Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Ranger - Mazda B-Series Forum > Ford Ranger - Mazda B-Series Forum
Notices
Ford Ranger - Mazda B-Series Forum Ford Ranger and Mazda B Series forums. The Mazda B2300 B3000 and B4000 are clones of the Ford Ranger, with all systems the same. The only differences are trim and a few body parts. This forum discusses Ford Ranger and Mazda B series specific issues. Owners of the older Mazda B2000 B2200 and B2600 are welcome as well.
ABS light on...how bad?
Reply
Thread Tools
Old 11-14-2005, 05:19 PM   #1
mkey1029
Columbia, SC
2000 Ranger
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Brakes are in good shape...I am fairly inexperienced. Will a brake job fix this, or am I looking at some overpriced "computer" BS? Thanks for the response.
mkey1029 is offline   Reply With Quote
( Join the Elite Explorers )
Old 11-15-2005, 07:14 AM   #2
ExplorerDMB
Moderator/Technician
Mechanicsville, Virginia
2004 Acura TL
Vehicle Specs
Quoted: 0 Post(s)
When the ABS light comes on your ABS is disabled. Now, how many miles are on the truck. If there is a lot of debris and build up around the one of the sensors it may not be working correctly. Also, some sensors do go bad and you should check them. A brake job will not/should not fix your problem.
-Drew
__________________
My Useful Threads (38 Entries and Growing)
ExplorerDMB is offline   Reply With Quote
Old 11-15-2005, 07:14 AM   #3
ExplorerDMB
2004 Acura TL
Vehicle Specs
Quoted: 0 Post(s)
Quote:
-Drew
EDIT: I don't know if autozone pulls abs codes, but you can try and see if you can get a code. That'll help you out
__________________
Old 11-15-2005, 07:51 AM   #4
BuffaloXplorer
The X had to go!
Buffalo, New York
BuffaloXplorer's Avatar
2006 Impala SS
Vehicle Specs
Quoted: 0 Post(s)
No, they don't. Any decent repair shop can pull the code and determine which sensor is bad. Shouldn't cost TOO much.
__________________
Chris
2006 Impala SS
Black on Black Leather
303hp V8 w/DOD - XM Radio
Adios 1996 Explorer Conversion - 4.OHV6
BuffaloXplorer is offline   Reply With Quote
Old 11-22-2005, 10:50 PM   #5
Ranger Al
Fresno, California
'00 FX4 Ranger
Vehicle Specs
Quoted: 0 Post(s)
Mine have trouble code 27 and no Ford Stealership would tell me what the code meant nor the Chilton manual. It so happen I found a website and guys was talking about the same code as mine and how to repair it.
You need to count the number of flashes on the ABS light and waited a few seconds and the second flash. As for code "27" it would flashes twice and waited a few seconds and flashes again 7 times.
The repair costed me $1.99 cents with a little knowledge of soldering. If thats your case, let me know and I can direct you on getting the part and how to replace the part.
__________________
1. XLT Ranger 4dr 4.0 5 spd 4X4-> K&N filter, grill insert, Stainless steel skid plate, 98 Mountaineer front axles swap, factory motor transplanted and new clutch kit, 3" Flowmaster 40 dual outlet, hard bedcover, JamesDuff traction bars, Bilstien shocks.
2. 1999 K1200RS BMW motorcycle <fast German technology>
3. 2005 Suzuki XL 7, the only small SUV with 7 passengers I could effort under $15K
4. 1970 VW project -needs exhaust, interior, extrical parts..
Ranger Al is offline   Reply With Quote
Old 11-23-2005, 06:13 AM   #6
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Quoted: 3 Post(s)
When the ABS computer detects a fault in one of it's sensors it disables ABS braking (standard braking is unaffected). It does this because the sensors tell the ABS computer each wheel's speed; the ABS computer uses this info to pulse the brakes accordingly during a lock up condition... As such the Yellow ABS light is no immiedidate cause for alarm, just an indication that ABS braking is not working.
__________________
John D-"Search first, Ask questions later" & "You can have my Explorer when you pry the keys from my cold dead hands." <<<Forum Rules >>>*My Truck*
4x4 Trouble Shooting Guide
See how cars work Axle and tire calculators U-joint replacement info/pics
Repair info NEX-New England Explorers NEX: Club Events
DeRocha is offline   Reply With Quote
Old 11-23-2005, 07:08 AM   #7
CougarX
Louisville, Kentucky
'98 EB, '02 ST, '97 XLT
Vehicle Specs
Quoted: 0 Post(s)
Ranger Al - did you pull your own ABS codes? How did you do this without any special equipment? Just curious cause i need to do mine too.
CougarX is offline   Reply With Quote
Old 11-23-2005, 08:04 AM   #8
BuffaloXplorer
The X had to go!
Buffalo, New York
2006 Impala SS
Vehicle Specs
Quoted: 0 Post(s)
Quote:
I think you're talking a about the airbag light - the ABS does not do this. If it DOES, you're the only one on the forum that has had this happen
__________________
Chris
2006 Impala SS
Old 11-23-2005, 10:43 AM   #9
EBInterceptor
Ada, MI
'98 Sport
Vehicle Specs
Quoted: 0 Post(s)
My ABS light has gone on because my hub when bad and little metal shavings were blocking the sensor. Something to keep in mind since it could have been much worse when my hub blew out on the highway. Luckily I was able to limp to a place where I could fix it. Just something to think about if the brakes and sensor are still in good condition.
__________________
Mike
'98 X Sport 4.0L V6 SOHC 4x4,KKM,Shackle/TT, AAL, Rancho RSX, Flowmaster 50, 4dr. Leafs
http://www.cardomain.com/id/dishdog2
'07 Sport Trac Limited, 4.6L V8 4x4
http://www.cardomain.com/ride/3358201
EBInterceptor is offline   Reply With Quote
Old 11-23-2005, 08:57 PM   #10
Ranger Al
Fresno, California
'00 FX4 Ranger
Vehicle Specs
Quoted: 0 Post(s)
Chris! You are right, it is the Airbag trouble code! Anyway, if anyone have airbag trouble code. I am willing to guide ya to get it fix.
I think you can pull the ABS from OBD II code reader from the local Autozone. I too having problem with the Chubby Blazer cause of the ABS stuff. I guessed, I'll get to it whenever the wife get tired of seeing it.
If anyone interested in the front ABS sensors (2 sensors), I still have it. Make me an offer.
__________________
Old 07-11-2007, 06:30 PM   #11
FallsRanger
Niagara falls
2000 Ranger xlt 4x4 offro
Vehicle Specs
Quoted: 0 Post(s)
US Dirty voltage
Man i bought my truck from told me abs light on due to left sensor reading back dirty voltage does that mean sensor shot or is there some other way of fixing it ?
FallsRanger is offline   Reply With Quote
Old 07-12-2007, 07:44 AM   #12
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Quoted: 3 Post(s)
Quote:
It sounds like the sensor is sending back a constant lock up voltage.. As mentioned in some previous posts the ABS sensor magnetically detects the teeth on the ABS tone ring. When metal debris collects on the sensor it will become blind and unable to detect the individual teeth on the ABS tone ring and send out a constant lock up signal to the ABS computer.
Check out other threads such as ABS Sensor problem for more info.
__________________
Old 07-12-2007, 09:33 PM   #13
Ranger Al
Fresno, California
'00 FX4 Ranger
Vehicle Specs
Quoted: 0 Post(s)
Ok.. my ABS sensor does go bad as well, I am not sure if it is too late to help you out. There is a rear sensor located on the pumkin, sometime you could clean it and reinstall it and will be fine. I tried but doesn't work, so I had to get mine at NAPA (around $7) and problem fixed.
__________________
Old 03-31-2010, 04:12 PM   #14
garythedoorman
2004 xlt
Vehicle Specs
Quoted: 0 Post(s)
My ABS light is on also and brakes are new and my 4x4 high light keeps flashing is this a serious issue?
garythedoorman is offline   Reply With Quote
Old 04-05-2010, 08:11 PM   #15
drewsexplorer
Lebanon, Ohio
1996 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
My ABS light is on and the truck will not go into 4wd at all, i switch to 4hi or 4lo but nothing happens, just the light comes on and stays on(the 4hi or 4lo light). Should i use my OBDII reader on it, will that work?
drewsexplorer is offline   Reply With Quote
Old 04-05-2010, 09:00 PM   #16
rwenzing
Michigan
03 Ranger FX4 LII 5.0 S/C
Vehicle Specs
Quoted: 2 Post(s)
Quote:
Probably not. Ordinary OBDII readers can only communicate with the PCM, not with the other modules like a 4WABS Module or GEM. A Ford dealer or a well equipped independent shop will have the necessary reader.
__________________
Bob
2003 Ranger FX4 Level II, 5.0L V8, 4R70W, BW4406 T/C, Aussie Locker front, Torsen rear
Torque Monsters, Magnaflow, duals; Explorer EATC, steering wheel controls, consoles
Bilstein 7100 reservoir shocks, Cadillac/Mustang SVO rear discs, Duff traction bars
rwenzing is offline   Reply With Quote
Old 04-22-2010, 07:25 PM   #17
drair
Athens, OH
2002
Vehicle Specs
Quoted: 0 Post(s)
So, my ABS dash icon/light flashes 4 then 6, for a failure code of 46. After that, the ABS light stays on continuously. Can anyone tell me what an ABS error code of 46 translates to in English? I can't find them online, and as noted earlier in this thread, this isn't an engine control problems so my OBD-II reader is of no use.
Thanks.
drair is offline   Reply With Quote
Old 04-23-2010, 10:16 AM   #18
drair
Athens, OH
2002
Vehicle Specs
Quoted: 0 Post(s)
Make that Airbag light, not ABS
sorry for the confusion. I meant that my AIRBAG warning light is flashing a 4-6 code. Any idea what sensor or failure mode that means? Thanks.
Old 04-23-2010, 10:23 AM   #19
ExploringNC
Hickory, NC
'98 XLT, '91 EB
Vehicle Specs
Quoted: 0 Post(s)
first and easiest thing is to clean the sensor located on top of the rear axle or just replace it, it's not much from parts store. Did you make sure fluid level correct?
__________________
'91 EB 4.0 OHV 4x4
31x10.5 Maxxis Bighorn's
Uwharrie 2010
BrooklynBay's List of Useful Threads
ExploringNC is offline   Reply With Quote
Old 04-25-2010, 05:27 PM   #20
joejoelewis
Oxon Hill, Maryland
2006 Explorer xlt
Vehicle Specs
Quoted: 0 Post(s)
Dk Exp abs light on
My abs light came on, what does that mean?
joejoelewis is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
