#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
door ajar light switch
Reply
Thread Tools
Old 11-05-2005, 02:02 PM   #1
mrossirr
Hickory,North Carolina
1999 Sport 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
How do you replace the door ajar light switches in the rear lift gate ?
99 Ex Sport
Thanks in advance, Mike
__________________
99 EX Sport
Pioneer -DEH 3500
Lightning Audio B150.2 Amp
10" RF Sub
Q-Logic custom enclosure
mrossirr is offline   Reply With Quote
( Join the Elite Explorers )
Old 11-05-2005, 04:06 PM   #2
Ray Lobato
Moderator
Ray Lobato's Avatar
2006 Honda Accord
Vehicle Specs
Quoted: 1 Post(s)
Cool
The whole latch machanism has to be replaced, as the light switch is part of the latch machanism.
__________________
Happy Wheelin'
Ray L.
Ray Lobato is offline   Reply With Quote
Old 11-05-2005, 06:01 PM   #3
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Quoted: 2 Post(s)
For a temp solution you could just remove the wire connector from the latch mechanism. This would take the rear hatch out of the door adjar loop...
__________________
John D-"Search first, Ask questions later" & "You can have my Explorer when you pry the keys from my cold dead hands." <<<Forum Rules >>>*My Truck*
4x4 Trouble Shooting Guide
See how cars work Axle and tire calculators U-joint replacement info/pics
Repair info NEX-New England Explorers NEX: Club Events
DeRocha is offline   Reply With Quote
Old 11-05-2005, 08:38 PM   #4
mrossirr
1999 Sport 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
How do I disarm the switches?
__________________
99 EX Sport
Pioneer -DEH 3500
10" RF Sub
Old 11-06-2005, 08:50 AM   #5
mrossirr
1999 Sport 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Ray and DeRocha -Thanks for the replies. Do I take the latch itself out to replace or unplug these switches or do I take the interior trim off ? Also I heard that both latches on each side of the lift gate have the switches ,is this correct ? One more question - what are the two spring loaded plastic pieces at the bottom corner of each side of the liftgate ? Thank You
__________________
99 EX Sport
Pioneer -DEH 3500
10" RF Sub
Old 11-06-2005, 09:51 AM   #6
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Quoted: 2 Post(s)
The spring loaded guides on each side of the body cradle the hatch to ensure it closes evenly. On my 1st gen only the driver's side latch mechanism is wired into the dome light circuit. I removed the hatch trim panel to access the latch wiring.
What kind of problem are you having with the rear lift gate switch? I mean if the door adjar light is on have you ruled out all other doors first?
__________________
Old 11-06-2005, 10:07 AM   #7
mrossirr
1999 Sport 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
DeRocha- I am 99% sure the lift gate is my problem. For the last few months I have had to close it several times to get the dome lights to go off. Also the door ajar light. Now they will not go off at all. With the key on or the vehicle running I get a chime when I open the drivers side or passanger side doors but not when I open the liftgate.
__________________
99 EX Sport
Pioneer -DEH 3500
10" RF Sub
Old 03-20-2006, 11:07 AM   #8
westcovinajoe
West Covina, Ca
91 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
I have this problem too.
By the hatch trim panel do you mean the paneling on the hatch itself? Or is it the panel area where the rear washer spray is located?
Also a weird aside, my X does the door chime noise anytime I open my driver door, key in ignition or not, but the other doors do not set it off.
Also, I have removed the wiring for the rear dome light and I noticed the 3rd brake light is not working, are they connected?
Thanks for the info in advance, I love this site and will be an elite explorer someday!
Joseph.
westcovinajoe is offline   Reply With Quote
Old 03-20-2006, 12:09 PM   #9
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Quoted: 2 Post(s)
Joseph.
The door ajar mechanism is contained within the Hatch itself. On the left/driver's side the latch mechanism which locks onto the striker post contains a switch and wire harness hidden inside the hatch. To test you can close all doors and verify the interior/dome lights go out. Then open the rear hatch and verify the interior lights come on. Without moving the hatch use your fingers to slowly squeeze the latch mechanism towards the locked position.. If the switch is working correctly you will see the interior/dome lights go out (before it locks all the way)... If you closed the latch all the way just use the hatch handle to unlock it again..
__________________
Old 03-22-2006, 08:04 PM   #10
westcovinajoe
West Covina, Ca
91 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
Thanks got it fixed! I just carefully closed the hatch after seeing how it worked with your advice DeRocha and I got it working again! All the lights are back in now and work!
DeRocha rules!
Joseph.
Old 03-25-2006, 09:27 AM   #11
HAWK53
Smithfield, R.I.
99 XLT
Vehicle Specs
Quoted: 0 Post(s)
I have the same problem with the rear hatch, i spray the mechinism with WD40 and Im good for about 4 or 5 months
HAWK53 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
