Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Dropped your gas tank? Let me know!
Reply
Thread Tools
Old 06-05-2005, 07:13 PM   #1
V8BoatBuilder
Transplanted Bostonian
East Brunswick, NJ
V8BoatBuilder's Avatar
97 Mountaineer V8 4x4
Vehicle Specs
(Original Poster)
I need to remove my 21 gal gastank for my t-case swap. if you have dropped your gas tank, I would love to hear about it, what probelsm you encountered, tips, etc.
__________________
-Aaron
Off Road: 97' Mountaineer: V8, 4x4, 4.56s, 4" Superlift, SOA, TrXus 33x12.5 - Under The Knife
Work: 00' Ranger 4cyl 5spd, 02' Ford E250 5.4
On Road: 2006 VW Jetta TDI/6spd DSG. Fill it with diesel, please.
Octopus Yachts, LLC Engineered Marine Electrical Systems
V8BoatBuilder is offline   Reply With Quote
Old 06-05-2005, 07:24 PM   #2
Doug
I'm Awesome!
Home is where the Army tells me. Right now it's Manorville, NY
Doug's Avatar
Vehicle Specs
Just remove the straps that hold the gas tank up. Also make sure it's empty or close to it. It only takes about 15 minutes, it's not anything to worry about.
__________________
97 Explorer
Life's hard. Wear a helmet.
Doug is offline   Reply With Quote
Old 06-05-2005, 07:29 PM   #3
RangerX
Moderator
Elite Ranger
Omao, Kauai
RangerX's Avatar
'93 Ranger XLT 4X4
Vehicle Specs
Skidplate comes off first, if you have one. Use a floorjack with a ~2' piece of 2x6 on it to support the tank as you lower it. Watch the gas lines and wiring as it comes down.
__________________
Bill Collins
93 Ranger XLT 4X4
"Beauty is only sheet metal deep."
RangerX is offline   Reply With Quote
Old 06-05-2005, 07:36 PM   #4
Brian_B
Mountain Home, AR
Brian_B's Avatar
2000 mounty / 56 f-100
Vehicle Specs
I have dropped mine on the ranger. I siphoned out most of the gas and removed the skid plate. I then set a floor jack under it with a wide board on it (didn't want to dent or puncture it) and unbolted the straps. Nothign to it. Just reverse to put it back.
__________________
56 f-100, short bed, 272 "Y" block V8, 3 speed standard, 3.73 rear gears.
Oh...I have a 2000 mountaineer as well.
Brian_B is offline   Reply With Quote
Old 06-06-2005, 08:57 AM   #5
RangerX
Moderator
Elite Ranger
Omao, Kauai
RangerX's Avatar
'93 Ranger XLT 4X4
Vehicle Specs
This link might help some. http://draco.acs.uci.edu/explorer/fuelpump2.html
__________________
Bill Collins
93 Ranger XLT 4X4
Old 06-06-2005, 10:04 AM   #6
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
remove skid plate, support tank, remove straps.
ONce its down a little disco the filler neck, lines, and wiring.
Its not that bad, first time might take a couple hours total.
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
Wifes 07 FJ build - 2007 FJ cruiser locked and lifted
410Fortune is offline   Reply With Quote
Old 06-06-2005, 10:42 AM   #7
Bronco638
Nobody Home
Itasca IL
Bronco638's Avatar
'96 XLT 4.0L OHV
Vehicle Specs
Just Curious.
Why do you need to drop the gas tank to swap t-cases? I went from a 4405 to 1354 and this wasn't necessary.
Bronco638 is offline   Reply With Quote
Old 06-06-2005, 10:48 AM   #8
clarkkent
san luis obispo, CA
McNeil Mountaineer
Vehicle Specs
sweet, this is a useful thread, hehe i needa swap mine out cause of that damm hole.
*subscribed
__________________
"Can I fit 44 inch tires on a body lift?"
clarkkent is offline   Reply With Quote
Old 06-06-2005, 10:50 AM   #9
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
did I mention how lame I think the drivers side mounted tank is on the explorer?
hahahaha
__________________
Old 06-06-2005, 11:53 AM   #10
clarkkent
san luis obispo, CA
McNeil Mountaineer
Vehicle Specs
Quote:
hahahaha
haha i feel ya. last night my driver side leaf springs spreaded like a fan and stabbed my gas tank, now i have this hole.... hey 410, do u kno how hard it'd be to upgrade to a broncoII gas tank and mount it in the middle? mounting it wouldnt be hard, but what about the fuel pump and guage and stuff?
__________________
Old 06-06-2005, 12:10 PM   #11
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
the big problem is the height of the BII tank and the Explorer floor, also there is a crossmember that picks up your spare tire AND the shocks a totally different.
So yeah its a little bit of work But the BII tank is 23 gallons, has a semi beefy skid plate (I have performed rock and concrete modifications to my 17 yer old unit, its not shaped the same but there is still room for more denting before I hit the tank), its metal, and will accept a en Explorer fuel pump (BII uses dual pumps until 89, then single like an Explorer).
It has been done, Rangers are easier, body lift helps, might be worth a look if you want more weight in the back, more capacity, etc...
__________________
Old 06-06-2005, 07:58 PM   #12
V8BoatBuilder
East Brunswick, NJ
Vehicle Specs
(Original Poster)
Quote:
Originally Posted by Bronco638
Just Curious.
Thanks for all the advice guys!! However the project will have to wait, as I just took a 2 week, 12 hour/day job working on a movie shooting in Boston as "Vehicle Coordinator." Something has to pay for the mods!
Bronco,
I have a 4404 AWD t-case, and am swapping in a 4406 t-case from an Expedition. It's much, much larger than the explorer cases.
__________________
-Aaron
Old 06-07-2005, 09:29 AM   #13
Bronco638
Nobody Home
Itasca IL
Bronco638's Avatar
'96 XLT 4.0L OHV
Vehicle Specs
Quote:
Originally Posted by V8BoatBuilder
Bronco,
Got it!
Thanks and good luck with your new job!
Old 06-07-2005, 10:49 AM   #14
Nitrous SSC
Layton, UT
98 Eddie 3-oh-2
Vehicle Specs
If you really want an easy job. Extend your hose that goes into the fuel filter to a 5 gallon can when you're almost out of gas. Jump the relay and turn the pump on. drain your tank completly and it weighs next to nothing and is 50 times easier to move around without gas shloshing around.
I do this when ever I have to pull any tank...
__________________
Matt H.
04 Merc Marauder (daily)
90 GT, Built/Blown 347
01 SVT Cobra, 03' drivetrain Wife's car.
Nitrous SSC is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
