Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
Loud humming noise coming from the air filter
Reply
Thread Tools
Old 06-23-1999, 10:53 AM   #1
scubaman
Unregistered
Posts: n/a
Vehicle Specs
Quoted: Post(s)
I have a 95 Explorer and I'm getting a loud humming noise coming (it seems) from air filter compartment. I took it in for repair but they could not figure out what was causing the sound. Any ideas? I'm trying to avoid taking it to the dealer!! ($$$). It does do it all the time and it doesn't affect my engine, steering or braking. Please help me solve this problem because it's getting on my nerves.
( Join the Elite Explorers )
Old 10-06-1999, 02:12 PM   #2
KyleC
Vehicle Specs
Quoted: 0 Post(s)
Post
I dont know if this helps but a friend of mine has a F-150 that was doing this because he drilled holes in the airbox and weakened the plastic just enough to make it resonate as the air goes throught it. It actually sounds like a cow mooing at certain RPMs.
KyleC is offline   Reply With Quote
Old 10-07-1999, 12:46 AM   #3
Chris Suerig
Vehicle Specs
Quoted: 0 Post(s)
Post
I have the same problem with my 97. Did you ever find the problem? my e - mail is Csuerig@aol.com. Thank you.
Chris Suerig is offline   Reply With Quote
Old 08-08-2004, 05:00 PM   #4
rwp99exp
el cajon, ca.
1999 explorer sport
Vehicle Specs
Quoted: 0 Post(s)
mine does the same thing and i have the gen 1 K&N. they say it normal.....its just sucking a lot of air
rwp99exp is offline   Reply With Quote
Old 08-08-2004, 06:50 PM   #5
Alec
Elite Moderator
Houston, Texas
Alec's Avatar
2008 JK
Vehicle Specs
Quoted: 0 Post(s)
Very loud humming noise at idle (or low load) = IAC, Idle Air Control valve. A zillion posts on here about it, good luck!
__________________
Alec "Dr. Candlepower" Rosenbaum
Daily: 2008 JK
Gone: EE "Splat", 2003 VW GTI VR6, 85 Bronco project
Alec is offline   Reply With Quote
Old 08-09-2004, 04:58 AM   #6
unclemeat
Richmond, VA
unclemeat's Avatar
91 sport
Vehicle Specs
Quoted: 15 Post(s)
It is also cheap and simple to fix.
unclemeat is offline   Reply With Quote
Old 08-10-2004, 02:08 PM   #7
My98xplorer
lakeland fl
1998 Sport
Vehicle Specs
Quoted: 0 Post(s)
I had the same problem with my Explorer. It was indeed the IAC, i took it off and cleaned it out and instantly no more humming!
__________________
1998 x sport, billet grill, clear corners, 5% tint all around, reverse indiglow gauge, carbon fiber overlay around gauges, carbon fiber radio bezel, 10" JL Audio sub
My98xplorer is offline   Reply With Quote
Old 03-30-2008, 04:03 PM   #8
fordfordboy
texas
95 explorer
Vehicle Specs
Quoted: 0 Post(s)
humming noise!
The humming noise on my 95 explorer started after I instaled a K&N filter. It only does it at idle, not when i hit the gas. And it starts right about when it hits around 90 degrees outside. I will look at the control valve.
fordfordboy is offline   Reply With Quote
Old 05-02-2009, 11:36 AM   #9
SuperSix1
1997 XLT
Vehicle Specs
Quoted: 0 Post(s)
I just got my car back had the serp belts replaced some other things + a long overdue air filter/ oil change and my cars been humming in the low rpms at stop lights but never while on the highway/ constant moving ... I figure its just sucking alot of air in...
SuperSix1 is offline   Reply With Quote
Old 12-27-2013, 10:35 AM   #10
ugoguyo
west covina , california
1998 ford explorer
Vehicle Specs
Quoted: 0 Post(s)
Ive had that same humming from my air filter box for about 5 years ....Its annoying!! ...its time to fix it
ugoguyo is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
KKN AIR FILTER HUMMING vbtruk Under the Hood 33 01-31-2003 02:21 PM
Humming from FIPK filter aqs789 Under the Hood 19 07-11-2002 11:20 PM
Noise after installing K&N air filter Mike Moyer Under the Hood 7 11-12-1999 09:51 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
