Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
horn doesn't work
Reply
Thread Tools
Old 08-04-2005, 04:45 AM   #1
med
hope, ar
'97 X xlt 4x
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
horn doesn't work
have a '97 x and the horn will not work and the lighted writing for the cruise (left side only on steering wheel) is not working. it was like this when i bought it. i have no idea on where to start looking for problems. anybody able to help?
thanks-
med
__________________
Never go where your mind hasn't already been.
med is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-04-2005, 03:42 PM   #2
ExplorerSportNu
St.Louis - MO
95 Sport/ExpeditionPkg
Vehicle Specs
Quoted: 0 Post(s)
Does your cruise control not work at all and is your airbag light on? If this is the case then you probably have the same problem I have, clockspring in the steering wheel is bad, it's the mechanism behinde the airbag in the actual steering wheel itself. I'm still trying to figure out how to get the steering column off, all the steering wheel pullers I have come across don't work worth a shit when it comes to pulling it off
__________________
95 Sport on 35's / 5-6" of TorsionTwist = No problems
ExplorerSportNu is offline   Reply With Quote
Old 08-04-2005, 03:52 PM   #3
CobraXP
Just another White X
Salt Lake City
CobraXP's Avatar
Early 97 X
Vehicle Specs
Quoted: 0 Post(s)
First thing I would check is the horn itself. It is under the battery. Take the screws out of the fenderwell and feel right above it.
The horn is actually a dual horn setup. They are known for grounding themselves out. You can unhook them one at a time and see if the horn works. Mine grounded out a while back. When it grounds itself, it usually kills the lights in the cruise buttons and sometimes the cruise itself because they are on the same circuit at the wheel.
I would check that first because it is cheaper and easier to fix that than starting at the wheel. If you disconnect one horn and nothing works, then check the other and still no results, then I would move to the wheel.
__________________
David
Just an old Explorer and a getting older Sport Trac...
CobraXP is offline   Reply With Quote
Old 08-04-2005, 04:52 PM   #4
Rhett
Let Them Eat Cake
Cape Girardeau, MO
Rhett's Avatar
94 Sport 4x4
Vehicle Specs
Quoted: 62 Post(s)
Before I did any of that I would check the fuse and/or relay that is on the horn/cruise contrl circuit.
__________________
94 Sport 4x4; AMSOIL cone filter; Granitelli MAF; BBK 66mm TB; Apten dual-program chip; BFG's; Warn manual hubs; Timken bearings w/Spicer internals; IPCW Crystal Diamond headlights; Blazer DF1075 55W fogs; and more stuff etc. etc.
Rhett is online now   Reply With Quote
Old 08-04-2005, 08:29 PM   #5
med
hope, ar
'97 X xlt 4x
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
thanks guys....i'll check it out.
ExplorerSportNu --- the cruise works fine thank goodness. little stuff like this not working drives me crazy. i can be aggressive at the wheel at times and i want to be able to lay down on the horn when those not so attentive drivers pull out in front of me. they'll never realize i'm flippin' e'm off if they can't hear me honkin'.
thanks-
med
__________________
Old 08-04-2005, 09:26 PM   #6
ExplorerSportNu
St.Louis - MO
Vehicle Specs
Quoted: 0 Post(s)
thanks-
med
LOL I feel your pain, going on no horn for about a month now i'm about to lose my marbles and be very glad you don't have the problem I have
__________________
Old 08-04-2005, 10:27 PM   #7
Glacier991
EF Tranny Guru
Sacramento, CA 95827
1992 XLT
Vehicle Specs
Quoted: 5 Post(s)
"horn doesn't work, watch for finger?"
Glacier991 is offline   Reply With Quote
Old 08-14-2005, 05:54 PM   #8
med
hope, ar
'97 X xlt 4x
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
ok.....i finally got around to checking my horn out. it was said that it's a dual horn but it looks like i just have one. i'm not sure wtf is up with that. and the existing horn is not connected to anything. there is a female connection coming from the horn and another female connection coming from some other assembly. and i cant figure out where the horn is supposed to plug in of if something else is missing. a pic is included. if anyone can help i'd appreciate it.
thanks-
med
__________________
Old 08-14-2005, 09:53 PM   #9
99SportX
Duluth, MN
1999 Ex & Mounty
Vehicle Specs
Quoted: 12 Post(s)
lol. Your other horn is missing. If you want to have a horn, connect the blue wire on the left to the the one on the right. There is supposed to be another horn to the right of the existing one, and that is what the wires are supposed to connect to.
__________________
'99 Explorer Sport 5.0 2wd Lowered, etc
'99 Explorer XLT 4.0 SOHC 4x4 daily driver
'99 Mountaineer 5.0L V8 AWD other daily driver
'96 ZJ Limited on 33's, front long arm, rear 8.8 swap
99SportX is offline   Reply With Quote
Old 08-16-2005, 02:26 PM   #10
med
hope, ar
'97 X xlt 4x
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
i don't mind having 1 horn although it makes me very curious about what happened to it or why it's not there. but what do i need to get to make these two female connections fit together?
thanks-
med
__________________
Old 08-16-2005, 06:22 PM   #11
99SportX
Duluth, MN
1999 Ex & Mounty
Vehicle Specs
Quoted: 12 Post(s)
You could simply cut the connectors off and install an end to end connector, tape them together, or solder and then tape over the joint. Just be aware that your car will sound like a sissy car without the other frequency horn there.
__________________
Old 10-25-2005, 08:26 AM   #12
mcshot
over da bridge, mi
98 Sport
Vehicle Specs
Quoted: 0 Post(s)
Newbie here with no horn. Now know where to look and what to look for.
thanks,
mc
mcshot is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
