Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer - Ranger Tires & Wheels
Notices
Ford Explorer - Ranger Tires & Wheels Want to know what size tire or wheel combo will work with your Ford Explorer or Ranger based vehicle? Interested in Beadlocks or Dubs? Learn all about them here.
Info On Tire Pressure Monitoring Systems (TPMS)
Reply
Thread Tools
Old 10-22-2005, 01:19 PM   #21
X-Cited
State of Shock
'05 Limited
Vehicle Specs
Angry Pita Tpms!!!
Quote:
Originally Posted by rick chi-town
I just put 20in Roush rims on my 2005 Expy equipped with the TPMS.... So now, every time I get in the car, I have to reset the on-board display with the error message "TIRE PRESSURE MONITOR FAULT" kind of a PITA!
I replaced the stock 17" chrome wheels with 20" U2 wheels. The sensors would fit the new wheels, but there would only be 1-1/2" inch of clearance between the sensors and the floors of the new low profile (P275/45/R20) tires. Therefore, I did not transfer the sensors to the new tires.
Neither my dealer nor Ford's Customer Relationship Center could tell me how to deactivate the TPMS. They had to have realized that people would want to use aftermarket wheels that might not accommodate the TPMS sensors. I'm still trying to find the one person at Ford who knows how to TURN OFF the TPMS.
In addition to the TMPS aggravation, the no one at Ford seems to know how to turn off the auto-dimming feature of the windshield rearview mirror. It still works even after I unplug the wiring harness. My rear windows came tinted very dark. At night, the auto-dimming feature makes it impossible to see anything except the headlights of the cars behind me. Therefore, I have to turn it off everytime I get in the SUV at night.
Other than these two aggravations, I love my '05 Explorer.
X-Cited is offline   Reply With Quote
Old 10-22-2005, 01:40 PM   #22
ExplorerDMB
Moderator/Technician
Mechanicsville, Virginia
2004 Acura TL
Vehicle Specs
(Original Poster)
Looks really good. Sorry to hear your frustration. You should look at see if the TPMS has a fuse. If it does, pull it and see what happens. Now that you have the new wheels on, whats the TPMS doing? Blinking at you?
-Drew
__________________
My Useful Threads (38 Entries and Growing)
ExplorerDMB is offline   Reply With Quote
Old 10-22-2005, 03:00 PM   #23
X-Cited
State of Shock
'05 Limited
Vehicle Specs
Thanks for the compliment. When I first start turn the ignition, there is a loud beep and a warning message "TIRE PRESSURE MONITOR FAULT" on the message screen and the yellow TPMS icon under the speedometer blinks. Hitting the "RESET" button clears the alarm. The alarm also sounds every 45-60 minutes of continuous driving.
I thought about the fuse, but other things are on the circuits. The TPMS actually has two fuses: fuse #16 is for the power mirror, manual climate control, and TPMS; fuse #25 is for the mode-temperature actuator for auxilliary climate control, trailer tow battery charge relay coil, and TPMS. I have no idea which TPMS function is on which circuit.
Oh, by the way, I forgot one other aggravation: no power antenna. Everytime I go to the car wash I have to unscrew the antenna and cover the hole with electrical tape so that water won't get down there and cause a rust problem.
Old 11-03-2005, 10:17 PM   #24
ExplorerDMB
2004 Acura TL
Vehicle Specs
(Original Poster)
Little bit of an Update:
Beru AG and Lear are making the TPMS systems for Ford (and a lot of other companies). More information here: Beru AG and here
Here is another link for other stuff: http://www.mtdealer.com/t_inside.cfm...t&storyID=4227
-Drew
__________________
Old 11-10-2005, 10:02 PM   #25
ExplorerDMB
2004 Acura TL
Vehicle Specs
(Original Poster)
Someother cool stuff:
AutoPump System:
A new advanced tire pressure monitor system from SmarTire has been tested on some prototype Jeeps. This system or one similar may appear on future models. In conjunction with an automatic tire AutoPump made by Cycloid, this combined system automatically and continously re-inflates tire pressure to a specified level, ensuring optimal inflation of tires under different situations and temperatures.
The inertia compressor is only 1" thick by 3" in diameter and weights a mere 8 ounces. Its expected design life is 130,000 miles, with ten years of battery power. The system has been shown at some past auto shows in the U.S., installed in the Grand Cherokee Concierge prototype concept car.
Just some random stuff about the actual TPMS:
-Drew
__________________
Old 01-09-2006, 06:10 AM   #26
ExplorerDMB
2004 Acura TL
Vehicle Specs
(Original Poster)
bump
__________________
Old 01-09-2006, 08:27 AM   #27
SuRrEaLNJ
hail to the king, baby!
out of my mind...
SuRrEaLNJ's Avatar
MUNK 07 Focus 97 XL1200C
Vehicle Specs
Good wealth of information DMB
while i agree that this is a usefull feature if you want it, it can also be a real PITA. There should be a way to disable the system in a situation such as airing down the tires. When droped to 18-20 psi for traction the system beeps and displays a message in the message center. hiting reset clears the message temperarily, but it continues to come back with another beep and message. After 8 hours of being in an aired down state this REALLY starts to get on your nerves.
__________________
Quote:
Originally Posted by Spas View Post
You are all lunatics, and Jay is your king!
BEN REALLY REALLY LOVES PINK
SuRrEaLNJ loves Hannah Montana
SuRrEaLNJ is offline   Reply With Quote
Old 01-09-2006, 11:47 AM   #28
ExplorerDMB
2004 Acura TL
Vehicle Specs
(Original Poster)
The problem with allowing people to air down is that is sometimes a way for the TPMS Module/Computer to see that it is time for "relearn" process. There a few vehicles out there that when you aggressively air down the horn will beep and there is a certain way to go about relearning for that vehicle. So if someone is airing down and the horn beeps and he goes about his business, he's goin to have a huge F*-Up.
In '07 it's suppose to be manditory on all US Vehicles. Some are making it state inspection. It's a great feature, for someone that wants it. With the way the world is now with customizing and accessories - manufacturers and aftermarket are now butting heads.
-Drew
__________________
Old 01-15-2006, 01:08 PM   #29
ExplorerDMB
2004 Acura TL
Vehicle Specs
(Original Poster)
bump
__________________
Old 01-24-2006, 11:58 AM   #30
FJB20
Phila.,Penna.
2006 XLT
Vehicle Specs
I would love to know how to go in with a computer or whatever to deactivate the system -- I bought the 17" chrome wheels that come on the 06 Limited for my 06 XLT- No sensor on the new wheels- Now I have to hit reset every time I start the car and there isn't a tool to take the sensors off the old wheels and put them on the new - You have to buy new sensors at $70.00 a rattle
FJB20 is offline   Reply With Quote
Old 01-24-2006, 04:17 PM   #31
ExplorerDMB
2004 Acura TL
Vehicle Specs
(Original Poster)
The sensors are actually easy to take off, but you have to break down the wheel/tire and get the tire somewhat off the wheel and then get the sensor. I have a feeling the sensors are the same (for the stock wheels and limited wheels) you just have to make sure. I wish you were closer cause I could help you out.
-Drew
__________________
Old 01-24-2006, 05:33 PM   #32
FJB20
Phila.,Penna.
2006 XLT
Vehicle Specs
Drew -- Thank You -- When I ordered the XLT I then went to parts to order the chrome wheels that were only available on the Limited or EB (311.00 a piece )
No sensors in them and didn't know that I needed them -- Bought 275-60-17 Tires
and had the whole works put on the XLT - What a difference - Now I've got the 24/7 Low Pressure Alarm that has to be reset when you start the car - Don't have a problem with having the tires taken off but I wish there was more info or a take off and remount tool so I could take the tire guys thru the procedure - I'd like to keep the integrity of the car so that if someone else drives the car they don't think they're getting a flat-- And now you have the WISEGUYS - Nice tires Frank-Wanna push the reset and kill the tire lamp on the dash ---Thanx Again
Old 01-24-2006, 05:57 PM   #33
ma96782
Vancouver, WA
'94 XLT, 4dr
Vehicle Specs
Think, "cost benefit analysis"...........IMHO............it's not worth it.
Just more things to go wrong and cost me more money to repair.
Typical.....liberals in government.....want me to pay.....cause, they think I'm not smart enough to check my tire pressure. So, they mandate the auto mfn to put that (TPMS) in.
Aloha, Mark
ma96782 is offline   Reply With Quote
Old 01-25-2006, 12:08 PM   #34
FJB20
Phila.,Penna.
2006 XLT
Vehicle Specs
Damn shame there isn't an easy way to disable the TPMS -- I don't have the dash with the menu in it (2006 XLT) I'm told you can disable the system with that dash - I think the EB or Limited has it
THANX
Old 01-25-2006, 01:14 PM   #35
ExplorerDMB
2004 Acura TL
Vehicle Specs
(Original Poster)
Well in 07 you probably won't be able to disable it (easily atleast) because it will be mandated by the government.
-Drew
__________________
Old 01-29-2006, 03:29 PM   #36
Crizz
Germany / Hessen
Crizz's Avatar
actually none
Vehicle Specs
Very interesting thread. Got my 006 Eddie on Sat., and it´s equipped with TPMS. ( I´ve ordered a 2006 XLT V8, don´t know who is responsible for shipping a V8 Eddie to GE, but I´m not mad on it ).
Only prob : I want to use the 18" plastic-chrome-covered-wheels only for winter, for summertime i´m interested in Cragar-Wheels with a little wider tires ( 275/60 17 or 255 /60 18 ). Does anybody figured out how to disable the TMPS, or where to get aftermarket-sensors that fit the Ford-TPMS ?
I haen´t found a fuse esp. for the TPMS and I´m not sure if it´s embedded on the EEC / OBD...
__________________
act. no Explorer - History : ´90 XLT Shifter, ´98 XLT, 2006 Eddie V8
Crizz is offline   Reply With Quote
Old 01-29-2006, 04:34 PM   #37
ExplorerDMB
2004 Acura TL
Vehicle Specs
(Original Poster)
It uses it's own computer like a brake module (ABS). Right now, no one on here has found a way to disable it. My best advice is to get ford 17s and put their sensors on there and then learn them to the transmitter in the vehicle. TPMS will be hard to get around til aftermarket companys find a way. As of to my knowledge, everyone in the aftermarket world is still developing wheels.
Also, it's not only the wheels that are cause problems (cause the sensors have to sit flush against the wheel), its the people that want to use 22s and have hardly any tire/rubber on the sidewalls. You know how you bend a wheel? Well when you hit the curb or pot hole or whatever else, you run the risk of snapping that sensor and buying yourself 80-100 sensors every other week.
-Drew
__________________
Old 01-30-2006, 12:13 AM   #38
Crizz
Germany / Hessen
Crizz's Avatar
actually none
Vehicle Specs
Drew, I still wonder why they put a TPMS on a SUV / CrossTerrain-Vehicle... Would have made more sense to give the driver the choice of enable/disable this feature for using Non-TPMS-wheels. But like wie know : that´s the way to sell parts.
__________________
Old 01-30-2006, 11:12 AM   #39
ExplorerDMB
2004 Acura TL
Vehicle Specs
(Original Poster)
Granted - but with the %'s of Explorers out on the roads, they are found more in grocery store parking lots than desert terrain. See what I'm saying? To them it's more practicle to have it than not. Plus by 07 it is mandated in the US. So they are trying to get any kinks out as possible
-Drew
__________________
Old 01-30-2006, 12:36 PM   #40
Crizz
Germany / Hessen
Crizz's Avatar
actually none
Vehicle Specs
I know, Drew.... it´s the same like the "Big M.´s" CoffeeCups : "content may be hot"...
But in GE we´re going close to that, just a matter of time. It´s not really fun anymore over here, it I would be a little younger or a good job-offer over there... Wouldn´t take much to make me move.
__________________
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
