
JTX
Rollin...
New Mexico
JTX's Avatar
94 xlt
Vehicle Specs
Rookie im setting up the same exact axle now. Mine was from a 77 F150. There pretty common actually.
__________________
-=Elite Registry=-
JTX is offline   Reply With Quote
Old 09-15-2009, 11:58 PM   #1771
lifeguard379
sacremento,ca
Vehicle Specs
how about these?
http://www.wildhorses4x4.com/category/axle_shafts_front
__________________
sas thread
sas registry
Old 09-16-2009, 12:59 AM   #1772
rookieshooter
Martinsburg WV
Vehicle Specs
(Original Poster)
Hey, thanks for the link. Might have to call them up and see if I can get just the right side.
__________________
Old 09-16-2009, 05:24 AM   #1773
rookieshooter
Martinsburg WV
Vehicle Specs
(Original Poster)
Quote:
Is yours an 8 lug or 5? I'm trying to figure out if the 79 F150 Super Cab was the only one that had the 5 on 5.5 bolt pattern between 77-79. I also just learned that not all axle tubes in 79 were 3" x 1/2" wall. Some were 2.75 x 1/4"wall.
Just trying to be an educated consumer LOL.
__________________
Old 09-16-2009, 05:52 AM   #1774
rookieshooter
Martinsburg WV
Vehicle Specs
(Original Poster)
Also I'm trying to determine if the amount of webbing on center section translates to a heavy duty case, and if so this might mean that the tubes are in fact the .500" tubes.
This would be good info when scouring thru the salvage yards in quest of a HD axle.
Here is a pic of mine with the webbing. It has three on one side and a single one on other.
Any info from anyone would be appreciated.
__________________
Old 09-16-2009, 10:40 AM   #1775
black91EB
Air Rifle Technician
Millington, TN
black91EB's Avatar
'92 XLT 5spd 4wd
Vehicle Specs
Hmmm, I'll look when I get home, I have a full width coil spring d-44 HP empty housing out of a 78 Bronco that I can measure. Will also look at the webbing. I find quite a few coil versions in the yards around here, but very few leaf sprung in either pattern.
__________________
My Elite Registry
'92 F-250 XL supercab, 5spd, 4x4, IDI Diesel
black91EB is offline   Reply With Quote
Old 09-16-2009, 11:09 AM   #1776
rookieshooter
Martinsburg WV
Vehicle Specs
(Original Poster)
Thanks for doing that EB.
Just got back the pass. side knuckle from the machine shop. Now instead of the TRE going in the extended arm with the hole, it will mount high up on a fabricated arm bolted to the top of the milled area.
$29.00 and some change to mill and re-tap those threads. No bad at all.
I had it milled the same angle to the ball joint hole as the driver side. Of course the driver side was done from factory.
I'm already thinking about a built 4 link DOM tubing suspension. If not then a built pinned twisted arm type.
To say this is getting interesting is an understatement.
__________________
Old 09-16-2009, 11:44 AM   #1777
lifeguard379
sacremento,ca
Vehicle Specs
did he drill the holes or are you planing on that?
__________________
sas thread
sas registry
Old 09-16-2009, 11:59 AM   #1778
rookieshooter
Martinsburg WV
Vehicle Specs
(Original Poster)
The holes are not drilled. This is a whole new learning process for me. I'm thinking of getting the arms with the holes. And then getting the right hardware needed. This might be those cone shaped bushings also. Then if it's somthing I can do, I will get the right tap and have at it. My research says that those holes have to be Dead Drop perpendicular to the milled area. If I think I can not do it then off to the the machine shop.
I don't have he arms yet and that's another reason there are no holes. Seems to be a lot of suppliers out there to chose from. And prices all over the board.
__________________
Old 09-17-2009, 03:23 PM   #1779
rookieshooter
Martinsburg WV
Vehicle Specs
(Original Poster)
Going to weld on this part of the knuckle to the shortened axle. This was a major pain trying to get the tube and inner knuckle aligned up. Even after putting part in oven I still had to beat on it untill the cows came home. Then after it was on tube far enough it was just a frog hair off on the Laser beam. But I finally got it lined up. About a 1/4" from the left end of the light beam, you can see a faint dimple that is centered in the beam. This was one of my holding points.
Then the fun part of welding the steel tube to the cast iron knuckle. Used plenty of heat from an acetylene torch. And then even post heated it.
There was plenty of bare metal after cleaning the axle, so I thought some paint may be in order. I like the looks of the shaved axle minus those shock mounts.
__________________
Old 09-19-2009, 08:00 AM   #1780
rookieshooter
Martinsburg WV
Vehicle Specs
(Original Poster)
Here is the stock axle length compared to the cut axle tube.
And here is the splined end just far enough back not to extend past the spider gear.
So now to get the axle cut. I'm just going to send it to Currie and let them do it. Lord knows they have done enough of them.
When I talked to them they quoted $70 for cutting and machine work and around $20+ for shipping from CA to WV.
Need to start designing radius arms or 4 point as far as DOM tubing and joints go. Have and idea for a twisted RA suspension. Really want a 4 point, but not too much room under there. But we'll see.
__________________
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
