#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
Would a stuck open thermostat cause a slight rough idle?
Reply
Thread Tools
Old 10-19-2005, 06:59 PM   #1
porshapower
jacksonville Florida
1996 explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I have been chasing a slight bad idle and have tried everything. One thing that struck my mind is that the temperature barely ever moves to the 1st line. Would a bad temp switch for gauge or thermostat or temp sending switch cause a slight bad idle?? 1996 explorer 4.0..ThanksNel
porshapower is offline   Reply With Quote
( Join the Elite Explorers )
Old 10-19-2005, 07:13 PM   #2
Vanquish502
Kitchener, Ontario
91EB, 91EB, 92XLT
Vehicle Specs
Quoted: 0 Post(s)
No. An open thermostat would just let the engine run cool all the time, making your heater useless.
Vanquish502 is offline   Reply With Quote
Old 10-19-2005, 07:33 PM   #3
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 2 Post(s)
it will also not allow the computer to switch into open loop operation,, the truck would run rich all the time and lose performance.
But I would not suspect a bad thermostat to cause a miss.
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
Wifes 07 FJ build - 2007 FJ cruiser locked and lifted
410Fortune is offline   Reply With Quote
Old 10-20-2005, 08:57 PM   #4
Runnin'OnEmpty
Southeast USA
2000 Sport
Vehicle Specs
Quoted: 44 Post(s)
My thermostat stuck open a while back. It gave a fast idle, but it was smooth.
Since it's so easy, I'd replace the thermostat first. Those stock Motorcrafts are made in Germany, and seem to be failure-prone for some reason......? I replaced mine with a Stant.
__________________
2000 Sport 4x2, 4.0 ohv, 5R55E w/Superior shift kit, 3.55 diff, Mazda truck alloys/BFG TAs, RoadMaster Active Suspension, EE anti-sway bar, F&R poly bushings, camber kit, Rancho shocks, Hooker Aero Chamber muffler, Medium Wedgewood Blue.....
Bought another 2000 Sport (God help me), 4.0 ohv auto, 60K actual miles, Cragar SS alloys/BFG TAs, AAL, EE anti-sway bar, Gibson cat-back, Harvest Gold, GT leather interior.
Runnin'OnEmpty is offline   Reply With Quote
Old 10-21-2005, 09:48 AM   #5
johnnyex99
Naperville, Illinois
'99 XLS
Vehicle Specs
Quoted: 0 Post(s)
When my thermostat went not only was I not getting heat, but the idle was rough and my gas mileage went south. Changed the thermostat, got heat, smoother idle, and my gas mileage improved greatly. Its a 15 minute job. Good Luck!
johnnyex99 is offline   Reply With Quote
Old 10-21-2005, 11:09 AM   #6
spindlecone
B
San Jose, Calif
2003 sport trac
Vehicle Specs
Quoted: 0 Post(s)
spindlecone is offline   Reply With Quote
Old 10-21-2005, 11:18 AM   #7
MalcolmV8
Kansas City, MO
05 Tundra DC
Vehicle Specs
Quoted: 0 Post(s)
Spinlecone, what 410 is saying is because the thermostat is stuck open the engine is not coming up to temperature. The ECC sees the engine is cold and enriches the fuel mixture (like a choke on the old carbs). However the engine never gets warm enough so the computer may never switch from open loop (running off predefined air/fuel etc) to closed loop (where it checks its sensors for feed back on air/fuel etc.).
I agree with him that it should not affect idle. Otherwise all cold vehicles would suffer bad idle. I've had a stuck open tstat before and it did not affect idle at all.
__________________
03 Cobra
05 Tundra
94 Ranger 302 AWD
http://www.v8-ranger.com
MalcolmV8 is offline   Reply With Quote
Old 10-21-2005, 11:40 AM   #8
spindlecone
B
San Jose, Calif
2003 sport trac
Vehicle Specs
Quoted: 0 Post(s)
Thats what I thought he was trying to say, open to closed loop
Old 10-21-2005, 12:10 PM   #9
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 2 Post(s)
the coolant temp sensor has nothing to do with idle, does it? Just tells the PCM when to switch from OPEN to CLOSED (hahaha sorry I always thought it was closed then to open, I had it backwards mr picky)
Man where is that flipoff smiley when you need it? LOL
__________________
Old 10-21-2005, 12:21 PM   #10
spindlecone
B
San Jose, Calif
2003 sport trac
Vehicle Specs
Quoted: 0 Post(s)
Actually, I don't believe coolant temp has anyting to do with open to closed loop, believe that is done by the 02 sensors.
My sensors are heated sensors, at cold start up am in open loop for maybe 5 secs, than it go's to closed loop
Old 10-21-2005, 01:01 PM   #11
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 2 Post(s)
No way its the coolant temp! At least it was on the EEC-IV....
__________________
Old 10-21-2005, 02:02 PM   #12
spindlecone
B
San Jose, Calif
2003 sport trac
Vehicle Specs
Quoted: 0 Post(s)
K
Old 10-21-2005, 05:02 PM   #13
EMG7895
'91 xlt, 93
Vehicle Specs
Quoted: 0 Post(s)
When mine went I had had no heat rough idle, stalled a few times, really bad mileage etc.
EMG7895 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
