Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
OIL PRESURE DROPPING
Reply
Thread Tools
Old 12-17-1999, 09:54 PM   #1
91expl-sport
Vehicle Specs
(Original Poster)
Post
I HAVE A 91 EXPLORER 4.0 V6 AND ABOUT A MONTH AGO THE OIL PRESURE GUAGE MOVED FROM THE (M) IN (NORMAL) TO THE (R)AND BACK TO THE (M) THE NEXT DAY. SINCE THEN I ALSO CLEANED THE TROTTLEBODY AND MAF SENSOR. CHANGED THE THERMOSTAT (JET 180),OIL(ROYAL PURPLE SYNTECH),FILTER (MOBIL ONE) PLUGS(BOCH PLAT 4), AND WIRES, FLOWMASTER 40 WITH NEW 2 1/2 PIPES AND ADDED A K&N FILTER CHARGER, TO THE TRUCK. ORDERED BORLA HEADERS ON 12/10/99.
PROBLEM:
WELL TODAY THE IT WENT FORM (M) IN (NORMAL) TO ALMOST TO THE (O)...PARKED THE TRUCK AND REPLACED THE OIL PRESURE SENDING UNIT OR SENSOR.. STILLING HAVING THE SAME PROBLEM BUT THIS TIME ITS MOVING TO THE (R) FROM THE (M). THERE IS NO KNOCKING SOUND FROM THE LIFTERS OR LOST OF POWER..
91expl-sport is offline   Reply With Quote
Old 12-18-1999, 09:42 PM   #2
Exrange
Charlestown, RI
2008 sport trac 4.6 limit
Vehicle Specs
Exclamation
Isn't that a "dummy" guage in there? I know that ford started putting dummy guages in their trucks because too many people were complaining about a fluxuating guage when this was normal. I think the only way it will work if there is absolutely no pressure. Just what i heard, hope this helps. Matt
Exrange is offline   Reply With Quote
Old 12-26-1999, 01:03 AM   #3
slow-demon
Hawaii
'91 xl sport
Vehicle Specs
Post
The oil pressure gauge sender is just a switch. It doen't vary with oil pressure like other brands of cars. It just switches if their is pressure. Try taking the single wire that comes of the oil sender and ground it. The gauge needle should go back the normal postion which is usually by the "R or M" in normal. If it does then change your oil pressure sender.... The only way to correctly check oil pressure is with a manual oil pressure gauge.
[This message has been edited by slow-demon (edited 12-26-1999).]
slow-demon is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
You smoke cigarettes? FourXFred General Topic Polls 167 11-12-2011 09:12 PM
OIL PRESURE DROPPING 91expl-sport Under the Hood 2 01-22-2000 06:22 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
