PJC
- August 20, 2005
- Central Illinois
- 1992 XLT
I purchased a '92 XLT about 6 months ago with 148,000 miles on it. It seems to be very solid and generally in good shape. However, with all vehicles that old with that many miles on it, there are a few small problems -- of which I have a few questions.
First, the 4x4 worked when I first got it, but now it is not. Reading through everything, I think I have the problem with the shift motor on the transfer case (it being a push button shift). I am reasonably mechanically apt and would like to take a shot at tearing down the motor and fixing it. However, as it is my only current means of transportation if something goes wrong with the rebuild and I have to pay for a new/rebuilt motor, can the vehicle still operate with the shift motor removed (in 2WD, where it is currently at, of course) without causing any additional damage?
Secondly, I am pretty sure the oil sending unit is not working correctly. While it should be easy to replace and I think I have located it on the vehicle, does the oil need to be drained prior to changing it or is it sitting high enough that oil won't spill out of the hole when it is removed? Also, will standard teflon tape be acceptable as a thread sealant?
Finally, the cruise control works -- but works strangely. If I accelerate to, say, 45 mph and engage the cruise control, the truck will slow down about 4-5 mph and then engage. It will then maintain speed at 40-41 mph. If I accelerate back up to 45 using the SET button, it does the same thing and drops back to 40-41 mph. The only way to set it at a given speed is to accelerate to about 5 mph above where I want to set it and then engage it. In urban conditions, there is not always enough room to accelerate 5 mph faster than surrounding traffic to engage cruise. Also, maintaining 5 mph under the current flow of traffic will get the ire of all around you. Is there any adjustments that can be made to to system to get it to operate properly?
Thanks in advance for any/all help.
PJ
PJ
