Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Resetting Anti Theft System: Help Please!!
Reply
Thread Tools
Old 05-30-2005, 02:28 PM   #1
ExCon
TAMPA FLORIDA!!!
98 EDDIE BAUER 5.0 LITE
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I had 2 idiots detailing my truck and somehow by using the pressure washer they now have the truck in "theft" mode and the truck will not start. Does anyone know a way to "clear" the CPU and reset the system? Is there a reset switch or a fuse I can pull for a few minutes? HELP!! MY WIFE IS FREAKING OUT!!!
__________________
The Only Credit I Ever Got Was Credit For Time Served!!!
ExCon is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-30-2005, 07:00 PM   #2
jayhawkexplorer
Mission, Kansas
jayhawkexplorer's Avatar
'97 XLT
Vehicle Specs
Quoted: 0 Post(s)
Disconnect the negative battery terminal for 15 mins.
__________________
Former owner of a '97 Explorer XLT, I let her go on 5/31/06
Had a Mazda Protege5 for 32 days before it got totaled by a fellow driver, now owner of an '03 Mazda 6s.
jayhawkexplorer is offline   Reply With Quote
Old 05-30-2005, 08:20 PM   #3
ExCon
TAMPA FLORIDA!!!
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks!!!
__________________
Old 09-22-2012, 07:36 PM   #4
RubenT
2001 Ford Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
Any other suggestions? Also no fuel going to engine...
RubenT is offline   Reply With Quote
Old 09-23-2012, 05:23 AM   #5
crazymind
99 mountaieer 4.0
Vehicle Specs
Quoted: 0 Post(s)
Check the inertia switch. Its on the passanger side under the carpet.
crazymind is offline   Reply With Quote
Old 09-24-2012, 07:04 AM   #6
RubenT
Vehicle Specs
Quoted: 0 Post(s)
The inertia switch didn't 'pop up'. Is there something else to tth to reset ?
Old 09-24-2012, 07:17 AM   #7
RubenT
Vehicle Specs
Quoted: 0 Post(s)
Should read "do to reset factory anti-theft?"
Truck ran fine. Disconnected battery to change post terminals. plugs, wires. Assembled all & ...nothing. Just turns over. Could it be anti theft because dash light keeps blinking. Help!
Old 09-24-2012, 07:43 AM   #8
budwich
Ottawa, Ont
96 XL
Vehicle Specs
Quoted: 0 Post(s)
You have to clarify your observations to help the forum a bit. When you put your key in the ignition, EXACTLY what happens when you turn the key to ON in terms of the theft light (ie. flashes slowly, flashes fast, flashes what?).... go from there. Further have you tried other keys.... does the system response change?
budwich is offline   Reply With Quote
Old 09-25-2012, 11:33 AM   #9
RubenT
Vehicle Specs
Quoted: 0 Post(s)
1) The "theft" light (indicator) on the dash flashes fast when the key is in the ON position. The engine turns over & no fuel is getting to the engine (as though the fuel has been disabled {by the PATS being ON?}
2) Only have one key at purchase so no, I have yet to try any other(s).
Thanks for your replies thus far. Keep em' coming!!
Old 09-25-2012, 12:07 PM   #10
budwich
Ottawa, Ont
96 XL
Vehicle Specs
Quoted: 0 Post(s)
:-( I think you going to have problems trying to get around this. The "fast" flashing is a bad sign. Make sure you have powering going everywhere... check ALL your fuses... perhaps a "wet ingression" sprung one. Perhaps cleaning / drying PCM connections along PATS module connections might help.
Old 09-26-2012, 12:34 AM   #11
RubenT
Vehicle Specs
Quoted: 0 Post(s)
What is "wet ingression"? PCM module?
Possible thatbattery terminal posts changes caused
pats trigger?
Old 09-26-2012, 05:49 PM   #12
RubenT
Vehicle Specs
Quoted: 0 Post(s)
Theft light will flash 6 times in succession, pause, flash once, pause, then repeat.
The light will then disappear bit still no start
Old 09-26-2012, 06:03 PM   #13
Blee1099
Evil Asian
Elkridge, MD
Blee1099's Avatar
91
Vehicle Specs
Quoted: 10 Post(s)
From what I heard there is a actual flash "code". Like 1 flash pause then 5 flashes, then it repeats. If yours flashes 1 then 6 times it means there is a fault between the PATS module and EECV.
Blee1099 is offline   Reply With Quote
Old 09-27-2012, 12:27 AM   #14
RubenT
Vehicle Specs
Quoted: 0 Post(s)
Blee1099, thanks for your reply. Any remedy suggestion (s) to try?
Old 09-27-2012, 01:19 AM   #15
Chikar
Ladysmith, British Columbia
1999 Explorer Sport 4X4
Vehicle Specs
Quoted: 0 Post(s)
Blee1099 has it right. A communication problem between the PATS (Perimeter Anti-Theft System) and the EECV (Electronic Engine Control version 5) module. The PATS system disables engine start under various scenarios, usually involving somebody trying to steal your truck.
Basically you've got a wiring problem between the two it seems. You're facing a lot of circuit tracing and diagnosis or worse taking it to the dealer.
Chikar is offline   Reply With Quote
Old 09-27-2012, 11:39 PM   #16
RubenT
Vehicle Specs
Quoted: 0 Post(s)
Thanks for your input as well, Chikar. Short of dealer visit what recourse is there?
Circuit tracing - not a strong point and manuals not bog on circuit diagrams.
Any other possibilities? Drove fine until battery change....
Old 09-28-2012, 12:58 AM   #17
Chikar
Vehicle Specs
Quoted: 0 Post(s)
Hi RubenT;
If you're not good at electrical work like circuit tracing and don't have access to a manual with test procedures and circuit diagrams I'm afraid you're stuck with taking it to a shop. It doesn't necessarily have to be a dealer. There are independent shops out there with very capable techs and they do tend to be less expensive.
Although the flash code says there is a communication problem between the PATS and the EECV the problem could actually be that one or the other has failed. While the Ford modules have a reputation for being almost indestructible they CAN fail.
You mentioned changing the battery posts. There will almost always be a bit of a spark as a cable is removed from a battery post. That puts a voltage spike into the trucks wiring which MAY have damaged a module. Pretty unlikely but it can happen. I've been an electronics and computer tech for over 30 years and have seen it happen.
Old 09-28-2012, 09:22 AM   #18
budwich
Ottawa, Ont
96 XL
Vehicle Specs
Quoted: 0 Post(s)
Ruben T, you brought up an old thread (I failed to notice that) with "any other suggestions?". You need to fully restate what your vehicle is doing and how it got that way... now you state that you change battery cabling when this started. Do you have a remote starter installed in this vehicle? As suggested try cleaning the connections at the pcm and the PATS. Have you checked ALL your fuses??
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
