EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Air Bag Removal
Reply
Thread Tools
Old 05-27-2005, 09:01 PM   #1
Kevin Kuiper
Eustis, Fla
96 XLT
Vehicle Specs
(Original Poster)
US Air Bag Removal
How Do I remove My Air Bag??? With Out Damaging Anything
__________________
Love Riding My VTX 1800 Retro
Kevin Kuiper is offline   Reply With Quote
Old 05-27-2005, 09:38 PM   #2
Doug
I'm Awesome!
Home is where the Army tells me. Right now it's Manorville, NY
Doug's Avatar
Vehicle Specs
Pop off the covers, remove the two bolts holding it on and undo the connector, takes about a minute. Though it's illegal to operate a vehicle equipped with air bags with out them.
__________________
97 Explorer
Life's hard. Wear a helmet.
Doug is offline   Reply With Quote
Old 05-27-2005, 09:45 PM   #3
Kevin Kuiper
Eustis, Fla
96 XLT
Vehicle Specs
(Original Poster)
So The Horn Cover just Pulls Off??? And I'm am Not Taking it Off for Good, Just to Re-Place a Cruise Switch...
__________________
Old 05-27-2005, 09:51 PM   #4
Doug
I'm Awesome!
Doug's Avatar
Vehicle Specs
The horn button is actually under the airbag. Just do what i told you, it's real easy and you'll see the screws to remove the cruise control switches.
__________________
97 Explorer
Old 05-27-2005, 09:58 PM   #5
Kevin Kuiper
Eustis, Fla
96 XLT
Vehicle Specs
(Original Poster)
OK, So All I do Is Pu;; the Horn/Air Bag Cover Off... And It Should Pop Right Back on.. Sounds Very Easy!!! Thank You!!!
__________________
Old 05-27-2005, 10:43 PM   #6
MONMIX
I fix dents
Millersville , Maryland
MONMIX's Avatar
2000 Explorer Sport
Vehicle Specs
woah !!!!!!!!!!!!!!!!!!!!!!!!!!!!
__________________
MONMIX
Wheels and intake for sale
Live your life for a change
My Explorer
CHURCH.... sort of
MONMIX is offline   Reply With Quote
Old 05-27-2005, 10:50 PM   #7
MONMIX
I fix dents
MONMIX's Avatar
2000 Explorer Sport
Vehicle Specs
Oops,
First disconnect the battery, both positive and negative for ten mineuts prior to the next step.
Behind the steering wheel there are two covers.
Pop off the covers and there are tow 8mm bolts.
Remove them.
there will be two wires to disconnect. One wire for the horn, pull that, the next is a yellow conector, that is for the bag.
There is a tab that folds over the connector, pop that out and then lift out the connector.
__________________
MONMIX
My Explorer
CHURCH.... sort of
Old 05-27-2005, 10:56 PM   #8
MONMIX
I fix dents
MONMIX's Avatar
2000 Explorer Sport
Vehicle Specs
passenger side, remove the glove box, by remove I dont mean open I mean remove.
There will be four 11mm bolts. Shiney brass ones you should see them easily.
Lift the bag out from the top.
The connecor for that it a PITA
it is clipped to one of the dash supports and you really cant see it, feel your way down the wire to the connector and pull it off of the support.
You will now have enough slack. There is a tab that goes down the center of the connector, pull that out, then push the relase to undo the connector.
__________________
MONMIX
My Explorer
CHURCH.... sort of
Old 11-21-2009, 08:00 PM   #9
dafinsfan
Loveland, CO
dafinsfan's Avatar
98 XLT
Vehicle Specs
How about install?
How do I do the install on the airbags? I assume the battery has to be disconnected, do I need to take any precautions before reconnecting the battery? Also, can I drive a vehicle that had both air bags deployed? or Do I need to replace the bags before I can move the car? I bought this 98 explorer and I have to go pick it up, both bags were deployed when the previous owner scraped the side of the car, but there was no collision, except for a long scratch along the passenger side and a broken mirror. Thanks in advance for your help on this.
__________________
Dafinsfan
Miami,FL.
dafinsfan is offline   Reply With Quote
Old 12-13-2009, 05:11 PM   #10
MONMIX
I fix dents
MONMIX's Avatar
2000 Explorer Sport
Vehicle Specs
you can drive them all you want with the bags deployed.
It will harm nothing other than your self if you are in a severe collision.
You will need to have both terminals disconnected for the reinstalation. Bagds first than module but DO NOT reconnect the bettery until all three are done.
__________________
MONMIX
My Explorer
CHURCH.... sort of
Old 12-13-2009, 05:15 PM   #11
Scotty J.
Packin
Little Rock, Ar
Scotty J.'s Avatar
'02 Ford Ranger XLT
Vehicle Specs
Quote:
I thought it took a minimum 33mph frontal collision to deploy them? I may be mistaken, in fact there is a VERY good chance that I'm mistaken.
But if what you said is true, seems like it these vehicles wouldn't make for offroading very well...
__________________
Scotty J.'s Registry
My Build Thread
Quote:
Originally Posted by JDraper View Post
There are two types of people that offroad, those that have damaged their vehicles, and those that are going to damage their vehicles...welcome to group 1
Scotty J. is offline   Reply With Quote
Old 12-13-2009, 05:48 PM   #12
techieman33
Topeka, KS
techieman33's Avatar
00 V8 Mountaineer
Vehicle Specs
There are pressure sensors behind the front bumper, when enough force is applied to them they pop. I'm pretty surprised that they would deploy after scratching the side of the vehicle though.
techieman33 is offline   Reply With Quote
Old 12-13-2009, 07:08 PM   #13
Scotty J.
Packin
Little Rock, Ar
Scotty J.'s Avatar
'02 Ford Ranger XLT
Vehicle Specs
Quote:
That's what I'm saying, Last weekend I went through a mud hole that was trenched so far on the left that my truck leaned over so far that it collapsed my drivers mirror on the left edge of the rut, it was a pretty good lick. Arco777 was right behind me in a pretty much stock Ex and he had no problems either, much less air bag deployment.
__________________
My Build Thread
Old 12-13-2009, 08:58 PM   #14
dafinsfan
Loveland, CO
dafinsfan's Avatar
98 XLT
Vehicle Specs
Air Bags
Thanks for your reply. Actually you are correct, the picture from the listing showed some damage from the passenger side starting at the door all the way back to the bumper. The car was a DUI donation (more like taken away) and after inspecting the car, I noticed that the front stabilizer bar links were snaped like a cracker, which indicates some kind of impact from the front of the vehicle. My guess, the drunk driver fell in a ditch or something. However, I picked up the car from Minessota and drove it back to South Florida, all I had to replace was the battery and a local shop made a small repair on the radiator to stop a leak. The car drives great, the engine is strong and I am very happy with my Explorer. Thanks for the reply, I'm sure I'll be posting again as I begin to work on my Explorer.
__________________
Dafinsfan
Miami,FL.
Old 10-09-2010, 11:02 AM   #15
tjfly
Washington
2000 EDdie Bauer Expolrer
Vehicle Specs
Wink Passenger Air Bag Cover Removal
I am new, hope to be a help at some point,but need a spot of help at the start.
I recently bought a 2000 EB Explorer that is in exceptional condition, and am please overall so far. One niggling thing: I have a rattle that appears to be the passenger airbag within its storage area.
Can I safely simply pop off the plastic cover by prying it up gently in one corner then removing it? I want to just see where it rattles and pad it slightly and replace the cover.
...or do I need to go through the whole disassembly routine of the glove box & bolts?
thanks
TJ
tjfly is offline   Reply With Quote
Old 07-15-2011, 05:24 PM   #16
exploder1995
Menominee, Michigan
95 xl
Vehicle Specs
is it necessary to replace the airbag module after bother airbags have been deployed. i dont care if the warning light stays on. i just dont feel like ripping the whole dash apart if it isnt needed.
exploder1995 is offline   Reply With Quote
Old 02-12-2012, 11:34 AM   #17
scapino
Vehicle Specs
Air Bag Removal?
Quote:
Ok, I need to ask this question because it's not adequately answered - how do I remove the drivers side airbag on a 2005 Exp? I need to replace a cruise switch so I need the airbag removed to gain access to the switch. I've replaced an airbag on a Ranger before so I know the basics (disconnect battery, etc) - but what covers do I "pop off" to get at the bolts? and how do they "pop off"??
scapino is offline   Reply With Quote
Old 02-12-2012, 11:55 AM   #18
buckwill
trona calif
1998 sport
Vehicle Specs
well like they said battery etc,,, on 98 on sides of sterring wheel underneath spokes there are 2 round discs,, plugs,, pop them out with small flatblade screwdriver, one disc on each side,, srews are in the holes
__________________
if my memory was getting shorter would i know???,, disabled viet vet, retired navy,, 98 exploder sport sohc 4.0,, retired macinist,gas and steam turbine millwright,, ive arrested, stroked twice and i mispell lots,
buckwill is offline   Reply With Quote
Old 07-10-2012, 08:33 PM   #19
rzappala
California
'97 XLT
Vehicle Specs
I am planning to sell my 1997 Explorer to the California State as part of their Vehicle Retirement program (for $1000), but was thinking about selling any parts not required to be on the vehicle before I take it to a salvage yard. Someone has expressed an interest in both airbags. I am aware that it is not legal to operate a vehicle without the airbags, but I will only need to start it and drive it 10 yards. I can do this after towing it to the salvage yard and can drive on their property.
My question is will the Explorer start and run without both airbags?
rzappala is offline   Reply With Quote
Old 07-11-2012, 11:13 AM   #20
bobflood
Powder Springs, GA
1997 Eddie Bauer V8 2WD
Vehicle Specs
Yes, it will.
__________________
1997 Ford Explorer, Eddie Bauer, 5.0L V8, 2WD, 270K+ miles, starting to show its age!
bobflood is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
