Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
My experiences on pinging
Reply
Thread Tools
Old 06-07-1999, 12:05 AM   #1
ryanj
Unregistered
Posts: n/a
Vehicle Specs
I went to Colorado recently and before the trip the explorer was pinging pretty bad. I decided to run mid octane gas the whole trip and the ping went away. (I'm from St. Louis BTW) About half way to CO I started loosing power bad, I could go 75mph with it floored, not good I thought. Before the trip I was allready experiencing very poor performance with the explorer. So in desperation I stopped at a gas station somewhere in Kansas, and talked to a mechanic. He changed the fuel filter...all my pinging, poor performance, etc. went away. I had 53k mi on it. He said its pretty common and Ford recommends changing it every 15-20k. Seems pretty lousy to me. Good thing I had it changed though...got to Pikes Peak with no problem. Thin air and all. Oh and for the trip I covered up the holes I drilled in the air box thinking that may have been causing the pinging...it was not.
Ryan J.
ryanj@primary.net
Old 06-07-1999, 09:36 AM   #2
gatlin
Unregistered
Posts: n/a
Vehicle Specs
Did the mechanic give an explanation of why changing the fuel filter fixed affected the pinging?
gatlin
Old 06-07-1999, 09:36 AM   #3
gatlin
Unregistered
Posts: n/a
Vehicle Specs
Did the mechanic give an explanation of why changing the fuel filter fixed the pinging?
gatlin
Old 06-10-1999, 07:06 AM   #4
ryanj
Unregistered
Posts: n/a
Vehicle Specs
I didnt know the pinging was gone until I left and I didnt think that getting the fuel filter changed would help the pinging either.
Its now about a week since that had happened and STILL no pinging.
Old 06-10-1999, 01:34 PM   #5
gatlin
Unregistered
Posts: n/a
Vehicle Specs
Does anyone have any ideas on how changing the fuel filter could affect pinging?
gatlin
Old 06-12-1999, 12:06 AM   #6
Skip Pendle
Unregistered
Posts: n/a
Vehicle Specs
Gatlin:
The probable reason that the fuel filter change stopped the pinging is as follows:
Fuel flow to the engine is controlled by a combination of a constant fuel pressure to the injectors and the spray timing of the injectors. The fuel pressure is controlled by a pressure regulating valve which can only do its job if the fuel pressure from the fuel pump equals or exceeds the regulated pressure. If there is a restriction in the fuel feed line (a plugged fuel filter, for example) the fuel pressure reaching the engine will be reduced as higher fuel flows are demanded by engine load. This will cause a lean air/fuel mixture in the cylinders with the result of a tendency to burn by "explosion" rather than with a progressive flame front which is normal. It is this explosive burn that you hear as "pinging". Of course, restricted fuel flow also means less power output from the engine.
Old 06-12-1999, 11:08 PM   #7
ryanj
Unregistered
Posts: n/a
Vehicle Specs
Sounds like a good explanation to me.
Hehe, I was talking to a car parts dealer (attempting to buy somthing to fix it) before I went on my trip..told him that it was pinging bad and mentioned I had drilled holes in the airbox. He freaked out saying the MAF couldnt tell how much air was going to the engine, thats why it was pinging. I didnt aruge with him and left without buying anything...guess he thought I managed to put holes somewhere after the sensor...whatever.
Old 06-12-1999, 11:11 PM   #8
ryanj
Unregistered
Posts: n/a
Vehicle Specs
Oh, one other thing. The irony of this whole situation was that I attempted to change the fuel filter on my own before I went on the trip...just because I thought it would be good to do. But had given up because I could only get one of the fuel lines off...so I figured it would be ok if the filter stayed on a little longer...that'll teach me.
Old 06-15-1999, 12:38 AM   #9
gatlin
Unregistered
Posts: n/a
Vehicle Specs
Thanks for the explanation, Skip. I'll be changing mine this weekend.
gatlin
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
PLEASE HELP!!! Very bad pinging Sanchez Under the Hood 3 07-20-2001 10:51 AM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
