#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Lifters making ticking noise
Reply
Thread Tools
Old 09-07-2005, 07:08 PM   #1
phasmid123
seattle
91 EB
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
US Lifters making ticking noise
Hi All,
I have a 91 EB that makes ticking noise when engine's turned on. A friend told me it's probably the lifters making noise from dirty engine and flushing the engine with detergent should get rid of the noise. Is this true? Also, is it just an annoyance or I should seriously consider replacing the lifters? Much obliged!
phasmid123 is offline   Reply With Quote
( Join the Elite Explorers )
Old 09-07-2005, 09:53 PM   #2
Glacier991
EF Tranny Guru
Sacramento, CA 95827
1992 XLT
Vehicle Specs
Quoted: 4 Post(s)
If your Explorer is running fine otherwise, it is just an annoyance. I'd love to tell you adding some engine flush would likely help, but odds are it might do more harm than good and won;t likely help. Short of replacing the hydraulic lifters the best advice is live with it. If you are really worried you might check your oil pressure with a gauge. (The one in the dash is a joke). Low oil pressure can cause it too.... meaning new pump. But it's likely just system wear. Not harmful.
Glacier991 is offline   Reply With Quote
Old 09-07-2005, 10:06 PM   #3
midgetwith9arms
Anderson, SC!!
'91 Sport and '92 XLT
Vehicle Specs
Quoted: 0 Post(s)
if you have alot of miles on it then its saying "i need to be overhauled", bc my old 92 sittin at the house does it and it has like 190k miles on it.
__________________
Boredom=Stupidy
midgetwith9arms is offline   Reply With Quote
Old 09-08-2005, 10:57 AM   #4
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 2 Post(s)
Try a can of seafoam in the crankcase before your next oil change. Follow directions on bottle.
Sometimes it will cure the sticking lifters/poor oiling.
Also check the torque on the upper intake manifold, if it is loose you have a vacuum leak. 91-94 are notorious for this.
Search for both of these on this forum for more info
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
Wifes 07 FJ build - 2007 FJ cruiser locked and lifted
410Fortune is offline   Reply With Quote
Old 09-08-2005, 12:48 PM   #5
trucku
Queens, New York and living in Budd Lake, NJ now.
trucku's Avatar
2002 Explorer XLS 4.0 4x4
Vehicle Specs
Quoted: 0 Post(s)
I had some ticking noise last year. It was not the valves. I was using lucas oil stabilizer and had too much viscosity for engine (10W40). I lived with it till this summer. I went to right viscosity 5W30 mobil1 synthetic and no additives. The noise went away after some driving..about a month or so.
http://www.jonko.com/forum/diagnosis...engine_tap.htm
__________________
2002 XLS 4.0 SOHC 4x4. Frantz Bypass filter, Mobil 1 5W30.Perma-cool dual remote (2 full flow PureOne PL30001). Perma-cool remote transmission filter (Pure One PL30001). Scanguage II, Sunpro Oil Pressure Guage
Gen 4 mirrors
"The More Complex The Mind, The Greater The Need For The Simplicity Of Play"
trucku is offline   Reply With Quote
Old 09-11-2005, 10:04 AM   #6
MazdaGreg
Frederick, Co
93 Ranger XLT
Vehicle Specs
Quoted: 0 Post(s)
I used to have ticking lifter noise as well. If you change the oil more frequently, sometimes you can cure that. I'm talking once every 1000 miles or so. Use a lighter weight oil also, like a 10:30 or 5:30. I don't know if i'd go with the 5:20 because that could be a bit too thin for 4.0l
MazdaGreg is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
