Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Replacing Multifunction Switch
Reply
Thread Tools
Old 06-27-2005, 12:21 PM   #1
aldive
Elite In Memoriam
aldive's Avatar
1999 XLT
Vehicle Specs
(Original Poster)
The multifunction switch on my ’99 has been infected with a poltergeist for quite some time; the wipers come on whenever it suits them.
This integrated multifunction switch controls the turn signals, hazard flasher, windshield wiper/washer control, headlamp dimmer/flash-to-pass.
I finally decided to replace the switch.
The switch, part number YL5Z13K359AAA, cost $66.48 at my local Ford dealership.
The first step is to disconnect the negative battery cable. Next, the 3 screws that hold the steering column shrouds on were removed and upper and lower steering column shrouds. This fully exposes the multifunction switch and its two Allen head screws which are then removed. The two electrical connectors are removed.
Installation is the reverse of the above procedure.
The total time involved in this project was about 20 minutes.
Alas, the poltergeist has been exorcised; all functions controlled by the multifunction switch have been restored to normal.
__________________
Al Franklin
My truck
My Quest for 30
RIP Al Franklin! 1947-2010. Gone but not forgotten! :(
aldive is offline   Reply With Quote
Old 06-27-2005, 12:45 PM   #2
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
I'm on my 4th one, every time I hit a junk yard I grab one or two....88 parts are discontinued these days...
Funny thing is each time I replaced it, except for the first time it ended up being something else (bad wire) so I have 6 or 7 of these suckers sitting around that work....hahahah yeah yeah so typical of my truck..
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
Wifes 07 FJ build - 2007 FJ cruiser locked and lifted
410Fortune is offline   Reply With Quote
Old 06-28-2005, 09:14 AM   #3
aldive
Elite In Memoriam
aldive's Avatar
1999 XLT
Vehicle Specs
(Original Poster)
Several interesting things happened since replacing this switch ( I assume the exorcism was incomplete ).
First, the seat belt alarm started working again ( http://www.explorerforum.com/forums/...d.php?t=137840 ).
Second, the chime that signifies that the lights are on when the door is opened sounds off whenever the door is opened. This is quite annoying.
__________________
Al Franklin
My truck
My Quest for 30
Old 06-28-2005, 09:35 AM   #4
BuffaloXplorer
The X had to go!
Buffalo, New York
BuffaloXplorer's Avatar
2006 Impala SS
Vehicle Specs
Quote:
Whether or not the lights are actually ON?
__________________
Chris
2006 Impala SS
Black on Black Leather
303hp V8 w/DOD - XM Radio
Adios 1996 Explorer Conversion - 4.OHV6
BuffaloXplorer is offline   Reply With Quote
Old 06-28-2005, 09:45 AM   #5
aldive
Elite In Memoriam
aldive's Avatar
1999 XLT
Vehicle Specs
(Original Poster)
Quote:
Yes; totally independent of the lights. Strange, very strange,
__________________
Al Franklin
My truck
My Quest for 30
Old 06-28-2005, 10:21 AM   #6
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
you have completed many chime circuits
__________________
Old 06-28-2005, 10:31 AM   #7
aldive
Elite In Memoriam
aldive's Avatar
1999 XLT
Vehicle Specs
(Original Poster)
Quote:
I do not understand??????? Sorry.
__________________
Al Franklin
My truck
My Quest for 30
Old 09-08-2005, 08:35 PM   #8
mshuffler
Wilmington, NC
96 Eddie Bauer
Vehicle Specs
Switch gremlins
I have been fighting a lot of the same symptoms. At first my switch had several problems: hazard did not work, wipers would change speeds without touching the switch, blinker would buzz every now and then. I changed the switch with one out of the junkyard and it fixed almost everything. Now my only problem is a buzz in the right turn position. If I hold the switch a little to the right it will blink ok. I changed the flasher relay (under the dash) and it did not help. I'm guessing that I got a bad switch. I guess I will try a new one from the ford dealer. Let me know if you have any other ideas.
mshuffler is offline   Reply With Quote
Old 09-08-2005, 08:42 PM   #9
ExplorerDMB
Moderator/Technician
Mechanicsville, Virginia
2004 Acura TL
Vehicle Specs
Good post Al. Sorry to hear your still having little problems with your switch.
-Drew
__________________
My Useful Threads (38 Entries and Growing)
ExplorerDMB is offline   Reply With Quote
Old 09-09-2005, 12:54 PM   #10
00XLS
Frackville/State College PA
Explorer 00 XLS
Vehicle Specs
Man and I thought my spontaneous tact was annoying, Good luck
__________________
2000 4dr. 4x4 XLS 4.0 OHV 3.73's K&N,throttle cable mod. Brown wire 2wd, Mobil 1, Air Box mod. w/ K&N, TT &shackles, 31 Goodyear Wrangler SA, Silverstar Ultras, Alpine HU, Sirus Satrad.
00XLS is offline   Reply With Quote
Old 09-11-2005, 08:25 AM   #11
OZY EXPLORER
QLD AUSTRALIA
1999 XLT
Vehicle Specs
AU
Quote:
My xlt 99 suffered from the buzz instead of the blinkers working so last week I went to Ford and clained it on the extended warranty and they replaced it no charge.Ford has also come to the party on new cam chain ajustors and gas struts for the hood (amazing since there is only 6000k to go on the warranty)
__________________
OZY EXPLORER is offline   Reply With Quote
Old 09-13-2005, 10:07 AM   #12
Cali' Explorer
Sacramento, CA
'97 XLT 5.0
Vehicle Specs
The buzz means you got another bad multi-function switch. If adjusting the handle makes the blinkers work properly, then its the switch and nothing else. Buy a new one, it'll save you time in the long run.
Also, just for some of your knowledge, I was having some somwhat similar problems in my 1997 V8. Whenever I would turn the blinker left without actually locking it into the left turn (IE: Just holding enough for blinker), a nice puff of electrical smoke would pop up from the steering column. It would also deactivate my Cruise Control if it was engaged. And ironically, only the left turn, not the right one.
This is evidently very common, has something to do with the grease in the contact getting old. I was going to replace it, but held off, and now everything works fine as it did before, even if I just hold it enough to blink... weird.
__________________
Steven West
Sadly, I'm Explorer-less now....
Cali' Explorer is offline   Reply With Quote
Old 11-03-2006, 12:27 PM   #13
marragtop
balt, md
91 xlt, 92 xlt, 95 xlt
Vehicle Specs
BTW... rockauto.com has the switch for $34.....
__________________
'88 F150 4x4
'91 Explorer XLT 4x4
'92 Explorer XLT 4x4
'95 Explorer XLT 4x4
If it don't = 16 (4x4), it ain't worth driving...
marragtop is offline   Reply With Quote
Old 11-11-2006, 12:05 AM   #14
Fish Man
Marietta, GA
1995 Explorer XLT
Vehicle Specs
i bought the switch on ebay new for $20 since mine was doing the annoying buzz thing. just a note: to get the shroud off you have to take the tilt column lever off, which i couldnt figure out how to do so i just worked around it, which was a pain. also, its torx screws that hold in the switch.
__________________
1995 XLT 4x4 4.0L TT, AAL, Warrior Shackles, 3" PA body lift, Flowmaster, K&N, Pioneer DEH P7500mp HU, JBL P300.1 pushing a Memphis 10 in a stealth box, JBL BP80.4 running Autotek and MA components in some Q Logic kick panels, 33" BFG Mud Terrains on 15x8 AR-23s.
My (really old) CarDomain Page
Fish Man is offline   Reply With Quote
Old 12-10-2006, 10:39 PM   #15
jfman
Georgia
92 manual tranny
Vehicle Specs
Quote:
20$ for a new one ?
jfman is offline   Reply With Quote
Old 12-11-2006, 06:56 AM   #16
COBRA_ESQ
Long Island, N.Y.
95 4Dr 4x4 XLT
Vehicle Specs
To all who responded with all the help THANKS!
It turned out to be a wire was pinched in the steering column and after 170,000 miles it went.
Down side, I purchased a new switch from Ford. Hopefully they will take it back.
__________________
1995 Explorer XLT 4x4
2003 Cobra Convert (Factory Supercharger YEE HAA)
2005 Escape
COBRA_ESQ is offline   Reply With Quote
Old 12-11-2006, 12:45 PM   #17
jfman
Georgia
92 manual tranny
Vehicle Specs
If not let me, give me aprice shipped to zip code 30044.
Old 12-12-2006, 05:16 PM   #18
COBRA_ESQ
Long Island, N.Y.
95 4Dr 4x4 XLT
Vehicle Specs
jfman
sent you a private message
__________________
2005 Escape
Old 12-13-2006, 03:13 AM   #19
reserved50
mooo
1997 XLT SC'd 5.0/331
Vehicle Specs
I opened mine up because the one from the wrecking yard i put on was worse than what I had, no washer misting and headlights flickered, I couldnt see any wear just minor tracks where the contacts contacted so i used a mini wire cup brush for a dremel and applied dielectric grease to all the contatcs<----opening the switch is waaaay easier said than done, total pain(if you can build a model car with your eyes closed this should be no problem:p)
reserved50 is offline   Reply With Quote
Old 12-13-2006, 01:24 PM   #20
jfman
Georgia
92 manual tranny
Vehicle Specs
Paypal sent Cobra ESQ
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
