Explorer 911! Forum Rules!!! MUST READ!! | Ford Explorer Forums
Status
Not open for further replies.
Blee1099
Evil Asian
Moderator Emeritus
EF Vendor
Elkridge, MD
04 4Runner, 22 Silverado
Welcome to the Explorer 911! Section. Please follow the following rules set forth:
1. The rules listed in the FAQ, which can be found at the following link: Help
2. Before posting in this forum, please do a search using some keywords at the following link: Search just to make sure your situation hasn't come up before from a previous member. That will help you out in the long run since often times you won't get an instant reply.
3. This section of the forum is dedicated for only situations where your Explorer/Ranger/Mountaineer/Navajo is disabled such as it doesn't start or the truck doesn't move when its in gear. If your situation does not fit the criteria then please look for a more appropriate section to post in.
4. This section is not intended for situations when you are in the middle of a repair and need assistance.
5. If any threads do not fit the criteria they will be moved to a more appropriate section.
Your Co-Moderators of Explorer 911!
Blee1099
Derrick C.
Status
