#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
Fuel Filter stuck
Reply
Thread Tools
Old 12-09-2005, 08:02 PM   #1
rsilva708
Hickory Hills, IL
2000 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Fuel Filter stuck
I went to replace my fuel filter today, and it just wont come off. I used the fuel line removal tool, and of the pre filter side to come off, but no matter how hard I press in on the tool, I can't get it to go all the way in to push out the clips on the post filter side. Are there any tricks to getting getting a stuck fitting off?
I have read the how to that I found with the search, but it doesn't help with the stuck fitting
Thanks
Bob
2000 XLT 4.0 OHV
rsilva708 is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-09-2005, 08:14 PM   #2
Skibum1989
Sammamish, WA
'95 XLT
Vehicle Specs
Quoted: 0 Post(s)
When I replaced mine I thought I had to really ram that tool in to get it to disengage, turns out all it takes is a gentle push, you should hear a VERY subtle click. Then, as you keep pressure on the tool pushing towards the gas tank, pull the filter towards the engine side of the car, (kinda like a chinese finger trap, you gotta push and pull at the same time to get it off.) it should just slide off. I really doubt it rusted shut or anything like that.
Skibum1989 is offline   Reply With Quote
Old 12-09-2005, 08:30 PM   #3
rsilva708
Hickory Hills, IL
2000 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
Tried all that. When I got the pre filter side off, and let the filter hang down to drain it, it drained almost black with a lot of black "film" like material out of it. If it was rusted together, what would be my options at that point.
I tried the plastic and metal tools, with the pushing and pulling. The tool simply will not push all the way into the fitting.
Old 12-10-2005, 03:25 PM   #4
Skibum1989
Sammamish, WA
'95 XLT
Vehicle Specs
Quoted: 0 Post(s)
Your local hardware store should have a rust removing solution available, give that a try, be careful not to use anything that could eat away your fuel lines.
Old 12-11-2005, 12:16 AM   #5
F14CRAZY
To the flo...
Dimondale, Michigan
F14CRAZY's Avatar
'92 GT, '93 Limited
Vehicle Specs
Quoted: 0 Post(s)
Cut the old lines and get some fuel-grade rubber hose and good clamps and go over it. Had to do that a few days ago on my Limited (the "gas leaks suck" thread).
__________________
'07 Subaru Forester 2.5 X. AWD (of course), manual trans
Previous: '03 Mounty 4.6L AWD, '93 Limited 4WD, '92 XL manual trans
F14CRAZY is offline   Reply With Quote
Old 12-11-2005, 01:57 PM   #6
Turdle
Move along people
nothing to see here
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 653 Post(s)
Been right with you and thought it wasn't coming off, but it did, right on my last try believe it or not. Keep trying , it will come off, you kind of have to push it on further, click push again and pul, twist all at the right time
Use all the cuss words you can muster, we're here for moral support also you know
__________________
Jon
9 mile skid, on a ten mile ride. Hot as a pistol but cool inside.
2000 Mountaineer
1998 Mountaineer "Turdle"-gone
1993 Convertible "Vitamin D Wagon" Sold also
Turdle is offline   Reply With Quote
Old 12-11-2005, 02:05 PM   #7
Rhett
Let Them Eat Cake
Cape Girardeau, MO
Rhett's Avatar
94 Sport 4x4
Vehicle Specs
Quoted: 43 Post(s)
I had a hard time changing my fuel filter the last time I did it. As you may have read in other threads, for some reason my truck doesn't like the metal tool, but it likes the plastic tool. Even so, I thought it would never come loose. Then one day, I got under there, and it came off on the first try. Needless to say, I was pretty surprised after all the trouble I had with it in the weeks prior.
__________________
94 Sport 4x4; AMSOIL cone filter; Granitelli MAF; BBK 66mm TB; Apten dual-program chip; BFG's; Warn manual hubs; Timken bearings w/Spicer internals; IPCW Crystal Diamond headlights; Blazer DF1075 55W fogs; and more stuff etc. etc.
Rhett is online now   Reply With Quote
Old 12-11-2005, 06:11 PM   #8
Lloyd10977
Trenton, NJ
Lloyd10977's Avatar
1995 Limited
Vehicle Specs
Quoted: 3 Post(s)
Quote:
I had the same problem and when I quit the first time I noted one, mind you I said ONE!!!, small drop of gasoline at the joint. The next day it came off like it was greased with butter. I can only guess that the small gas leak must have lubricated the joint and the springs, making it come apart as per the original design.
__________________
Black , street stock, 1995 Ford Explorer Limited, 4.0L-OHV V6 with AirHog filter, iridium spark plugs w/Taylor wires, 4dr, auto w/tow package and 3.73 Traction-Lok rear, 4WD, 4 wheel disk brakes with ABS, with tan leather, sunroof and engine block heater, made in Canada. Rear leaf springs from a '78 Bronco 3" wide spring pack added to the stock 2.5" wide main spring, 1.2" lift.
Lloyd10977 is offline   Reply With Quote
Old 12-11-2005, 06:40 PM   #9
nctrader77
Charlotte NC
2000 Ford Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
Same problem
I had the same problem, and almost gave up. However, after I twisted the filter on the line several time it came right off. Hope it works for you.
nctrader77 is offline   Reply With Quote
Old 12-13-2005, 09:11 PM   #10
karl_burns
Winston Salem, NC - Go Deacs!
karl_burns's Avatar
98 Sport OHV 5speed
Vehicle Specs
Quoted: 0 Post(s)
I screwed with mine for 45 minutes and had no luck. I'll go back and try this weekend.... in the SNOW! Argh!
Karl
__________________
Karl Burns
2000 Explorer Sport: KKM, BBK 66mm TB, Granatelli 70mm MAF, 3" Intake, 31" BFG AT/KOs
1998 Explorer Sport: Spindle Lift, SOA, Rancho 9000s, powered by Apten, PIAA 1500s and 520s
Eclipse, McIntosh, Focal and JL sound system
karl_burns is offline   Reply With Quote
Old 12-15-2005, 10:58 PM   #11
F14CRAZY
To the flo...
Dimondale, Michigan
F14CRAZY's Avatar
'92 GT, '93 Limited
Vehicle Specs
Quoted: 0 Post(s)
Aw I saw just cut em and go over them with good rubber hose and a few Fernco type clamps.
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
