Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Auto locking hubs
Reply
Thread Tools
Old 06-02-2005, 01:13 AM   #1
stone4x4
Copperas Cove, Texas
93, Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Auto locking hubs
My 93 4x4 Explorer Sport have the auto locking hubs and they do not operate when I press the button for 4x4. I have check the connections, the fuze links under the dash and the main fuze box under the hood. I do not see and blown fuzes. When I press the button, I can here a click in the left rear panel. I am not sure if the module is bad or not.
Can someone help me shine some light on this problem?
Thanks
Stonne4x4
stone4x4 is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-02-2005, 01:28 AM   #2
jimbo74
Elite Ranger
Nor*Cal
jimbo74's Avatar
98 XLT Supercab 4x2
Vehicle Specs
Quoted: 0 Post(s)
welcome to the site, are you having a hub problem? or dont know?
does the light on the dash come on at all? if 4x4 still doesnt engage there is probably a shift motor failure and it needs to be cleaned
__________________
My Truck
jimbo74 is offline   Reply With Quote
Old 06-03-2005, 01:44 PM   #3
stone4x4
93, Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Auto Locking Hubs
No, I press the button on the dash and nothing happens. I replaced the rotors a few months ago, I followed the repair manual step by step and look back at the manual to see if I missed something. Is it possible to use too much grease in the hubs? When I press the button on the dash, I here a click in the left rear panel.
Thanks
Stone4x4
Old 06-03-2005, 02:08 PM   #4
MrShorty
Spanish Fork, UT
92 XLT and '87 Bronco II
Vehicle Specs
Quoted: 10 Post(s)
Is it possible to get too much grease in the hubs? Yes, it is.
Are you certain the t-case is engaging? The fact that the dash light doesn't come on suggests that the t-case isn't engaging. Hubs won't engage until the t-case engages.
__________________
Mr. Shorty
92 XLT 4x4
87 Bronco II XLT 4x4
'98 Chev K1500 Suburban SLT 4x4
MrShorty is offline   Reply With Quote
Old 06-03-2005, 04:35 PM   #5
jgilbs
Naperville, IL(home)/Iowa City, IA(school)
jgilbs's Avatar
92 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
you ask is it possible to use TOO MUCH grease. you should not use ANY grease inside the hubs, as this gums them up and causes them to not work. Try cleaning them with paint thinner and then soaking them in ATF to get the grease out.
jgilbs is offline   Reply With Quote
Old 06-05-2005, 07:34 AM   #6
MazdaGreg
Frederick, Co
93 Ranger XLT
Vehicle Specs
Quoted: 0 Post(s)
I had a similar issue on my 93, and found that most likely your T-Case motor is sticking. what you can do is go under the car, and find the motor on the Transfer Case. tap on it a few times with a hammer (not too hard. don't beat it up) but that sometimes will loosen up some garbage in there, and then when you hit the button, it will work. That's a fairly common issue on these.
MazdaGreg is offline   Reply With Quote
Old 01-17-2006, 05:32 PM   #7
rust591
Winkler Manitoba Canada
91 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
When talking about no grease in the hubs which parts are you talking about
my transfer cas is engaging replaced the shift motor lights all work
took my wheels off and slid the hub off and everything stayed toger didn't find anything broken but quite alot of grease does anyone have pictures of what the hub all consits of cause i do have another explorer with hubs and that 4x4 works but don't want to take them off if I don't have to
rust591 is offline   Reply With Quote
Old 01-20-2006, 03:24 PM   #8
93junker
Sterling Heights, MI
'93 XLT 4X4
Vehicle Specs
Quoted: 0 Post(s)
I may be having the same problem. 4x4 lights come on and say its engaged (dash and panel lights) even tried jacking all 4 tires off the ground to see if 4x4 would engage but when i hit the button the light comes on transfer case begins turning but front wheels dont turn.??? what's going on??
93junker is offline   Reply With Quote
Old 01-20-2006, 04:26 PM   #9
Critter92X
Lake of the Ozarks Mo.
Critter92X's Avatar
92 xlt 4x4, 02' EB 4x4
Vehicle Specs
Quoted: 0 Post(s)
Like jgilbs said there shouldn't be ANY grease in the hub. when you pull it off if there is try cleaning it out because that may be what's keeping it from locking in. I just use a light coat of gear oil on mine to keep it from rusting.
__________________
92 Explorer XL 4x4
02 Explorer EB 4x4
92 Harley Davidson XL 1200
Critter92X is offline   Reply With Quote
Old 01-20-2006, 04:32 PM   #10
Critter92X
Critter92X's Avatar
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Did you try locking it in and pulling forward before you jacked it up? I think the front wheels have to turn before the hubs lock in.If it's jacked up and you engage the 4x4 you might be able to spin the front wheels forward to lock in the hubs, I don't know for sure I never tried it that way.
__________________
92 Explorer XL 4x4
02 Explorer EB 4x4
Old 01-24-2006, 09:25 AM   #11
Tony H
New York, Wading River (that's on Long Island)
'91 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
If the light does not come on then it is not Hub related. It is Transfer Case Motor related.
If the light comes on and the front Driveshaft turns BUT you are not getting the front Tires to turn then it's Hub related. These hubs start to engage by the rotation of the front axles.
__________________
1975 CJ5 with fiberglass body and 350/345Hp chevy power:bought it in '79
1985 chevy stepside pickup, 300K on the clock: Original Owner
1989 Volvo 240 300K on the clock: Original Owner
the 1991 X is my newbie with 331K on the clock: bought OCT.'03 with 183K
http://home.lyse.net/brox/TonyPage4.html
Tony H is offline   Reply With Quote
Old 01-24-2006, 12:19 PM   #12
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Quoted: 3 Post(s)
Welcome to the site.. HUB only come into play once the Transfer case has shifted into 4x4 and powered the front drive shaft and axles. It is very common for the electronic shift motor on the T-Case to fail resulting in a No shift condition.. In most cases the fix is easy and cheap, check out the
Shift Motor repair thread for lots of info and pics... In most cases the plastic stop bumper has deteriorated and allowed the T-Case geared positon sensor to travel outside it's operational range.. As such when you press the dash 4x4 button the shift computer in the rear cannot determine where the T-case selector shaft is and will default into doing nothing...
__________________
John D-"Search first, Ask questions later" & "You can have my Explorer when you pry the keys from my cold dead hands." <<<Forum Rules >>>*My Truck*
4x4 Trouble Shooting Guide
See how cars work Axle and tire calculators U-joint replacement info/pics
Repair info NEX-New England Explorers NEX: Club Events
DeRocha is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
