dreamr
- October 5, 2003
- Lynnwood WA
- 99 XL / 4x4 / 4.0 ohv
Well........ I have been working on tearing down a 96 XJ D30 for my rig. The axle is from the midwest so a bit "glued" together. I have gotten most of the junk off, but have yet to be able to pull the Hub and Bearing assembly.
On the jeep it is a very similar assembly to the 4X4 IFS Explorers.
Below you can see the assembly. The red dotted line is where it should seperate for removal. On the only Jeep I have worked on as well as my Explorer The whole unit just slid off by hand with no force whatsoever.
I have beat on this thing and soaked it in penetrating lube but to no avail. In short I need to get it off for replacement as well as to make the axle shafts available for removal and inspection. In addition to changing seals and such.
Well.... I was getting irritated and was advised to grab a gear puller and go to town with the impact wrench.
It all seemed to be going fine as the bolt was still moving and things were spreading........so I thought.
When it all finally popped free though this is what I got.
As you can see in the picture the inner and outer parts of the assembly seperated exposing the actual bearings. They really were not supposed to. Now that it is open I can see that the bearings were fine so I wonder can it go back together? and how?
But my main question is this. How do I get the inner part of the assembly off the housing???????????
