Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
oil pressure
Reply
Thread Tools
Old 07-22-1999, 10:07 AM   #1
mailman
Vehicle Specs
(Original Poster)
Angry
93 4x4 get off highway come to stop oil pressure drops idle at 600 put in park or hit gas pressure goes up. trun ac off pressure goes up. had ac checked, new sending unit, cleaned MAF,new belt,took bat. cable to set new idle?
mailman is offline   Reply With Quote
Old 07-22-1999, 02:01 PM   #2
pacman
Milpitas, CA (SF Bay Area)
'97 EB
Vehicle Specs
Post
How much does the pressure drop? It is normal for oil pressure to respond to the rpm's (since the oil pump turns faster with higher rpm's). If you have a significant drop, you might have a bad oil pump or your oil viscosity is too low (go to a higher viscosity number on the oil, i.e. the first part (5w, 10w, or 20w) is the viscosity when cold, the second part (-30, -40,-or -50) is the viscosity when hot. The higher the number the thicker the oil.). See if this helps.
pacman is offline   Reply With Quote
Old 07-22-1999, 02:21 PM   #3
Todd
Southwest MO
93 XLT (Sold)
Vehicle Specs
Post
mailman,
Oil gauges in many vehicles are no different than the well known idiot light for loss of oil pressure. That means there are only two positions for the gauge(generally) and that is below normal(either vehicle off or no pressure) and in the middle somewhere(pressure within a given range). If I remember correctly, early explorers were fitted with these type of gauges.
True oil pressure gauges will, as pacman stated, show variance in pressure. Oil pressure does vary quite a bit from idle to WOT and even when accessories are on(the a/c for example). At our family's nursery, our dump trucks all have true oil pressure gauges in them and the variance in pressure is over 2/3 of the gauge on a normal day.
So, hopefully this helps a little.
Take care and happy exploring!
Todd Metzger
'Off-Road and More!'
93 "Ford X 4" XLT
Todd is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
You smoke cigarettes? FourXFred General Topic Polls 167 11-12-2011 09:12 PM
OIL PRESSURE READ LOW? READ THIS! rjc Under the Hood 0 02-19-2002 12:53 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
