Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Fuel pump relay location??
Reply
Thread Tools
Old 08-29-2005, 04:09 PM   #1
Edcon
Emmaus, PA
91 Ranger XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
A friend of mine is having trouble finding his fuel pump relay on a 91 4.0. He was told to check the power distribution box under the hood, but he said there are no relays in it. Could someone please guide me to its location? Thanks.
Edcon is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-29-2005, 04:33 PM   #2
Bwana Bob
Morris Plains, NJ
92 XLT
Vehicle Specs
Quoted: 5 Post(s)
I've never seen the relay myself, but I understand that it is on the underside of the power distribution box. The box is snapped into a bracket and there is tab near the inside fender wall that you push to release the box. I tried this but the wire bundles were too short for me to actually lift the box out, so I gave up.
Bob
__________________
1992 XLT semi-retired: Manual trans, Manual hubs, brush guard, Hella fog lamps, K&N air filter, Michelin LTX/MS, 241,000+ miles. Daily driver: 2010 Focus SES. Amateur Radio WB2VUF
Bwana Bob is offline   Reply With Quote
Old 08-29-2005, 04:45 PM   #3
Edcon
Emmaus, PA
91 Ranger XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I'll tell him to try that. Thank you for the quick response. Ed
Old 08-30-2005, 05:27 AM   #4
marragtop
balt, md
91, 92, 95, and 2000 xlts
Vehicle Specs
Quoted: 4 Post(s)
I'm not sure the 91s have a 'relay'. There is a fuel pump fuse in the fuse box under the hood.
__________________
'88 F150 4x4
'91 Explorer XLT 4x4
'92 Explorer XLT 4x4
'95 Explorer XLT 4x4
If it don't = 16 (4x4), it ain't worth driving...
marragtop is offline   Reply With Quote
Old 08-30-2005, 01:27 PM   #5
unclemeat
Richmond, VA
unclemeat's Avatar
91 sport
Vehicle Specs
Quoted: 16 Post(s)
The fuel pump relay is below the fuse box under the hood. it is the relay closest to the rear of the vehicle. It is usually green. It should only be replaced with a motorcraft relay. Also be careful not to break the plastic parts. They tend to be brittle.
unclemeat is offline   Reply With Quote
Old 08-30-2005, 01:35 PM   #6
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 3 Post(s)
Unclemeat you can replace the sucker with any relay, they have ones at auto parts stores that will fit.
a 5 prong relay is a 5 prong relay typically in 12v applications.
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
Wifes 07 FJ build - 2007 FJ cruiser locked and lifted
410Fortune is offline   Reply With Quote
Old 08-30-2005, 01:35 PM   #7
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 3 Post(s)
Ford charges like $20 for each one if I remember right, Carquest was like $6.
hahaha
__________________
Old 08-30-2005, 06:39 PM   #8
Edcon
Emmaus, PA
91 Ranger XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks again for the help guys. I told him where to look, and I'll find out tomorrow how it worked out for him. Ed
Old 08-31-2005, 03:38 PM   #9
Tony H
New York, Wading River (that's on Long Island)
'91 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
If he gets the Distribution box off, I believe the OEM relay is the Green one.
The Distr. box lifts off..not easy though, you will want to look down the side closest to the Fender and see the Metal clip that holds it. may need to pry it back a bit with a large screwdriver
__________________
1975 CJ5 with fiberglass body and 350/345Hp chevy power:bought it in '79
1985 chevy stepside pickup, 300K on the clock: Original Owner
1989 Volvo 240 300K on the clock: Original Owner
the 1991 X is my newbie with 331K on the clock: bought OCT.'03 with 183K
http://home.lyse.net/brox/TonyPage4.html
Tony H is offline   Reply With Quote
Old 06-12-2009, 12:43 AM   #10
manny65
Forest grove, OR
1991 eddie bauer
Vehicle Specs
Quoted: 0 Post(s)
Dk Exp Fuel Pump Relay
There is a relay located under the power distrobution block. It is the green one closest to the firewall, just under the 2-15amp fuses and the 30amp fuel relay fuse. The easyest way to get to it is 2 - 8mm screws/bolts inside the fender that hold up power block.
manny65 is offline   Reply With Quote
Old 06-12-2009, 12:56 AM   #11
Tbars4
Offroad/Fitness Moderator
anaheim hills,california
Tbars4's Avatar
95 ranger 4x4/ 91 X 4x4
Vehicle Specs
Quoted: 300 Post(s)
...The last post is almost 4 yrs. old...
...For future readers with 91-94 X's looking for their fuel pump relay, they can find the information with pics here...
http://www.explorerforum.com/forums/...ighlight=relay
__________________
I have Rocks in my head. What's in yours?
'95 ranger xl 4x4 2.3L std cab, 3 sticks Ranger RegistryThe Squirrel
'91 4x4=To much to list, much more to add.. Project "X" and more Pics & Mod's List
How to: Wheels,Tires, & Lifts...
Buy Explorerforum.com Items here
Tbars4 is offline   Reply With Quote
Old 08-17-2009, 10:05 AM   #12
brian85
cave city ky
'94 xlt
Vehicle Specs
Quoted: 0 Post(s)
hey i have a 94 4.0 that dies often. i know its in the fuel system somewhere just not sure where. when it dies and i go to start it again i dont hear the fuel pump "charge up" and will have to wait a matter of mins. before it will untill it will start again. the fuel pump is approx. 3 yrs old.
brian85 is offline   Reply With Quote
Old 08-17-2009, 10:10 AM   #13
brian85
cave city ky
'94 xlt
Vehicle Specs
Quoted: 0 Post(s)
Old 08-17-2009, 10:14 AM   #14
marragtop
balt, md
Vehicle Specs
Quoted: 4 Post(s)
Try replacing the FP relay. Cheap and easy fix.
__________________
'88 F150 4x4
Old 08-17-2009, 10:17 AM   #15
Tony H
'91 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Sounds like the Relay.
I bought my 'X' because the Previous Owner was going crazy with an intermittent shut off. Just for giggles I replaced the Relay, And I never had the issue. I guess I guessed right...It's been over 150K miles since I bought it.
__________________
Old 08-27-2009, 01:16 PM   #16
DanielAmezquita
Chihuahua, Chihuahua
'96 XLT
Vehicle Specs
Quoted: 0 Post(s)
Thumbs up It works!! thanks
Hi, I was having the same problem. After a few short trips the X refused to start, only cranks. I was suspecting about the fuel pump, but after check the prices, I made a search here and found this tips. I changed the relay Two days ago and problem solved. (1996 4WD w/146K), the power distribution box has 6 relays (two groups of three small and three standard size), the fuel relay is the closest to the firewall, standard cube size.
Thanks for the tip guys.
Daniel
DanielAmezquita is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
