Oil Pressure Gauge Replacement | Ford Explorer Forums
RVerdejo
My Oil Pressure gauge isn't working Dead Link Removed. Spent the day taking the instrument cluster off so I could check behind it. I'm getting voltage at the 'B' contact (14.46) and at the 'S' contact (-0.02)
There's continuity in the sending unit wiring.
Chilton's talks of testing the gauge with a special tool (Rotunda Gauge Tester) but I don't want to make that special investment.
Can I just use a jumper from the B to S contacts to see if the gauge moves without damaging it?? Dead Link Removed
I considered changing out the sending unit, but it's location will require moving the power steering, and maybe the AC compressor just to get to it (front of engine on driver's side just below valve covers).
Any help/tips would be appreciated
Don't Worry about things you can control...
Don't Worry about things you cannot control.
96 Eddie Bauer AWD V8
Two other cars that aren't Explorers
[This message has been edited by RVerdejo (edited 01-11-2000).]
Yesterday, while driving to work, the oil gauge started working again Dead Link Removed. WHile driving home in the evening, I noticed the gauge stopped working again Dead Link Removed
Damned if I know what the hell is going on, but the airbag light, check gauge light, and check engine lights are driving me up the wall Dead Link Removed
[This message has been edited by RVerdejo (edited 01-13-2000).]
