| Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35 |
Thread Tools |
#1 |
Wannabe Elite Explorer
Collierville, TN
2002 Explorer XLS
How to tell transmission type?
I have a 2002 4dr Explorer XLS with the 6cyl engine. How do I tell what type automatic transmission I have?
The maintenance schedule that came with it lists several models of transmission that need a fluid change at 30k miles. The schedule also lists other transmission types that DON'T need a periodic change, but nothing I can find under the hood or elsewhere tells what type of transmission is in the vehicle. The dealer is no help at all. They just say change the fluid. |
#2 |
Mountain Home, AR
2000 mounty / 56 f-100
Look on the drivers door tag for a code and post it.
I would bet its a 5R55E. Personally, I see no need to change the fluid until around 60K in anything, but thats me. Others will post their opinons as well. __________________ 56 f-100, short bed, 272 "Y" block V8, 3 speed standard, 3.73 rear gears. Oh...I have a 2000 mountaineer as well. |
#3 |
Human-Animal Hybrid
Carmichael, CA
'97 Sport 4x4
I think he actually has a 5R55W in the 2002. It is the first trans without a dipstick.
Check out this thread: http://www.explorerforum.com/forums/...ssion+dipstick Also, see: http://www.charlietranny.com/5r55w.htm |
#4 |
Mountain Home, AR
You are right. Another ford dumb design (IMHO).....sounds like taking a pinto transmission and adding OD. Yep...thats the wonderful A4LD.
#5 |
Human-Animal Hybrid
Carmichael, CA
'97 Sport 4x4
Yes, seems not so bright to me either.
Lets recall Explorer transmission history: 91-94 A4LD - A modified Pinto trans which has gained a rep for blowing out at relatively low mileage 95-96 4R55E - An improved, electronically controlled A4LD, not quite as fragile but still has problems 97-01 5R55E - Beefed up a little more, electronic control allows another forward gear from the previous design. As far as I know, they don't puke their guts nearly as quickly, but still not the strongest link in the powertrain. 02+ 5R55W (4doorsonly, Sport-Trac still uses 5R55E) Apparently, Ford is so confident in their track record that they decide to make the tranny non-serviceable. I guess we will know in a few years if they are justified. Personally, I like having a dipstick so I can at least examine the color of the fluid on the stick, if nothing else. |
#6 |
Mountain Home, AR
Doesn't the new trans also say not to change the fluid for 150,000 miles? Never seen fluid last that long. Ch**y has lifetime anti-freeze and fuel filters now too. Its getting worse everywhere.
I bet the dealers tell you to change the fluid every 30,000, but bring it to them. $$$$$$$$$$ __________________ 56 f-100, short bed, 272 "Y" block V8, 3 speed standard, 3.73 rear gears. Oh...I have a 2000 mountaineer as well. |
#7 |
florida
94 explorer
if you have an a4ld can you bolt on a later model beefier tranny like a 4r55e or 5r55e? It is a 2WD automatic with OD
thanks, physh |
#8 | |
Human-Animal Hybrid
Carmichael, CA
'97 Sport 4x4
Quote:
No, its not just a straight bolt in because the later models have electronically controlled shift solenoids; the A4LD does not. You would need to add the later model electronics or find an aftermarket controller for the 4R55E or 5R55E. This would take a lot of knowledge and research and money. Some people have installed 700R4 trans (using a special adapter) in place of the A4LD. You could search on that to find more info. http://www.explorerforum.com/forums/...ighlight=700R4 |
#9 | |
florida
94 explorer
Quote:
physh |
#10 |
Collierville, TN
2002 Explorer XLS
The plate inside the driver's door says: TR:R.
The transmission has a dipstick for the fluid. |
#11 |
Human-Animal Hybrid
Carmichael, CA
'97 Sport 4x4
My manual is for 97 and doesn't list that code. For 97, the code for 5R55E was D.
#12 |
Aerostar Forum Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
Which manual were those transmission codes from? The dealers are always telling you that the newer vehicles don't require as much maintenance, like the 100k mile platinum spark plugs. In another thread, I saw that Amsol oil could last for 25k miles. It might be true, but what if it is inside of an old engine that was never maintained? I'm sure that these things wouldn't last as long. As for the 5R55W transmission without the dipstick, I'm surprised that no aftermarket manufacturer ever made a dipstick upgrade that could be attached to it. I'm sure that something could be easily fabricated.
#13 | |
Human-Animal Hybrid
Carmichael, CA
'97 Sport 4x4
Quote:
#14 |
EF Tranny Guru
Sacramento, CA 95827
1992 XLT
It IS possible however, to take the stronger internal parts from the 5R55E and put them into the A4LD case and have the best of both worlds. On here known as a "Frankentranny" - thanks to the idea and thread posted by Brain (it is in the stickies). So far ... far as I know, only Brain and I have built or are building them.
#15 |
NewWindsor, NY
99 XLT 4WD SOHC
Type R
Looks like it is a 5R55W.
http://www.vibratesoftware.com/html_...2006.htm#Trans Try this site also: http://www.transonline.com/transID/default.asp Last edited by BillJ; 09-10-2006 at 03:41 PM. |
#16 |
Brooklyn, NY
Here is the information from that link:
Axle Codes L - Limited Slip Differential C - Conventional Differential Code Ratio 41 3.27C 42 4.10C 43 3.08C 45 3.55C 46 3.73C D1 3.27L D2 4.10L D4 3.73L D5 3.55L Transmission Codes Code Model D (1997-2005) A5LDE / 5R44/55E D (1992-1996) M5OD-R1 J M5OD-R1 J (2002 - 2003) R1HD / M5OD-R4 M (2000-2001) Mazda M5D4 M (1997-1999) M5OD-R2 M (1992-1996) M5OD-R1 R (2002) 5R55W T (1992-1995) A4LD T (1996-2001) 4R55E U 4R70W V 5R55S X 6R60 |
#17 | |
Brooklyn, NY
Quote:
#18 |
EF Tranny Guru
1992 XLT
Fast way to tell the difference between a 5R55E and a 5R55W is to look and see if the bellhousing is part of the case or whether there is a joint where the bellhousing bolts on. The W uses a unitized case.
#19 |
Brooklyn, NY
That is something I was wondering about for quite some time. On the A4LD, 4R55E, and 5R55E you could disassemble the transmission by disconnecting the bell housing. If the 5R55W is a unitized case, how do you disassemble it?
#20 | |
B
San Jose, Calif
2003 sport trac
Quote:
| Thread Tools | |
