Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
How to tell transmission type?
Reply
Thread Tools
Old 06-12-2006, 10:16 PM   #21
Glacier991
EF Tranny Guru
Sacramento, CA 95827
1992 XLT
Vehicle Specs
Quote:
Originally Posted by BrooklynBay
That is something I was wondering about for quite some time. On the A4LD, 4R55E, and 5R55E you could disassemble the transmission by disconnecting the bell housing. If the 5R55W is a unitized case, how do you disassemble it?
If you look at the 4R70W diary you will find the answer. A unitized case is more common that the A4LD 4R/5R setup. The pump serves as the front "end plug" for the cavity in the case where the guts are.
I have wondered why FORD did the separate bell on the A4/4R/5R and the conclusion I came to was that by using a seperate bellhousing they could easily adapt it to many different engines.... that tranny saw a LOT of different engines in front of it before it was through.
Glacier991 is offline   Reply With Quote
Old 06-26-2006, 02:54 PM   #22
markhas1
Scottsdale, AZ
'98 XLT 4x4
Vehicle Specs
5R55W vs 5R55E
Does the W in the 5R55W stand for wide ratio? If so what different ratios does it use compared to the 5R55E (1st and 2nd)? Do the internals of a 5R55W fit in a 5R55E even though the case is different?
markhas1 is offline   Reply With Quote
Old 06-26-2006, 04:48 PM   #23
dogfriend
Human-Animal Hybrid
Carmichael, CA
dogfriend's Avatar
'97 Sport 4x4
Vehicle Specs
Quote:
Yes, the 5R55W has a wider range than the 5R55E, according to this site:
http://www.charlietranny.com/5R55E.htm
http://www.charlietranny.com/5r55w.htm
Don't know about how interchangable the internal parts are. My guess is not.
dogfriend is offline   Reply With Quote
Old 06-26-2006, 09:22 PM   #24
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
This is a comparison from those links:
5R44E/5R55E
Used 1997-up in many Ford products with 4.0 L engines, and 2001-up with other engines.
This is a computer controlled rear wheel drive transmission.
Gear Ratios:
2.47:1 1st gear
1.86:1 2nd gear
1.47:1 3rd gear
1.00:1 4th gear
.75:1 5th gear
2.10:1 reverse
5R55W
Used in some 2002-up Ranger, and Explorer models. This transmission is similar in appearance to the 5R55N, but very few parts are interchangeable with it.
This is a computer controlled overdrive (five speed) automatic transmission.
Gear Ratios:
3.22:1 1st gear
2.41:1 2nd gear
1.55:1 3rd gear
1.00:1 4th gear
.75:1 5th gear
3.07:1 reverse
BrooklynBay is offline   Reply With Quote
Old 06-27-2006, 12:03 AM   #25
Wrench
Courtenay, BC
99 B4000 4.0L OHV
Vehicle Specs
Smile
Anyone know the difference between the M5OD -R1,R2,R4. Is the R4 a stronger tranny? Any torque ratings available. Did Mazda use there own I.D. (M5D4)
Wrench is offline   Reply With Quote
Old 06-27-2006, 12:16 AM   #26
BrooklynBay
Brooklyn, NY
Vehicle Specs
That's a question for Spdrcer34. Take a look at his M5OD rebuild thread for some ideas: http://www.explorerforum.com/forums/...d.php?t=159665
Old 02-19-2013, 09:02 PM   #27
chiefmike
Aztec, NM
1995 Ford Explorer Ltd.
Vehicle Specs
A little confused
Gentlemen, after reading all of the posts I am still a bit confused. I just purchased a 1995 Explorer Limited for my daughter. I am trying to figure out what transmission it has (A4LD or 4R55E).
The VIN is: 1FMDU34X3SUA02492
Door jamb sticker: Trans: "T" Axle: "D4"
I appreciate the help. Thanks, Mike
chiefmike is offline   Reply With Quote
Old 02-19-2013, 09:49 PM   #28
BrooklynBay
Brooklyn, NY
Vehicle Specs
Welcome to this forum! You have a 4R55E transmission.
Old 02-19-2013, 09:56 PM   #29
chiefmike
Aztec, NM
Vehicle Specs
Thank you!
I am getting the Explorer for a steal....120,000 miles, no dents, no rust, no damage. Leather seats are great, carpet is perfect, no engine knock, no leaks, new tires, new windshield...all for $500. The problems are: controller for heat/cold damper, switch in the fan controller and a transmission 'problem.' They said it jerks when shifting from first to second and back down to first. Not sure of the problem yet, so I will probably be asking for more advice. Thanks again. Mike
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
