EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
Vacuum Lines and Air Box
Reply
Thread Tools
Old 09-15-1999, 01:50 AM   #1
Sparky
Vehicle Specs
(Original Poster)
Post
Gentlemen,
I have a 91 Explorer, 4.0L, 4WD and have a few questions about the vacuum lines at the rear, top of the air box. One has a yellow stripe on it, and runs down underneath the intake, and the other is routed over/behind the engine, connected to a vacuum port, on the upper intake manifold. The one connected to the vacuum port is attached to the left side of the box, closest to the fuse box. I'm just wondering: Is this hooked up correctly? Also, does it matter which side of the bi-metal switch the two lines are connected to? Lastly, just what does this setup do..??
Thanks!
Robert
[This message has been edited by Sparky (edited 09-15-1999).]
Sparky is offline   Reply With Quote
Old 09-15-1999, 09:17 PM   #2
Skip Pendle
Vallejo, CA
'93 Eddie Bauer
Vehicle Specs
Post
This set-up is there to pre-heat the intake air for quicker warm-up and to de-ice the intake manifold during sub-freezing weather. The line going below the air box is connected to a diverter valve in the air intake that mixes outside cold air and hot air that comes from an "oven" attached to the righthand exhaust manifold. You can check if this valve is working by gently sucking in and releasing on the line, you will hear the valve moving back and forth.
Frankly, I don't know what would happen if you reverse the two lines at the air thermostat on the air box.
Skip Pendle is offline   Reply With Quote
Old 04-02-2003, 08:45 PM   #3
JrseyKid86
Rochester Hills, MI
1991 Explorer XLT
Vehicle Specs
i took my lines off of my 91. rougher idle. The line that sucks air has to be on the left hand side when your looking at the front of the car. The one on the right, that looks like a shoelace doesnt really serve a purpose to my knowledge. But the one on the left sucks air from the airbox... kinda stupid if you ask me. But i dont know what its there for. No problem running w/o the lines in 65 degree Michigan weather.
__________________
-Marc
'91 XLT New Rockfordfosgate CD/MP3,6X9'' 250 Watt max output speakers, Alpine 4 channel amp, 2 channel Rockfordfosgate amp powering two 6X9 Explodes in the truck speaker box on either side of an 8" sub, interior rope and neon tube lights, custom fog lights, green LED backlit vents, customized stock grill, headlight strobes, bug sheild, custom pinstripes, custom window badging, aftermarket alarm, custom third brake light, drilled air box, DEE ZEE running boards... Customized interior painting, steering wheel cover, special 2 tone paint... and more
JrseyKid86 is offline   Reply With Quote
Old 04-02-2003, 09:03 PM   #4
Sparky
Vehicle Specs
(Original Poster)
Thanks guys...
Much appreciated.
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
what are the 2 vacume lines on my 93 stock air box? bnichols04 Under the Hood 12 07-25-2003 12:24 PM
Air Ride Shocks JJCollett Explorer - Ranger Shocks, Suspensions, Lift Kits 9 12-19-2002 05:33 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
