Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
'92 AC clutch not engaging
Reply
Thread Tools
Old 08-09-2005, 11:03 PM   #1
Static-XJ
Colorado Springs
'92
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
My AC clutch isn't engaging when I turn the AC on. The clutch turns fine by hand. I checked fuses, but didn't see any blown ones. Was going to send 12v directly to the clutch, but there's two leads, guessing it's not grounded through the case.
Static-XJ is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-10-2005, 10:08 AM   #2
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quoted: 218 Post(s)
Yes there are 2 leads on the compressor.. One is 12v and one is ground. It doesn't matter which is which.. If it engages when you manually put power/ground to it then the clutch is fine..
You should also check the low pressure switch. Its over on the accumulator. Take the connector off the switch, and short the plug. If the compressor turns on then you are either low on freon or you have a bad pressure switch. You will need to put a set of gauges on to see if you are low on pressure.
One other thing to check for.. the WOT relay. I believe its in the passenger/rear corner of the engine compartment. That relay is supposed to break the connection to the compressor when you are at WOT (or close to).
~Mark
__________________
Click HERE to see our Explorer Specs
Maniak is offline   Reply With Quote
Old 08-10-2005, 10:34 AM   #3
Glacier991
EF Tranny Guru
Sacramento, CA 95827
1992 XLT
Vehicle Specs
Quoted: 5 Post(s)
99 times out of 100 this is happening because you are low on refrigerant. Save yourself some time and check that first before you go searching for electrical gremlins.
Glacier991 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
