| Offroad Explorer - Ranger Projects Big projects... Lifts, Swaps, etc... IMPORTANT As the subject use your name, or the name of your truck, and the name of the project. Such as Superlift 5.5" installation, Dana 44 conversion, etc. |
Thread Tools |
#81 |
Wannabe Elite Explorer
Golden, CO
'94 XLT
oh, so they're just for different amounts of lift?
thanks, I guess I'll just get the 7* ones __________________ '94 XLT 4Dr 4X4 4x4 photos C4 conversion, man BW1354, 35" BFG muds, Trac-Lok Front, Aussie Rear, 4.10's, 8000lb Harbor Freight winch, custom front bumper ![]() Colorado School of Mines - Mechanical Engineering |
#82 |
moderation
Texarkana AR/TX
94 SAS sport
You need to find out what your caster is gonna be and order to set it. You can adjust the caster by moving the radius arm to frame mount up or down, "lift" height (springs or were the spring tower is placed on the frame) or with different wedges. The different degrees are for different caster settings for different lifts... but since you're SASing you dont really have a reference point.
#83 | |
Golden, CO
'94 XLT
Quote:
*ending threadjacking* __________________ '94 XLT 4Dr 4X4 4x4 photos C4 conversion, man BW1354, 35" BFG muds, Trac-Lok Front, Aussie Rear, 4.10's, 8000lb Harbor Freight winch, custom front bumper ![]() Colorado School of Mines - Mechanical Engineering |
#84 |
Rollover Posse Member
Monroe, GA
'93 Sport & '96 XLT
I think you'll be fine with the 7* ones if you plan on having about the same amount of lift as most others who do an SAS (6-9"). On our trucks, I've heard that you can't go less than 6" of lift with the SAS b/c of clearance issues, so there is no way you could get the lower degree bushings. Only other option for them is higher degree bushings...and after seeing that you wheel the X pretty hard
__________________ Weekend Toy: '93 Explorer 2dr - Full-width D44/9" swap, disc f/r, 37" Nittos, 4.88s locked rear, hi steer '96 Explorer 5.0 - Lifted, Magnaflow, Mac, TMH, 33s, TOTALLED!! New DD: '01 F150 Supercrew 4x4 - Magnaflow Hi-Flow cats & Muffler, powdercoated FX4 wheels, leveling kit |
#85 |
Golden, CO
'94 XLT
sweet
thanks *ok, I'm really going to stop threadjacking now* :p __________________ '94 XLT 4Dr 4X4 4x4 photos C4 conversion, man BW1354, 35" BFG muds, Trac-Lok Front, Aussie Rear, 4.10's, 8000lb Harbor Freight winch, custom front bumper ![]() Colorado School of Mines - Mechanical Engineering |
#86 |
Kane'ohe, Hawaii
'94 4x4 XLT
Its all good rino351. I don't mind sharing sas questions here!!! The more, the merrier!!
And btw, I am using the stock radius arms and already have ordered and received the 7 degree bushings! Like BMX said, many people have gone that route and so have I! Only thing is that I'm still unsure about what kind of yoke i have on the d44!! how can i tell? see if the d44 yoke can fit around the front driveshaft u joint?? __________________ Kea Hottendorf - '94 4X4 XLT, FULL WIDTH HP Dana 44 up front with FULL WIDTH Ford 9" in the rear. 4.88 gears Lockright front and detroit back 36'' IROKs 3" BL, KKM Air Filter, Flowmaster 50 series, ![]() My SAS Thread |
#87 |
Ogden, UT
1993 Sploder
My Dana 44 out of a 76 F150 had the right yoke on it for front driveshaft.
Ryan, It really depends on your mounts pretty heavily, not just lift to reiterate what James said. I used the lowest profile mounts I could pirate out of a 2x4 70s f150. I did that so I wouldn't snag them on anything. I am really not sure how my caster is since I haven't got it on a rack yet, but I don't think it is good. I started out with 4 degrees then moved to 7 degrees. Those bushings can also effect camber if caster is way out of wack and toe in must be used to off set it. I think that is what is going on with mine. I will find out when I finally take it down to get it aligned professionally (I am an ametuer, but I still can get it pretty close) but I am not doing that until I have the final steering setup. __________________ SOLD 93 Sploder- HP Dana 44 Front, 37" MTRs, 4.56s, 1354 doubler, ARB, Detroit, Winch, Kirby Built Armor, etc... 05 Jeep Rubicon Unlimited LJ 4" Lift, 33s, 94 F150 |
#88 |
Power through it!
onalaska, Washington
1988 BroncoII
__________________ 88 BroncoII 4.0/C5/1350/1354/D44/9" 72 Bronco 302 I have a matched set of early bronco axles for sale D44 and 9" for sale PM me for price and details. |
#89 |
Kane'ohe, Hawaii
'94 4x4 XLT
Did anybody install their own gears or are knowledgable on the ring and pinion gears? Need some help!!
#90 |
Golden, CO
'94 XLT
my dad and I installed gears into the 8.8" adn as long as you follow the directions it wasn't that hard at all. We will probably install the gears ourselves when we get that far for the sas
#91 |
Kane'ohe, Hawaii
'94 4x4 XLT
I needed some help with the Dana 44 up front! I know that its a bit more complicated then the ford 9 inch!
#92 |
Monroe, GA
'93 Sport & '96 XLT
Yep...from what I've read, the ford 9" is actually one of the simplest axles. And it's definitely proven to be so, when I've pulled it about this many times.
I may or may not regear mine on my own. I haven't made up my mind yet.
#93 |
Kane'ohe, Hawaii
'94 4x4 XLT
I've started on regearing the ford 9 and so far, so easy!!
#94 |
Ogden, UT
1993 Sploder
i have done about 10 axles so far. i did an xj last week and i will do my tj next. all the same basic idea, just accomplished a little differently. the 44 was an annoying design imho. too much pressing on and off. if i had to do it again i would make some set up bearings...
#95 |
Kane'ohe, Hawaii
'94 4x4 XLT
Well thats one of the things...I thought that the master install kit would've came with the setup bearings but when I opened the kit up, it didn't come with one. ALSO, it didn't come with those inner and outer oil slingers and oil baffle, so I had to go hunting around the island for some. I didn't want to order them online as they are only a buck a piece. Luckily for local 4x4 shops they had all kinds of oil slingers and baffles!
#96 |
Kane'ohe, Hawaii
'94 4x4 XLT
Changes made to my list - first post
#97 |
Kane'ohe, Hawaii
'94 4x4 XLT
anybody got pics of their drop trac bar bracket/mount? Not sure how/where to mount them!
#98 |
Ogden, UT
1993 Sploder
Mine:
TBar Mount And Mount Mines a stock mount turned over with a support built for it. I also welded some 1/4" reinforcement to the frame. Never had a problem with it. I hope Ibuilt it right the first time. There is alot of stress on that area, don't skimp in terms of strength. __________________ SOLD 93 Sploder- HP Dana 44 Front, 37" MTRs, 4.56s, 1354 doubler, ARB, Detroit, Winch, Kirby Built Armor, etc... 05 Jeep Rubicon Unlimited LJ 4" Lift, 33s, 94 F150 |
#99 |
Kane'ohe, Hawaii
'94 4x4 XLT
78-79 Bronco Drop Trac Bar Bracket
Actually I have these trac bar brackets off Broncograveyard and was wondering how you mount this sucker on?
![]() On the lower left part of the bracket there's a hole with a tube thats welded on to the other side. what do you do with that?! __________________ Kea Hottendorf - '94 4X4 XLT, FULL WIDTH HP Dana 44 up front with FULL WIDTH Ford 9" in the rear. 4.88 gears Lockright front and detroit back 36'' IROKs 3" BL, KKM Air Filter, Flowmaster 50 series, ![]() My SAS Thread |
#100 |
Ejection seat man..
Tooele,Utah
94 XLT,75 FJ, 05 Cummins
Its kinda worthless without the original trac bar mount to bolt it over. unless you cut one of the upper ears off and weld it to the frame.
__________________ SAS BUILD UP 2.5 Ton Rocks, Fully Locked, Pinion Brakes, Full Hydro, Re-Centered H1s, Rock rings. 42" Pitbulls Max speed about 35-40
| Thread Tools | |
