Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Offroad Tech Forums > Offroad Explorer - Ranger Projects
Notices
Offroad Explorer - Ranger Projects Big projects... Lifts, Swaps, etc... IMPORTANT As the subject use your name, or the name of your truck, and the name of the project. Such as Superlift 5.5" installation, Dana 44 conversion, etc.
Starting full width D44 SAS...B4 I order, what do you guys think??
Reply
Thread Tools
Old 04-09-2007, 12:06 AM   #181
Kirby N.
Ogden, UT
1993 Sploder
Vehicle Specs
Quote:
Originally Posted by james t View Post
I dont think you're going to be able to use an off the shelf draglink. Yes, the draglink and the tracbar are supposed to be at the same angle... or at least really close. You can change this by going with a straight draglink or raising the tracbar mount at the frame.
If it were me i would leave it as-is for now, and start rounding up stuff to do the GM one ton tierod flip in the future. All you need is a reamer, 4 TRE's, and some tube for a draglink and tierod. Thats the bad thing about the F150/big Bronco knuckles... the steering arm is really low. This makes the tie rod very vulnerable. Flip the TRE's to mount over the knuckle and this gets everything up out of the way. If you plan on wheeling it in anything other than mud then i would take the stabilizers off as they are going to get torn off.
Here's what your angle should look like with a straight draglink-
What? His angle looks fine. You can have all kinds of bends in a draglink, but the two end mounts are what determines the opperating angle. Straight or bent, draw a straight line between the two joints on the end of your drag link, and that angle is what is important. You can have a W bend in it and the geometry will be based on the ends it pivots on. That line James has drawn is the angle that counts, despite the fact that it is bent. That line looks pretty parralell to your trac bar to me. Might be a different length though.
ID is right on...
__________________
SOLD 93 Sploder- HP Dana 44 Front, 37" MTRs, 4.56s, 1354 doubler, ARB, Detroit, Winch, Kirby Built Armor, etc...
05 Jeep Rubicon Unlimited LJ 4" Lift, 33s,
94 F150
Kirby N. is offline   Reply With Quote
Old 04-09-2007, 03:01 AM   #182
ohe_boy
Kane'ohe, Hawaii
ohe_boy's Avatar
'94 4x4 XLT
Vehicle Specs
(Original Poster)
thanks for the bumpsteer lesson ld50. I never knew thats what bumpsteer was. I thought it was the pulling of your vehicle to one side when you hit a bump or an uneven road. My steering just seems "loose" as if it had very little power steering control. My steering sways from 11 o'clock to 1 o'clock when driving. Is this normal for a solid axle?
Anyway I know the angle is good but I gotta check the lengths between the two. See how close or off they are.
The backspacing on the wheels are common for a 15x10. I think its 3.45
THANKS FOR THE COMMENTS GUYS!!!!
__________________
Kea Hottendorf - '94 4X4 XLT, FULL WIDTH HP Dana 44 up front with FULL WIDTH Ford 9" in the rear. 4.88 gears Lockright front and detroit back 36'' IROKs 3" BL, KKM Air Filter, Flowmaster 50 series,
My SAS Thread
ohe_boy is offline   Reply With Quote
Old 04-09-2007, 05:32 AM   #183
james t
moderation
Texarkana AR/TX
james t's Avatar
94 SAS sport
Vehicle Specs
Quote:
ID is right on...
It is close, but not dead on. Having the draglink at the same angle as the tracbar is more critical than having them the same length (or close to the same length). Yes, lD50 is right... but the draglink/trac bar angle is what causes the most bumpsteer.
__________________
my rebuild
"It started as a hobby, slowly turned into a lifestyle, then spiralled downward into mental illness. My lawnmower has tree rash on it."
james t is offline   Reply With Quote
Old 04-09-2007, 11:58 AM   #184
ld50
Oh, the money you`ll blow
British Columbia
ld50's Avatar
93 4 dr 4x4 manual XL.
Vehicle Specs
I would think not. I`m just working out my steering for solid axle now, and I`m taking my time to ensure both the lengths and angles are as close as I can get them, since both can be a problem if out. -so I can`t tell you how mine feels yet.
__________________
Jim from BC - My Mugshot
All My Mods And How I did Them
ld50 is offline   Reply With Quote
Old 04-09-2007, 04:40 PM   #185
sn0border88
Master Apprentice
Souderton, PA
sn0border88's Avatar
1992 XLT
Vehicle Specs
mine does, terrible bumpsteer. But I can still manage. Going histeer "should" fix it
__________________
My Photos---Emily Rose---SAS Thread---My Mug
1992 4dr XLT. SAS'ed HPD44/9" 5.13's Locked F/R 36" SX
1999 4.0 5spd sport on 31" BFG Muds
sn0border88 is offline   Reply With Quote
Old 04-09-2007, 04:42 PM   #186
FROADER
Moderator
Huntington Beach, CA
FROADER's Avatar
Vehicle Specs
Mine does not. I have "normal" play in the steering.
FROADER is offline   Reply With Quote
Old 04-09-2007, 11:51 PM   #187
Mud Bug 94
Bloomingdale, N J
Mud Bug 94's Avatar
94 XLT-367k miles
Vehicle Specs
all you need to do is figure out which way it steers when you hit a bump... (most likey to the right) and right befor you hit a big bump jerk the wheel hard to the left to compensate...lol
__________________
94 xlt 4 door, 32's 4 inch shackles and custom tube bumpers with tire carrier
Mud Bug 94 is offline   Reply With Quote
Old 04-10-2007, 01:24 PM   #188
colindo94
Cameron Park, CA
94' XLT
Vehicle Specs
ohe boy- I'm in the process of starting my SAS and I was wondering what bracket you used for the trackbar and what you used for steering linkage? Forgive me if you already said what you used, but i'm pretty sure you have not.
__________________
Full width Dana 44/8.8, 36x12.5 TSL radials
Ostman Bros. Fab Shop
colindo94 is offline   Reply With Quote
Old 04-11-2007, 12:25 AM   #189
ohe_boy
Kane'ohe, Hawaii
ohe_boy's Avatar
'94 4x4 XLT
Vehicle Specs
(Original Poster)
james t - as I was looking at my steering linkage, I noticed that the bend in the drag link should normally be at the top by the pitman arm. I flipped the drag link and now the angle is JUST about parallel to each other. By flipping it around and setting the bend in its natural position, this makes the bend pointing foward instead of pointing downward. WIth the red line you had drawn out in the earlier post, this makes the draglink in that same line.
Steering has improved but the bumpsteer is still there. Just not as much. Maybe I need 4 stablizers instead of just two!
__________________
My SAS Thread
Old 04-11-2007, 12:26 AM   #190
ohe_boy
Kane'ohe, Hawaii
ohe_boy's Avatar
'94 4x4 XLT
Vehicle Specs
(Original Poster)
Quote:
I am also thinking that I shouldn't have that much play in the steering but let me know when/if you find out something!
__________________
My SAS Thread
Old 04-11-2007, 12:28 AM   #191
ohe_boy
Kane'ohe, Hawaii
ohe_boy's Avatar
'94 4x4 XLT
Vehicle Specs
(Original Poster)
Quote:
Yah its manageable,...just gotta keep a firm grip on the wheel!!!! Wish theres something to improve this!!!
__________________
My SAS Thread
Old 04-11-2007, 12:28 AM   #192
Burns
EF Late Night Crew
Memphis, TN
Burns's Avatar
1991 Explorer/2002 F-250
Vehicle Specs
Man im trying to think of what could be causing this. I dont have any at all. Like Colin i have regular steering play but thats it.
Burns is offline   Reply With Quote
Old 04-11-2007, 12:31 AM   #193
ohe_boy
Kane'ohe, Hawaii
ohe_boy's Avatar
'94 4x4 XLT
Vehicle Specs
(Original Poster)
Quote:
What is considered "normal" play? When I drive my wife's saturn (car) the steering wheel barely moves at all when trying to keep the vehicle straight. My hand just remains at 12 o'clock position and its all good. My X, inorder to keep that baby straight requires movement from 11 to 1. WTF??
__________________
My SAS Thread
Old 04-11-2007, 12:32 AM   #194
ohe_boy
Kane'ohe, Hawaii
ohe_boy's Avatar
'94 4x4 XLT
Vehicle Specs
(Original Poster)
Quote:
Ey don't laugh out loud.......
I really do that!!!! hahahahahaha
__________________
My SAS Thread
Old 04-11-2007, 12:33 AM   #195
Burns
EF Late Night Crew
Memphis, TN
Burns's Avatar
Vehicle Specs
Quote:
I have that play. I have been trying to get it tighter for a while. I dont think its in the axle but from steering box up.
Old 04-11-2007, 12:36 AM   #196
ohe_boy
Kane'ohe, Hawaii
ohe_boy's Avatar
'94 4x4 XLT
Vehicle Specs
(Original Poster)
Quote:
track bar bracket is from the broncograveyard website for full size broncos! I just welded it to the frame and coil bucket. I have brought this up in the beginning of this thread and I think theres pictures of it on the second or third page of this thread.
The steering linkage - pitman arm superlifts; draglink stock explorer bought new one from explorer express; tie rod - stock bronco from broncograveyard
hope this helps good luck with your SAS
__________________
My SAS Thread
Old 04-11-2007, 12:36 AM   #197
ohe_boy
Kane'ohe, Hawaii
ohe_boy's Avatar
'94 4x4 XLT
Vehicle Specs
(Original Poster)
Quote:
could it be my steering box is shot to hell???
__________________
My SAS Thread
Old 04-11-2007, 12:37 AM   #198
ohe_boy
Kane'ohe, Hawaii
ohe_boy's Avatar
'94 4x4 XLT
Vehicle Specs
(Original Poster)
^^^^^^ refer to previous post
__________________
My SAS Thread
Old 04-11-2007, 12:38 AM   #199
Burns
EF Late Night Crew
Memphis, TN
Burns's Avatar
Vehicle Specs
Well mine i think that is what it is. I have a "newer" that i just dont have the time to swap it out.
Old 04-11-2007, 12:38 AM   #200
FROADER
Moderator
FROADER's Avatar
Vehicle Specs
Normal play like when your X was stock. That's how much mine has. I definitely don't have from 11 to 1 amount of play.
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
