Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
My 4L SOHC set codes & failed state inspection
Reply
Thread Tools
Old 06-10-2005, 10:30 AM   #1
kponhlo
Niskayuna, NY
'97 XLT
Vehicle Specs
(Original Poster)
Please help. My '97 4L SOHC set Powertrain codes 442, 420 and 174. Not havng a lot of time or $$$ right now I tried clearing them to pass the new OBDII state inpection but then failed anyway - I have to drive it 200 miles so it can reset the codes and they gave me ten days to do that.
According to the book, the codes mean the following:
442 - EVAP small leak detected
420 - Catalytic system bank 1 efficiency too low
174 - System adaptive fuel too lean on bank 2
It idles a little rough when warm; during winter it would race, then bog, then race again during warmup. I have heard about the plastic intake/gasket issue, and have even bought the gaskets. Will that fix any or all of the described symptoms/codes???
I didn't have to drive it much for the past year or so, but now I really need it. Any thoughts are greatly appreciated.
Thanks,
-Keith
kponhlo is offline   Reply With Quote
Old 06-11-2005, 01:32 AM   #2
captTelescope
Orange County, CA
98 XLT 4.0 SOHC 4WD
Vehicle Specs
Here's a few suggestions on where to start.
For the 442, examine your hose connections to/from the EVAP cannister. Look for possible leaks. Fix anything suspicious. Make sure your gas cap is on tight and doesn't leak.
The 420 code is likely to hurt. It could be the Cat, but also O2 sensors. Suspect the downstream sensor (on the Cat's outlet). If you don't have proper diagnostic equipment, you could waste a lot of money throwing expensive parts at this problem. Or you could take it to a dealer (ouch) and get 'er done.
The 174 could be clogged fuel injectors, especially if the Ex has been sitting. Try a FI cleaner. That's cheap enough. Or it could be the upstream O2 sensor. Or the fuel filter. Or the fuel pump, check fuel pressure. Again, the dealer (theoreticly) could fix you right up.
__________________
Red! 1998 Explorer XLT, 4WD, 4.0 SOHC
Pinstriping by Desert Vegetation
Free advice... worth every penny.
captTelescope is offline   Reply With Quote
Old 06-11-2005, 12:04 PM   #3
CDW6212R
Knoxville, TN
CDW6212R's Avatar
98 Mountaineer A4WD
Vehicle Specs
Do as much of the tune up work that you can, before having to go to a shop. Include the normal stuff, and fuel injector cleaner, possibly Seafoam too. Good luck,
Don
__________________
Don
91 Lincoln LSC/SE, 99/93 Explorer Limited 4WD, 98 AWD Mounty with 255/55/18's, big sway bars, and 12.75" x 1.25" rotors. Soon a BW4406, built trans, stereo and interior.
The best thing that could help us all, is the Fair Tax Plan.
Be American, Buy American (Manufacturer)
CDW6212R is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
