Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Elite Explorer 911!
Notices
Elite Explorer 911! 911! is for situations where your truck is currently out of commission and the owner is in a crisis situation. Members will try to answer your questions asap, no time frame is guaranteed. Only Elite Explorers can post new threads in this forum
Replaced alt. still not charging the battery.
Reply
Thread Tools
Old 11-02-2005, 07:36 PM   #1
superedge88
Minnesota
99 Mountaineer 5.0L
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
My battery was not being charged, the other morning I had to jump start it to get it to the mechanic (for a leaky antifreeze issue) The mechanic told me that the alternator was bad. I replaced the alternator, but still no charging at all. I looked through my chiltons manual, but got no where. I started following the + wire that comes from the alternator and goes to the battery. I found a junction box where there is a 175 amp fuse. I tested the fuse and I get no continuity across it (it isn't one of those clear fuses but kind of an ANL style fuse) Of course I found this fuse after I already took the alternator out to go back and have checker test. I did have checker test the newer one and the old one, both are fine, but they would not let me return the new one I had just bought from them last night. So I am unsure if all I have to replace is this 175 amp fuse, or if there is another possibility that I am not thinking of? Since I also have had problems with my antifreeze leak, I haven't been to work in 3 days! I have to get this vehicle operational, I have changed alternators out before, and I have never had this much trouble before.
superedge88 is offline   Reply With Quote
( Join the Elite Explorers )
Old 11-02-2005, 07:41 PM   #2
sn0border88
Master Apprentice
Souderton, PA
sn0border88's Avatar
1992 XLT
Vehicle Specs
Quoted: 0 Post(s)
the wires maybe shot. Check all points with a voltmeter.
__________________
My Photos---Emily Rose---SAS Thread---My Mug
1992 4dr XLT. SAS'ed HPD44/9" 5.13's Locked F/R 36" SX
1999 4.0 5spd sport on 31" BFG Muds
sn0border88 is offline   Reply With Quote
Old 11-02-2005, 07:51 PM   #3
superedge88
Minnesota
99 Mountaineer 5.0L
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I'll do continuity and voltage tests throughout both negative and positive wires.
Old 11-02-2005, 07:52 PM   #4
budwich
Ottawa, Ont
96 XL
Vehicle Specs
Quoted: 0 Post(s)
check to make sure that you are getting 12v IN on your alternator.... referred to as the "A SIDE". This "turns on" the regulator and causes 12v + to go out on the "Bside". If you aren't getting the 12vin either the fuse is bad or the lead which goes to your start relay (at least in 96) is no good .... ultimately this goes back to your battery.
budwich is offline   Reply With Quote
Old 11-02-2005, 07:55 PM   #5
sn0border88
Master Apprentice
Souderton, PA
1992 XLT
Vehicle Specs
Quoted: 0 Post(s)
found this, it should help. http://www.explorerforum.com/forums/...d.php?t=122185
__________________
Old 11-03-2005, 12:58 PM   #6
Green98XLT
Winc. VA
Green98XLT's Avatar
2002 Limited
Vehicle Specs
Quoted: 12 Post(s)
Get a voltmeter and first make sure you have a minimum of 12.6volts at the stud on the back of your alternator.
If you do, then start the Ex and measure voltage at the same stud on the back of the alt. If there is voltage present above 13.2volts then your alt is fine and you have a problem elsewhere. Replace that 175amp maxi-fuse and with your Ex running, check your voltage at the battery. It should be no less than 13.2v.
You'll then want to verify that you have the same voltage at the junction box as you do at the back of the alt.
Remember, a fully charged battery must have a minimum of 12.6volts and the alternator should have no less than 13.2volts or you have something wrong.
__________________
2002 Limited
4.6 V8, all stock 142,000 miles
Green98XLT is offline   Reply With Quote
Old 11-03-2005, 02:18 PM   #7
Brett F.
Upstate SC
'93 4x4
Vehicle Specs
Quoted: 0 Post(s)
What's funny is that I sat in the Advance Auto parking lot and changed out 3 alternators before giving up. Took it to a local Mr. Alternator and they couldn't figure it out. Finaly once of the gurues came in and said check the fuse.
A freaking fuse was keeping the alternator from charging the battery. Change the fuse out. That is probably all it is. I keep spare fuses like crazy now.
__________________
Lovin' life here in the good ol' South.
My stock '93 4x4 XLT has been reclaimed from my chain smoking daughter and I am having to fix the neglected ride. 31's being swapped from 96 to this one.
My current daily driver is a 1996 XLT 4WD on 31's.
Brett F. is offline   Reply With Quote
Old 11-03-2005, 02:26 PM   #8
orange_exploder
Columbus, OH
2001 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
Did you check the battery to make sure it doesnt have a bad cell. I had a chevy citation that use to eat alternators every couple months. I even bought a new battery right after i changed the Alt the first time. After the third alt i said screw it and took the battery back to NAPA and found out that my new battery had a bad cell. Problem solved.
orange_exploder is offline   Reply With Quote
Old 11-03-2005, 07:56 PM   #9
superedge88
Minnesota
99 Mountaineer 5.0L
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
I changed out the 175 amp fuse, works like a charm. Thanks guys!
Old 01-19-2009, 12:01 AM   #10
jordanphilipster
Lafayette, CO
1998 Ranger 4WD 4.0L
Vehicle Specs
Quoted: 0 Post(s)
I have a similar problem, but with a non-similar solution.
The other day, the charging system decided to quit on me. Car runs, but everything is running off the battery. I know this because it dies after a period of time and a voltmeter shows me 12.6 or lower depending on how long the engine has been running or if the lights are on or not. I have to manually charge the battery to get it back up. I pulled the alternator, autozone says its bad. I get a new one thinking, duh, this WILL fix it. No, it didn't, I still have the same problem. I tested all fuses that I think are related (175amp and the 30amp #14) under the hood, still nothing. I get battery voltage at the b+ alternator post, so I know I have continuity. My guess is that I'm not getting the voltage needed on the A side of the alternator. (My understanding is that this voltage is required to "enable" charging from the alternator) Can anybody tell me what the voltages should be on the small wires going to the alternator? I can't find this info anywhere!
Thanks!
jordanphilipster is offline   Reply With Quote
Old 01-19-2009, 06:39 AM   #11
dogbis
south bend,in
'96 sport
Vehicle Specs
Quoted: 0 Post(s)
check your solenoid for the starter. even thuogh it starts find can still cause a no charge situation. I have seen this more than once.
dogbis is offline   Reply With Quote
Old 01-19-2009, 08:00 AM   #12
Cobraguy
Phoenix...Greatest City on Earth
Cobraguy's Avatar
1995 EB & 1999 EB 5.0
Vehicle Specs
Quoted: 13 Post(s)
I have never seen that 175A fuse blown. It would scare me to death to think about what could blow that.
__________________
http://banners.wunderground.com/weat...AZ/Phoenix.gif
Quote:
Originally Posted by four0sport
she is a girl, there are no answers, only more questions!
Cobraguy is offline   Reply With Quote
Old 01-20-2009, 05:29 PM   #13
JDraper
Somewhat Functional
McVeytown, PA
JDraper's Avatar
'11 XLT
Vehicle Specs
Quoted: 30 Post(s)
Quote:
I've seen it smoked once or twice. Usually caused by someone working on the vehicle with it running and accidentally shorting the positive terminal on the alternator to ground with a wrench or screwdriver...(been there, done that...d'oh!!)
__________________
Moderator..Home Improvement/Explorer 911/2011 Explorer Forum
You took my breath away....and now I want it back....
'66 Mustang Coupe, '04 Mustang Mach 1, '08 Focus, '11 Explorer XLT
"Ex"plorer's: '92 Sport, '94 Sport, '01 XLS
Our Crappy Website
JDraper is online now   Reply With Quote
Old 01-27-2009, 01:39 AM   #14
ohe_boy
Kane'ohe, Hawaii
ohe_boy's Avatar
'94 4x4 XLT
Vehicle Specs
Quoted: 0 Post(s)
Swapped out bad alternator with a new one. tested out fine. Left it over night, now battery is completely dead. I mean completely dead. (1.5V)
Any ideas???
__________________
Kea Hottendorf - '94 4X4 XLT, FULL WIDTH HP Dana 44 up front with FULL WIDTH Ford 9" in the rear. 4.88 gears Lockright front and detroit back 36'' IROKs 3" BL, KKM Air Filter, Flowmaster 50 series,
My SAS Thread
ohe_boy is offline   Reply With Quote
Old 11-04-2009, 07:26 PM   #15
skidooer
Vehicle Specs
Quoted: 0 Post(s)
I have a 1996 F150 that keep blowing that 175Amp fuse leading to the alternator. When that happens the alternator isn't charging. When i jump the two leads together the alternator starts to charge again. So i replace the fuse, but only to find that it'll last about a month or so, then the same fuse will blow again. I have checked battery voltage and it measures 12.8v when the motor is off, then when i fire up the truck the charge rate is 14.2v. It appears to blow this fuse out when the alternator stops charging. Is it possible that the diodes in the regulator malfunction and then it put a shot of AC thru the fuse taking it out. Nothing else on that truck has a wire heavy enough to take out that fuse other than the alternator putting out AC or am i wrong. Please help.
skidooer is offline   Reply With Quote
Old 11-12-2009, 07:15 PM   #16
Moto Mel
Virginia Beach, Va
'98 XLT + 2000 Navigator
Vehicle Specs
Quoted: 0 Post(s)
US Charging?
Quote:
In reading all of these posts I see that no one has mentioned cleaning the battery posts and clamps. I realize that it's basic but, I've seen many starting and charging problems cured by cleaning the terminals at the battery.
Mel
Moto Mel is offline   Reply With Quote
Old 11-13-2009, 10:48 AM   #17
skidooer
Vehicle Specs
Quoted: 0 Post(s)
Those items were the first thing a person would check. Oh by the way, i've been a mechanic for 25 years, but didn't run into this much on the F150. I am not a ford mechanic so they have features there, that don't apply to other manufacturers, but the solenoid and the starter draw was checked. As long as the truck is charging there isn't a problem of any kind. It's just when that fuse blows you can check the alternator and it no longer puts out 14.2 volts. It's not putting out anything. However, as soon as i jump those links together that attach to the fuse, it starts charging again. Hence, install another new 175amp fuse and drive away. this could be good for a month or so, then it returns. I have checked wiring from the rear of that truck including accellery plug in (re for trailers), all the way up the chassis, and that includes the wires on top of the fuel tank. Yet, to know avail. This one has me stumped.
Old 11-21-2009, 05:50 AM   #18
ranger7ltr
Great State of Texas
1999 Sport
Vehicle Specs
Quoted: 35 Post(s)
Blown megafuse is usually a short in the alternator...
When I bought my current Ford Explorer, ther was no voltage to the rear terminal...Checked the megafuse and it was blown...So I pulled the alternator and had it checked and sure enough it had a dead short to ground internally...
I had a spare alternator from a Ranger v8 conversion so I changed the case to use the Explorer mounting lugs and had it tested...It was charging just fine so I mounted the alternator into the Explorer...Changed the megafuse and it has been happy ever since...Charging voltage is 14-14.5v and all circuits are happy...
If your alternator is intermittantly charging then blowing the megafuse, I would test the wiring at the alternator to see if it might be touching the case or body somewhere or the diodes/rectifier bridge inside for movement...Make sure the case bolts are tight and it can't shift a little bit...A little movement is all it might take to ground out an internal connection...
If there was a dead short to blow the fuse, it would still be there after the fuse is blown and not start charging when you connect the terminals...
__________________
When in doubt, use a bigger hammer!
2014 Jeep Compass Limited [Company Vehicle]
2003 Ford F-150 XLT Supercab
1999 Ford Explorer Sport [new playtoy]
1983 Ford Ranger V8 [soon to be gone]
ranger7ltr is offline   Reply With Quote
Old 11-21-2009, 07:37 AM   #19
cattleshow
Central Texas
1999 explorer sport
Vehicle Specs
Quoted: 0 Post(s)
I recently found myself in need of a jump as the the battery was dead and I figured it might be the alternator.As it turned out my NEW sears diehard was a die easy.I had it tested and found out it was defective. Glad I didn't jump in and replace the alternator.
The tech at sears told me they get a lot of bad battery's back. Paid $110.00 and when I brought it back I noticed a little sticker on it that said made in Mexico. So much for Diehard,Americas best battery as there advertisement says.
Yes ,the alternator regulater must see 12 volt for it to work.
cattleshow is offline   Reply With Quote
Old 11-23-2009, 08:36 PM   #20
jremington59
Watertown, NY
jremington59's Avatar
1997, 99 and 2000 5.0's
Vehicle Specs
Quoted: 142 Post(s)
I'm not sure if it's been mentioned yet, but there's also a small fuse n the power dist box for the alt in some years.
jremington59 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
